Results 1 to 16 of 16
Thread: Transmission Oil
    900+ Posts
    Bellville, Texas, USA
    Default Transmission Oil
    It is time to change oil in the transmission. Here in Texas it is pretty hot most of the year. Is 75/90 good or should I go to 85/140 weight oil? To me it seems the 85/140 heavier oil would be better but I would appreciate some input from others. In any case I want to use real transmission oil and not Syn3. Just not sure about the weight.
    Thanks,
    Sunman
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I'm in PA and use Bel-Ray 85W-140 all year round. Red Line is another great choice.
    Bob
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Eions ago, 80s-90s, the tranis made wining noises or just plain noise. Along with 80-90 gear oil, we added Wynns gear additive or Slick 50.
    With today's trans you don't need additivesbue to better gear mesh, tolerances ect. So as long as it gets lube, it's happy. Personaly I am a gear oil person also.
    Its all gears! 🔃
    30+ Posts
    Mar 2016
    Wytheville, Va. USA
    New to the trike world! At what mileage should you change your transmission oil? Mine now has roughly 15K on it. Thanks to all who share an opinion or can tell me what Honda recommends! Thanks, Rick
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by ricksurratt2 View Post
    Your profile shows you have a 08 Honda GL1800 Goldwing/ Hannigan Trike Kit. If you are asking about it and not a Harley:
    You now have 15K on the engine oil as Gold Wing trannys share the same oil the engine uses.
    Don't want to start another oil thread but must say I have had the absolute smoothest shifts up and down since I started using Mobile 1 T4 for motorcycles
    If you are asking about a Harley, when I owned mine, I used Syn3 in all 3 places and was very satisfied.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    [QUOTE=Sunman;392271]It is time to change oil in the transmission. Here in Texas it is pretty hot most of the year. Is 75/90 good or should I go to 85/140 weight oil? To me it seems the 85/140 heavier oil would be better but I would appreciate some input from others. In any case I want to use real transmission oil and not Syn3.
    Thanks,
    Sunman[/QUOTE
    Try Bel-Ray 75-140 Hot or cold it shifts good
    Quote Originally Posted by Sunman View Post
    Thanks,
    Sunman
    Try Bel Ray 75-140
    Thanks,
    Sunman
    Try BelRay 75-145 Hot or Cold works good here in Fla
    Thanks,
    Sunman
    I use Bel Ray 75-145 here in Fla
    900+ Posts
    Thanks for all of the replies! Looks like I will be changing to 85/140. Now if I can just find Redline around here some place. Used to run it in my other Harleys but don't remember what weight it was. Also, local source for it is no longer here. May have to drive into Houston.
    Sunman
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Used to be we used Redline Heavy Shockproof in the trans. They advertise it as having film thickness of 75W250 but fluid friction like 75/90.
    Now Redline has a "VTwin" heavy shockproof oil for trans that is rated at 90W.
    I've found the best prices, and ease of not driving around looking for it, to be ordering it off the internet. 5 minutes on ebay and you can find someone with it on sale at good prices.
    www.DKCustom.com
    900+ Posts
    Thanks Kevin. Will check it out.
    Sunman
  11. #10
    Redline is Good but spendy IMO it does work good tho
  12. #11
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Here's another vote for Redline, my dealership carries it so it makes it very convenient.
  13. #12
    4750+ Posts
    Mar 2015
    Texas
    Redline was what I ran in mine as well. It seemed to do a very good job and I think it could go much longer between changes but stayed with the recommended just in case. Know what I mean???
    American Legion Rider
  14. #13
    Jul 2014
    S.E. PA, USA
    I change the tranny oil every 10,000 miles. I do Primary and engine oil every 5,000 miles.
    Bob
  15. #14
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Very seldom does one get something that works the best that is cheap also. Redline works quite well, also Bel-Ray. But I also must put Amsoil Harley transmission fluid here also. They also now have a primary oil for Harley.
    Using the best oil in both areas makes a big difference in noise & shifting, & wear.
    I look at it like what Harley recommends, Harley also sells. Also they aren't in the lubrication business, they are in the parts business though......
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  16. #15
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I have used Amsoil 75-140 all year long.
    The dealer recommended and put Bel Ray in my Ultra once back in 04 when I had a 6 speed put in. It was awful.
    IBA#61162
    PATRIOT GUARD
    USMC
  17. DKCustoms postbit
  18. #16
    20+ Posts
    Dec 2015
    San antonio,tx
    Amsoil sells a good Transmission oil. It works for me. Its quite and easy to fine neutral, and doesn't make that Harley first gear clonk to loud. Shift gears easy. Its pricey but according to the owners manual the next change is 20 k miles. However Redline is very popular with most riders. enjoy the ride and good luck in your choice.
    grunt67
  1. Transmission oil
    By greyfang in forum Harley Tri Glide
    Last Post: 08-28-2016, 09:50 AM
  2. Looks like I need to buy a VW transmission....
    By werewolf in forum VW Powered Trikes
    Last Post: 04-20-2014, 11:38 PM
  3. HD Transmission
    By ymxbgnf in forum Harley Trike Conversions
    Last Post: 02-24-2014, 09:22 AM
  4. Transmission
    By 07BlueCSC in forum Honda Trikes
    Last Post: 10-09-2011, 06:48 PM
