Sunman5rhino 2Honda TrikesF1 Warning Light
Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai4rhino 2New Member Introduct...New member from Texas
Bonsai4GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai4trike ladyNew Member Introduct...New member from Texas
Bonsai4BonsaiNew Member Introduct...New member from Texas
Sunman5BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Gorilla2Jack KlarichEnabled TrikersFull length floorboards
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  36
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
Thread: Stock Air Box Back On Re-Did, Re-Rout EBS Catch Can Set Up
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    Default Stock Air Box Back On Re-Did, Re-Rout EBS Catch Can Set Up
    I installed the Stock Air Box back on our 2017 trike today. I also re-installed the (EBS) catch can set up I had previously used. I decided to re-rout it out of the air box and re-rout it under the frame.
    I think it turned out well. I had to make a clamp and mount it to the existing exhaust clamp (see pic hose running through clamp).
    I had to drill a small hole in the stock air boxs bottom for the hose to exit and rout the path of the hose not to touch anything and not to get melted.
    Ride Safe All,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Sorry your stage 1 air cleaner didn't work out for you, surprised you didn't take it the dealer for a download
    All for now Trampas
    Mar 2015
    Quote Originally Posted by Trampas View Post
    All for now Trampas
    Trampas,
    My 2017 trike runs very well stock. For me the stage 1 was about looks and an experiment. My bubbly will buy the stage 1 from me for what I paid for it. He builds high end hot rod Harley motors at his engine shop.
    On the 2017 models with the 107 M8 there is no more downloads like on previous years. You have to now buy the HD Screaman Eagle EPA legal street tuner or an aftermarket tuner to tune the 2017 M8 engines.
    I did not want to spend $300.00 to $400.00 dollars to get that little extra. As said I find the 2017 trike with the 107 M8 to run just fine stock plenty of power.
    Also I can live with the looks of the stock air box. Plus I can now use my catch can mod.
    Ride Safe My Friend,
    Bill G
    1000+ Posts
    Aug 2016
    Des Moines IA US
    You would have to buy a aftermarket tuner since the HD one is not for triglide, I looked it up one time when I was talking to the service department and they mention that one from harley. I looked at online and it does not show any triglide at one, everything is all 2 wheelers and even the CVO's. I called harley up and they said it is not recongnize by harley for triglides, I ask him why not and he could not answer it, go figure.
    All for now Trampas
    gerald martin
    Guest
    Default EBS
    I see that your hoses run up and over the air cleaner. You may have trouble with that as there may not be enough pressure to push the oil up and it may block off your air flow. I had that trouble with my freewheeler until I routed the hoses to all flow downward.
    Mar 2015
    Quote Originally Posted by gerald martin View Post
    Thanks for your feed back,
    The factory hoses ran the same way over the filter. I had this same set up on my previous mod on this 2017 with no issues before I moved the catch can further down to the frame.
    I have seen simular mods done by others. It seems to work just fine, it is really just a vent. I don't think pressure plays to much into it functioning correctly as a vent.
    Also the 107 M8 vents to two diffrent places. Another vent goes to a space in the crankcase. Previous year Harley motors did not do this.
    What year was your Freewheeler??
    Time will tell.
    Ride Safe,
    Bill G
    Mar 2015
    All for now Trampas
    Thats is news to me and you may be correct. My dealer tells a diffrent story. I talked to them about it just before I did my testing on the stage 1 without a tune being done.
    Ride Safe,
    Bill G
    Mar 2015
    Gerald,
    The more I thought about it it made me think why take a chance. So I re-did the lines to go low it was easy enough to do. Why take a chance that it will be an issue on the road. It is just a vent so this way there should be no restriction at all.
    See pic's of re-rout to flow downward instead of over the filter.
    Thanks again for your feed back on this.
    Bill G
    gerald martin
    Guest
    Default vent
    Quote Originally Posted by Bill G View Post
    Gerald,
    Bill G
    looks good. you will have no problems now for sure.
  11. #10
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Looks like you had to drill another hole in air cleaner by the looks of it, basically I think this looks better and it won't have to go uphill so to speak
    All for now Trampas
  12. #11
    Mar 2015
    All for now Trampas
    Yes, I had to drill another hole but it is on the inside of the air box out of sight. The hose would not squeeze between the filter and the cover coming down the front side so the hole had to be done.
    It worked out well this way. The hole also serves as a guide and support for the hoses path. Also the hole does not affect the function or strength of the air box in anyway.
    Take Care Friend,
    Bill G
  13. #12
    40+ Posts
    Mar 2016
    Tehachapi, Ca, USA
    Thanks for this write-up. I have been considering the very same idea for my 2012 as I am running the stock air box with a K&N filter with the air box modified for increased air flow. Getting the oil vapor out of the air cleaner is a good idea and my ideas for an EBS are very close to what you did. Great pictures.
  14. #13
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool Bill G ?
    Gerald,
    Bill G
    Is this 3/8" fuel line you used for routing ? Looks like also 2- 90* elbows and a Tee ? Like this mod. I only have 100 miles on my 17 Tri with no oil yet showing in the filter area. I am surprised to see no drain hole in the plastic filter housing ,looks like water would puddle there. Thanks Doc
  15. #14
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool
    Pulled the stock nipple, I see it is 1/4" Sorry.
  16. #15
    Mar 2015
    Quote Originally Posted by hddocfl View Post
    Doc,
    The tubing is 1/4" I believe. It is some tubing I had laying around from some smog stuff that was removed from a duel sport a few years back. Yes two 90 and a T, also some spring clips.
    The tubing needs to fit tight that's why I used the spring clips. When you change the venting from positive pressure to negative pressure with the mod. Any loose fitting hoses will or could weep oil vapor.
    I bet if you remove your air filter and look in the throttle body you will see a small puddle of oil in it like in the pic below.
    Harley has routed the vapor back in this way for years and has worked to meet EPA requirements. I look at it like this, if you can remove the hot oily vapor from the throttle body without major mods, why not.
    If it was a major mod I would have left things alone but it's a pretty simple mod to do. It has has to be better for the motor taking the hot vapor out of the throttle body.
    The pic below is of my 2017 trike stock set up at around 800 miles or so. I got the catch can from DK Customs. It seems to be the right size.
    Ride Safe,
    Bill G
  17. DKCustoms postbit
  18. #16
    Mar 2015
    Correct 1/4" also there is a very small seem at the bottom of the stock air box. I don't think it is air tight.
    I suppose this could weep water out but how affective it would be is another thing. Yes, I agree in your other post a weep hole might be a good thing.
    The long run of tubing I used is thicker more heavy duty in size but was 1/4". It all fit nice and tight.
    Take Care,
    Bill G
  19. #17
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool Bill G
    Take Care,
    Bill G
    Thanks for the pictures and info on the breather. I still have no oil in the intake dry as a bone but I am doing your mod anyway and drill a weep hole in the air box. I have always vented the breather to ground in years past and it has worked out great for me , Never did it with the stock air box. I like what you did and am going to do it. Thanks Doc
  20. #18
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Take Care,
    Bill G
    OK I did your mod,
  21. #19
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool
    All 1/4" with barbs on the fittings . Will not come loose. I show a pic of the holes I drilled in the air box the smaller is for a drain may not be needed but hay I was in there
    , 1/2"hole for the 1/4" ID fuel line. Plugged the back of the paper filter were the stock line went in. All went well and $28 at Ace they had it all.3 ft of 1/4" fuel line 2 mini clamps 2 90* nipples 1 Tee all with barbs. Thanks Bill G.
    These new breathers do not breath as much as the twin cam going by what I felt before the hose install at the breather bolts now it is all out the hose to atmosphere.
  22. #20
    250+ Posts
    Nov 2012
    Bradenton, FL.
    One of the pics shows the hose of the front breather in front of the filter but it is in a notch ground into the plastic.
  1. Replies: 21
    Last Post: 03-21-2017, 07:45 PM
  2. Replies: 6
    Last Post: 01-14-2017, 02:31 AM
  3. Stock Mufflers Back On Freewheeler And I Am Ok With That
    Last Post: 06-29-2016, 06:45 PM
  4. Wards Parts Werks FCS back in stock!
    By MDF48 in forum Harley Tri Glide
    Last Post: 06-29-2016, 08:04 AM
  5. Stock air filter back on....
    By krooozn in forum Honda Trikes
    Last Post: 05-16-2011, 11:58 AM
