Likes Likes:  1
Results 1 to 7 of 7
Thread: Clutch Advise
    20+ Posts Mek5o's Avatar
    Apr 2019
    Cheltenham
    Default Clutch Advise
    Having issues with clutch wear on a 2011 L1200L converted with Lehman raider trike kit, Replaced once with extra plate Kevlar kit once already Starting to slip again any suggestions ?
    Clutch slippage is a combination of problems
    Worn/ weak parts and incorrect adjustment leads to faster wear and premature release/or incomplete release causing ride problems and accelerated wear
    I would first do a good clutch adjustment ( by the book) on a cold engine
    Apr 2019
    Cheltenham
    Default Thanks
    Yeah I did redo the adjustment today. It feels better fluid little dark Lol ! Just wondering if I should change out the type ? But I guess it's just one of those things where you live, ride and learn as you go !
    Quote Originally Posted by Mek5o View Post
    So what do you use in the primary?
    Do you use the correct level? This makes a huge difference on how the clutch can drag and or slip
    Apr 2019
    Cheltenham
    Had been using Formula + , I just tried redline light weight shockproof gear oil. I like the feel after the change.
    I do try to make sure it's correct. just a tad less then a quart.
    Does your extra plate set up use a newer improved pressure plate ( diaphragm spring )
    Apr 2019
    Cheltenham
    No just stock.
  1. V Trike Cruiser Clutch or clutch adjustment?
    By KeithK in forum Roadsmith Trikes
    Owners Forum
    Last Post: 03-25-2019, 12:23 PM
  2. Replies: 6
    Last Post: 10-31-2017, 12:55 PM
  3. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  4. Rekluse clutch vs EFM auto clutch
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-28-2016, 09:11 AM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
