Likes Likes:  10
Results 1 to 8 of 8
Thread: Spark Plugs
    200+ Posts
    NC Triker's Avatar
    Jul 2012
    Supply, NC
    Default Spark Plugs
    Had the 30k service done on my 2017 Triglide. Service mgr said spark plugs are changed on 30k service but I didn't have them changed as I have no ignition problems. Now I am thinking about upgrading the spark plug wires to those from DK Custom Products. While I have the tank off I will change the spark plugs. Does anyone have an opinion on the spark plug wires and brand of spark plugs?
    OEM plugs have served me good , The Pro wires by Taylor D K Customs sells are about as good as they get
    Since the advent of unleaded gas and hot ignition systems have yet to change spark plugs on any of my vehicles my truck right now has 60,000 miles and no problems with the plugs my 2011 triglide I had close to 50,000 miles and never touch the plugs. My wife’s car has 102,000 miles and still original plugs….
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by NC Triker View Post
    I think they work well. I put them on a couple yrs ago
    30+ Posts
    Apr 2023
    SHEBOYGAN
    Before I would change either, look at your owners manual for recommendations.
    Pull your plugs and look at them to see if they are burning properly. You just had a 30k service done, what does the service tech think?
    Your plug wires, put them to an ohm test. By doing this you'll know how things are. Don't spend money to spend money.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Changed the spark plugs last month. Used OEM. Bought them with Visa gift card points ying yang. Came under $25.00- I've spent more in the first 5 minutes walking into a bar. You won't see any benift from upgraded spark plugs on a stock motor except from some delusion you now have a race motor.
    Quote Originally Posted by DCR2013 View Post
    Just to add to the ohm test for the wires, twist the wires to see if the ohms change. Sometimes wires get a bit of breakage enough to change this value, 10K to 12K resistance per foot is a good rule of thumb
    100+ Posts
    Jun 2022
    South Carolina
    There is no reason to mess with the spark plugs or wires as long as the engine is running good.
    These days the only reason I replace spark plugs at a certain interval is so that they do not get stuck in the cylinder head.
    There are a lot of gimmick spark plugs out there, but none are better than the ones that came in the bike originally.
    I like to replace them at 30K, just so they don`t become embedded in the cylinder head.
    No anti seize needed, all modern plugs already have a sacrificial coating on the threads for that purpose.
    The service manuals now state clean and dry threads for spark plugs.
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  1. spark plugs
    By DJS in forum Honda Trikes
    Last Post: 06-03-2012, 04:26 PM
  2. spark plugs
    By geraldlanc in forum General Discussion
    Last Post: 03-24-2012, 09:03 AM
  3. Spark Plugs
    By drumdoctor in forum Home Built Trikes
    Last Post: 09-21-2011, 03:19 PM
  4. Spark plugs
    By John Luciano in forum General Discussion
    Last Post: 07-29-2010, 06:41 AM
  5. Check out these spark plugs
    By cjmitch in forum Honda Trikes
    Last Post: 03-19-2008, 11:51 AM
