Likes Likes:  5
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: Renegade Roadking
    60+ Posts
    Apr 2017
    Sunbury
    Default Renegade Roadking
    My harley roadking with renegade trike kit has always seemed to sit low at rear. Factory air shocks on it. Kit has been installed about 10 years. We have owned it last 6 years. Seems mufflers get smashed a little more every year. Any thoughts on correcting and maybe improving ride. It is a solid axle.
    Quote Originally Posted by Redharley View Post
    Yep switch to coil over shocks. See DK Custom this forum ads. They sell a couple of different ones. They can be pricey but it will solve your issue.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Bill,
    May I suggest you measure your air shocks to see if they are the correct length.
    Should be 13" from center of each eye.
    Conversions were usually done utilizing existing shocks.
    If the motorcycle had been lowered at some time prior to the conversion, it may have shorter shocks.
    Shorter shocks mean a shorter spring and a harsher ride.
    Jim Murphy
    Iron Butt Rider 2001
    60+ Posts
    Apr 2017
    Sunbury
    Thanks for the info Lee. I'll measure them does it matter if on or must they be off for that eye to eye measurement.
    60+ Posts
    Apr 2017
    Sunbury
    Also would you recommend one replacement over the other. my wife is the driver of this unit she is on the smaller size maybe 125lbs. Thanks
    Martinsburg, WV
    Cool
    Un compressed
    Jim Murphy
    60+ Posts
    Apr 2017
    Sunbury
    Un compressed
    Found this road king was a classic which came with shorter air shocks 12.5" would you suggest I just install 13" or could I go with even longer. I see most are going 14 on triglides. Would 15" be a possibility. Bill
    Martinsburg, WV
    Cool
    If you create too much travel (15") you start having belt issues.
    Air shocks (H-D) should be set at 15# to start and if a 13 1/2" or even a 14" can be found, use that.
    Rear Tire pressure also be set at 20#.
    The rear swingarm is designed with limited travel and will bind on the transmission case if too much travel is introduced.
    Jim Murphy
    60+ Posts
    Apr 2017
    Sunbury
    Thanks for that info. Appreciate your reply. Bill
    60+ Posts
    Apr 2017
    Sunbury
    Again Thanks for your help , have installed a set of Ikon basic shocks (old Koni company) . They were built to wifes weight , very pleased made a world of difference.
  1. unused RoadKing exhaust???
    By DblTrbl in forum General Discussion
    Last Post: 06-07-2016, 12:07 AM
  2. Sissy bar for Roadking Champion trike
    By roadking2 in forum Champion Trike
    Last Post: 12-12-2013, 06:40 PM
  3. Roadking dumb question
    By Pittsburgh Biker in forum Harley Trike Conversions
    Last Post: 04-13-2013, 09:16 PM
  4. Has anyone converted there roadking, using Santiago Chopper kit?
    By HogGoneWild in forum Harley Trike Conversions
    Last Post: 06-03-2012, 12:40 PM
  5. Renegade Trikes
    By aminal in forum Other Brands Trikes
    Last Post: 09-23-2010, 09:27 PM
