Likes Likes:  7
Thanks Thanks:  2
Results 1 to 5 of 5
Thread: Homemade Harley Passing Lamp Socket
    Default Homemade Harley Passing Lamp Socket
    Cut a 9/16th deep socket down with a dremel tool like in this picture
    Now you can adjust and or tighten your Harley passing lamps without having to cut the wires or pay to have it done
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Good idea. Made the tool to adjust the passing lamps I just bought off Ebay.Got an 02 Police Electra Glide mounting bracket with passing lamps and signal lamps.Really nice shape. Removed signal lamps. Mounted right up. Gonna run it unwired for awhile to see if I like the look.
    Ok wiring- the manuals are valuable for this. If you remove the LH signal lamp nacelle panel (remove two acorn nuts) you will see the signal lamp connector. #31 male/ female.This is a 6 pin Tyco 070 multilock unsealed connector.To BCM all 6 pins have wires.From that connector to signal lamps are only three wires.Position 5&6 on the signal side are empty. On the BCM side 5&6 have blue/black wires connected.
    This is your auxiliary lamp Power.You can buy harness pn#69201108 from Harley and youre all set- almost.But I'm thinking I'll just crimp some molex pins or sockets and run wires in position 5&6 and get power that way. Now for the switch. This is HD pn: 71522-08. It's a toggle switch and HD is very proud of it.
    I can make up a toggle switch and run leads to #109 which is the connector to power for the switch, a 4 pin Tyco mate-n lock unsealed.You may be able to see this connector by shinning a light up the underside of the tank.I was able to pull it from the caddy. It looks like a white molex 4 pin. But like I said this is far as I'm going to see if I like the look.
    60+ Posts
    Feb 2023
    Southport NC USA
    Just asking as I haven't a clue. Would it be possible to simply splice the passing lamp power wire to the turn signal power? No switch required and clearly with both turn signals and passing lamps being LED...the amount of current drawn would be minimal. As I stated...just asking. Not an electrical engineer...nor an engineer of any sort or description.
    Quote Originally Posted by SouthportFLRT View Post
    These I like better than splice and butt connectors
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Your property do it anyway you want. HD already provides for the proper way to do it. Its simple. Adding the switch which is controlled by the BCM allows the passing lamps to turn off when you hit the highbeam switch.
  1. ***Save 10% on DK Custom Products LED Passing Lamp Bulbs***
    By DK Custom Products in forum DK Custom Products
    Last Post: 06-03-2015, 04:54 PM
  2. Fairing power socket
    By danield in forum Honda Trikes
    Last Post: 04-29-2013, 01:53 PM
  3. Honda Steering Stem Socket
    By Woolie in forum Honda Trikes
    Last Post: 01-13-2013, 12:05 PM
  4. Kuryakan Total Contol Passing Lamp Harness
    By TriGeezer in forum Harley Trike Conversions
    Last Post: 08-27-2012, 09:06 AM
