ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie9ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie9ol' schoolNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie9SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie9Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie9LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  16
Thanks Thanks:  1
Results 1 to 20 of 38
Thread: TriGlide rear wheels
    Default TriGlide rear wheels
    As most of you know,TriGlide rear wheels are a 15x5.5 size. I'm trying to figure out if a 6" wide wheel will fit. If so,that would really open up wheel selection for them and the Freewheeler. It would be much appreciated if someone could give me some measurements from the outer tire sidewall to the inside edge of the fender lip and from the inside tire sidewall to the inside of the fenderwell.
    Putting your TG on a lift to get these measurements would be even better but I'll take what numbers I can get,right now.
    Thanks again.
    Oct 2010
    USA
    I am going to say no as it is tight in there now just to get the wheels off the bike..Shorter yes - wider no..
    So,you have already measured it and know this for a fact? Or,are you just guessing? Going from a 5.5" width to a 6" will make very little difference in the tire's section width. You do know this,right?
    Let's quit guessing and figure it out for sure,ok?
    My Harley dealer had a new TriGlide on the showroom a few days ago so I just rode the five miles over there to see if I could get some measurements. Nope,they already sold it! It was only on their floor for two days and they didn't have another TG or a FW on the premises.
    Back to the drawing board.
    Apr 2015
    wichita falls tx usa
    Clint, looks like the outside clearance is 1 inch and the inside about 3/4 inch. Don't have a lift but those are close measurements
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    Looks tight to me...
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
    250+ Posts BOXX3R's Avatar
    Jul 2015
    Huntington Beach, Ca
    Clint...I can confirm that there is 1' between the inside of outer part of the fender and the tire wall, and about 3/4" of clearance on the inside.
    "HOW we ride today, may determine IF we can ride tomorrow"
    Oct 2010
    USA
    Quote Originally Posted by Clint44 View Post
    Have fun..No guessing on my part.. Have you ever taken off the rear wheels on the TRIGLIDE yet? Its tight enough now and you want to add a half an inch to the width..Good luck with out some sort of mods..
    I guarantee it is not as hard as removing the rears on a Boss Hoss trike so what's your point? They require completely deflating the tire,then unbolting the shock mounts so you can drop the rear end down. Only then can you get the wheel & tire out from under the body.
    Going to a 6" wheel would add 1/4" to each side. The tire is the widest point and we're not changing the tire size. From other responses to this thread,it sounds like a 6" wide rim will easily fit w/o clearance issues. Just need to crunch some numbers and figure out the back spacing needed. Thanks for your measurements,guys.
  11. #10
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Your reasoning might be solid, providing you can get a wheel that does the 1/4" each way with the correct offset.
    I've even thought of buying extra rear fenders & do a wide fender just to clear the tire, but that is some major work ! The other option is find a fender that is wider that you can adapt to the bolt pattern on the trunk.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  12. #11
    Quote Originally Posted by Sloufoot View Post
    Many wheel manufacturers offer a 6" width in a two-piece wheel so getting a custom backspace is not a problem,at all. For example,American Racing's TorqThrust II is a two-piece wheel and custom backspacing can be ordered in 1/8" increments. TriGlide and Freewheeler rear wheels are a slight negative -9 offset (more dish) which us old-school hotrodders like. Hannigan,Roadsmith,and CSC all use a high positive offset rear wheels (very little dish) that were originally designed for front wheel drive cars. The 15x5.5 Harley wheels have 2.85" backspacing while the 17x7 Intro wheels on our Transformer have 5.7" backspacing (+40 offset)
    Wider rear fenders are just not an option,IMO.
  13. #12
    Stock 15x5.5 TG and FW rear wheels have 2.83" of backspacing so a 6" wheel with 3" backspace should fit fine. As for tire sizing,I would stay with a 205 as there is a huge tire selection in that width.
    Just curious but what's the drill for R&R'ing the rear wheels and tires?
  14. #13
    Jul 2012
    Chubbuck Idaho
    Just to be exact for everyone's information on measuring their wheels:
  15. #14
    Thanks for posting those graphs,Sloufoot. This stuff may seem overly technical but it's really pretty simple once you get the hang of it.
    Just for info but an advertised 5.5" wheel is measured from tire bead to tire bead. It would measure 5.5" but actual wheel width is measured from outside edge to outside edge of the rim. That advertised 5.5" wide wheel is actually 6.5" wide.
  16. #15
    Aug 2015
    ft worth
    Cool
    The 5x5 1/2 is a ford truck bolt pattern, or ford van. I at one time would never have contemplated doing to the trike what i now don't hesitate to do, cut the opening with whatevers handy, and make it work, to pull the wheel, kinda like on my 55, jus pull it, no drop no unbolt shocks and all the drama.
    Don't forget you can add a lip to the fender if ya wish, either aftermarket off road, or home made, after cutting it out you can dress it up a little, choices.
    On one trike i built i used softail fenders widened, and on a pivot, pull the rear bolt, tilt the fender to the front and pull the wheel, which was a 20in Harley truck wheel, it was trick. pics on a crashed pc of course.
    Tape it off cut it out, to a pleasant size and pull your wheel, or install, I like a little more than a little less to get what i need done. Surely others must protest the procedure, best to ya.
    Name:  1955 chevy drivers side view.jpg
  17. DKCustoms postbit
  18. #16
    Quote Originally Posted by Downtown Cowtown View Post
    TriGlides and Freewheelers use a 4 lug, 4.25" bolt circle wheel that is 15" diameter by 5.5" wide.
    Bolt circle can also be expressed as 4x108mm.
  19. #17
    Aug 2015
    ft worth
    Cool
    sounds like an outdated falcon comet wheel lug pattern. Needs to be 8 or 10 inch wide get some meat on the ground.
    Buy some adapaters, make it 5 maybe and pull the fenders and have some made and put 8 or 10inchers on the back, now the cookie cutter look is going going gone.
    Run some tomb stones on the fenders led of course. Make these bikes to your desire, not the moco, after the warranty issue expires i guess.
  20. #18
    Jul 2012
    Chubbuck Idaho
    If you put a tire on the rear that wide it must be for looks only. You couldn't hardly move in snow or even heavy rain. The rear end would be all over the place.
  21. #19
    Aug 2015
    ft worth
    Cool
    Ive done it without issue, but thats me. As for looks, oh yeah. You get too wide in the back it pushes the trike in the corners.
    Ive got 8 or 10s on my shovel trike and never had a problem, even up pikes peak. Funny thing is Ive had the same tires on it since 77. Not much weight on them, and i used to run 12lbs air.
    Ive built probably 6 trikes and designed a swing arm in 82 that many have copied since, older motor trike is similar to my design.
    Ran the first disc brakes on the rear of a Harley trike rear end that i or anyone else had ever seen, and designed a sprocket kit to put a 51T on a Harley rear end designed for 37 tooth, funny you look at Frankenstein and you see what i sketched out in 82 and still have the paperwork.
    Im not new to the process, but i retain an open mind, so i think, as for the rear wheels Ive never ridden a tri glide or a v rod, the more i ride my street glide i think of triking it, and the more i ride it i get tired of the heat.
    So Ive been eyeballing v rods, mmm, put that engine in an extra touring Harley i have on the table, mmm, anyone ever seen that ?
    Ride safe i value and respect your opine, and keep the rubberside down.
    You close to mountain home ? My uncle died there in a training plane crash B-17 WWII.
    My dad was the gunnery instructor there at that time, until he shipped out for 50 missions from north Africa into the belly of the beast. Germany.
  22. #20
    Jul 2012
    Chubbuck Idaho
    There was someone doing an engine swap on the Tri with the V-rod engines. He was in Florida somewhere. I can't find the web site anymore.
    Here in Pocatello, which Chubbuck is right beside, is the base they flew the B-17's & B-29's among others out of during the war. Our airport used to be the biggest in the state. They are still using the same strips as in WW2. Just a bit of rebuilding a couple years ago.
    Now the Salt Lake airport uses the strips for training their commercial pilots with their jets doing touch & goes. We have had a lot of problems keeping Jet service here because of loading $$$ ! We are up to 2 flights a day (jet) HA !
    We are about 160mi from Mountain Home. That is now the main AFB in Idaho. They still have the range there.
  1. TriGlide Rear Wheels Specs
    By myxcape in forum Harley Tri Glide
    Last Post: 02-22-2015, 08:44 AM
  2. TriGlide Chrome wheels...
    By Trent in forum Harley Tri Glide
    Last Post: 04-07-2014, 08:11 AM
  3. 09 TriGlide Chromed Wheels
    By lzski326 in forum Harley Tri Glide
    Last Post: 03-02-2010, 08:54 PM
