ask some questions. I've been around bikes a long time and own 2 Valkyries and a Can Am Spyder, however I wanted something a little different and I'm in the process of building a V8 trike with a 302/C4/independent rear. After much research I decided to go ahead and use a 1100 Goldwing front end even though I was worried about it being strong enough however I wanted the motorcycle look up front. My main question is how much air pressure can I run in the front end, and is there aftermarket heavier spring available for the forks so I don't have to run high pressure. Thanks in advance and I'm sure before I get done I will have more.
