Likes Likes:  1
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: motor trike rear end problem
    Feb 2020
    Mesquite
    Default motor trike rear end problem
    I have a Motor Trike kit on my 2001 Electra Glide. I converted it to a chain drive because I've broken 2 belts in the past year. I do all of my work myself so I've taken it apart several times before. However, after replacing the sprocket and getting the bike put back together, I went to do the test ride and the bike would not move. Chain is turning the rear sprocket but the wheels will not move. I'm certain I stabbed the axles properly and have them seated. Any ideals of what the problem could be? Rear wheels are just free spinning. Any help would be appreciated. Not looking forward to taking this thing apart again without any ideal of what the problem could be.
    Quote Originally Posted by Big Hustla View Post
    Cliff......Welcome to Trike-Talk..........I can't help much with the problem, But if i recall right there was a thread on the same problem....Maybe someone will chime in with a better memory than mine ..And give you a link to it....
    cliff welcome
    Found the tread........Titled..; Freewheeler won't move.....Posted 12/23/19...
    Maybe it will give you an idea.....
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hi Cliff! No help as to the problem - just want to welcome you to TrikeTalk from the Texas Hill Country! I hope you get the problem resolved soon.
    And if you are in Mesquite, TEXAS - come on down to Kerrville to our TrikeTalk meet and greet April 19-23. See the thread: KERRVILLE 2020
    750+ Posts
    Jan 2010
    east windsor ct
    with the bike off the ground and in gear... spin one wheel does the other go the opposite direction??
    750+ Posts
    Jan 2010
    east windsor ct
    i went looking for this thread and didnt find it.. perhaps you could copy the address and post it??
    Here https://www.triketalk.com/forum/thre...eewheeler+move
  1. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  2. Motor trike rear end locked up on interstate!
    By Chappy KC in forum General Discussion
    Last Post: 07-15-2015, 09:54 PM
  3. Motor Trike rear end noise!!!
    By iowatree in forum Motor Trike
    Last Post: 06-03-2015, 10:12 AM
  4. Bad bearing in Motor Trike rear end.
    By sandrooney in forum Motor Trike
    Last Post: 07-08-2012, 06:31 PM
  5. Motor Trike Rear end Question
    By Paul_Trike in forum Honda Trikes
    Last Post: 03-19-2012, 09:49 PM
Tags for this Thread
