ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  1
Results 1 to 5 of 5
Thread: Belt adjustment
    Feb 2008
    Shippensburg, Pa
    Default Belt adjustment
    Just have a quick guestion. I'm assuming most bikes in this section are belt diven. How often does the belt need adjusted. And how long does one normally last on a trike.
    Thinking of getting a kawasaki vaquero but I've never had a belt driven bike.
    Jan 2019
    Alexandria
    Quote Originally Posted by 3W-lonerider View Post
    Typically one should expect to get approximately 40,000 miles out of a belt. Though I am not familiar with Kawasaki's recommended service on them, I believe 40k is considered the point in which belts are recommended to be changed. Far better than chains at any rate. As for adjustment, they will usually require the initial adjustment and then another within a relatively short time afterwards. From that point they may not ever need readjustment until replaced or you have to remove them for servicing of other equipment. Again, significantly less service than a chain.
    Feb 2008
    Shippensburg, Pa
    Quote Originally Posted by SmartAceWoLf View Post
    do the pulleys need replaced to. i know the sprockets, on a chain drive do. but i haven't had a chain drive since the early 80's. iv'e had a shaft drive bike for over 25 years. so anything you can say to enlighten me i'd appreciate it.
    In a word NO, check the pulleys with a fingernail for any sharp edges
    Look at the wear pattern on the pulleys
    Feb 2008
    Shippensburg, Pa
    ok, thank you for your time and assistance
  1. Belt adjustment.
    By sandrooney in forum Harley Trike Conversions
    Last Post: 06-19-2014, 05:19 AM
  2. Torques for belt adjustment.
    Last Post: 06-17-2014, 07:55 PM
  3. Belt Adjustment on Road Star Trike
    Last Post: 02-22-2014, 08:10 AM
  4. Lift brackets- drive belt adjustment
    By jimdog1356 in forum Harley Tri Glide
    Last Post: 03-22-2012, 09:16 AM
  5. Primary drive belt adjustment
    By jkchipster in forum General Discussion
    Last Post: 02-05-2012, 03:14 PM
