Likes Likes:  1
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: Anyone using a car rim on the front of a trike?
    90+ Posts
    Edwardsville, IL USA
    Default Anyone using a car rim on the front of a trike?
    If you are, what are you using for axle, hub, brake disc and caliper?
    Any type of wheel spacer?
    Width of tire/rim?
    Pics?
    Thanks for the help.
    Quote Originally Posted by Eggman View Post
    Width of tire/rim?
    Pics?
    Just curious why would you want to use a car rim ..?
    90+ Posts
    I already have 4 rims. Would definitely be easier to carry one spare tire versus waiting on a tow truck to get me from the side of the road.
    Plus, I just like the look of a decent front end.
    750+ Posts
    Jan 2010
    east windsor ct
    plus you can run a car tire rather than a bike tire at about 1/3 the cost w way more mileage
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Thank you
    Bob
    90+ Posts
    No question as to where the beef is with that assembly. Basically, I'm looking for one a bit lighter than that.
    Sep 2014
    Moneta VA
    I had originally though of doing what you what to do and for the same reason.
    I decided to go to something different (see link) https://www.triketalk.com/forum/thre...r-trike/page39
    Could you adapt the setup in my last post to what I did in the above link
    Thank you
    Bob
    90+ Posts
    I did get a few things figured out, just have to go back to O'Reilly's and change out either the caliper or the rotor.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default front
Size:  231.8 KBhere is one to study!
    4750+ Posts
    Mar 2015
    Texas
    Quote Originally Posted by Fowler View Post
    Do you know what happened to that build? Thread just died. I was just wondering about the angle of the driveline. I had a 77 Blazer that had a fair amount of angle and I was putting u-joints in that thing almost dead on every 18k miles. And that was no matter how often I greased them. I put 3 sets in and then sold it before needing the 4th. I don't know if it was the angle or something else but it eat u-joints.
    American Legion Rider
    90+ Posts
    How was your pinion angle versus your transmission output shaft angle? They need to be equal and opposite. Or you can always rotate the rear pinioni to point at the transmission and use a cardan joint.
    90+ Posts
    Quote Originally Posted by LarryA View Post
    Damn!! That's a lot of aluminum!!
    750+ Posts
    Jan 2010
    east windsor ct
    also the ends of the shaft need to be timed
    90+ Posts
    After several trips around the block with the all-terrain tire on the front, I've decided that it's not for me. Makes the front end way too heavy to steer comfortably.
    Looking at an MC tire... https://www.bikebandit.com/tires-tub...0444?b=2812235
    I've read that when running double dark on a motorcycle, with a rear tire on the front, it's ran backwards to the arrow. With running it on the front of a trike, would it be ran backwards as well? Or forward?
    Thanks.
    3022
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Using a car tire on the front
    By glenn m in forum Yamaha Trikes
    Last Post: 10-15-2018, 06:32 PM
  3. Car Tire on a Harley 16" Front Rim
    Last Post: 05-01-2015, 12:09 PM
  4. rim fire anyone?
    By wiredgeorge in forum The Gun Enthusiast
    Last Post: 01-23-2014, 12:37 AM
  5. Anyone know how to get a chrome front rim?
    By Boscoporp in forum Honda Trikes
    Last Post: 07-31-2011, 07:05 PM
