Likes Likes:  10
Thanks Thanks:  4
Results 1 to 13 of 13
Thread: Hard steering.
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Hard steering.
    I'm sure you all have been asked this I just returned from Lonestar rally on my 2001 Road King converted to trike. Great rally..had a great time. The ride on this great..I truly like it. The steering is stiff as @#$%! And of course the wobble isn't fun either. Please tell me more on this Zook easy strategy? What dampener is best? Thanks to all.
    Quote Originally Posted by Clevelandpat View Post
    First thing I would check is the steering head bearing it should be tighten down more than the two wheeler and then go from there…
    Patrick, I would suggest you get a hold of Randy (owner of the Forum and Cut N Shoot Customs)
    He is a straight shooter on the EZ Steer and has been building custom Trikes for a long time
    http://www.cutnshootcustoms.com/
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Steering head
    That was checked and we did tighten but no change. Thanks.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Patrick, I would suggest you get a hold of Randy ( owner of the Forum and Cut N Shoot Customs)
    Agreed Patrick! That is whom you should turn to. Randy will "steer" you in the right direction.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Patrick… Randy is your neighbor in Conroe… give him a call… he will steer you right!
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Default The answer is 17.2 miles away
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    The answer is his Rake Kit. He did mine this summer on our way West. Does away with the damper. Steers great after install. I rode down to his shop from Ohio, surely you can make it from Cleveland ,Tx lolol. Best improvement for me..
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Cutnshoot
    I did contact Randy and he's going to contact me today. Was traveling. He states he has a fix for it. Another small issue I forgot to ask it this kit I installed takes a different style side cover or battery covers. I am told a street glide or Roadglide panel fits right on it. Anyone have any Advise? Thanks!
  11. #10
    60+ Posts Mavigogun's Avatar
    Feb 2022
    Houston, Progressive Texas
    ”Great” relative to trike steering in general, right? It’s still a bear to arm wrestle on the twisties, yes? (The added rake doesn’t ease steering force requirements, does it?)
  12. #11
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by Mavigogun View Post
    Steers so much easier even on the twisties. MAJOR difference. Wish I had it from day of purchase on the new trike.
  13. #12
    Feb 2022
    I’ve heard rake mods ranging from 3-7 degrees; what do you recommend? (What do you reckon your pre and post mod rake angle to be?). I suppose ground clearance must have reduced, presuming the same forks are used- is that the case?
  14. #13
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Ground seems the same. Steering 100% better. Go over to Randy's shop North side of Houston & talk to him. I forget the degree it is now. Stock forks are used. I rode down from Ohio & had Randy install for me. Then we started our 5k trip from there. Going down after 250-300 miles, shoulder was killing me (had surgery on it in Nov of 20) .We left on trip after Randy did the install & were running 350-400 a day & still fell good. No more shoulder discomfort. We ride all US & state routes so it takes us a bit longer to cover the miles. i was glad I had Randy do the install Took it in one morning & had it back later the same day.
  1. Freewheeler Steering vs Tri Glide Steering
    By POPSHD in forum Harley Tri Glide
    Last Post: 01-08-2020, 09:45 AM
  2. new tri-glide hard to steer??
    By jackf1950 in forum Harley Tri Glide
    Last Post: 02-02-2012, 02:01 PM
  3. The ride's too hard
    By gareth323 in forum General Discussion
    Last Post: 07-20-2010, 03:49 PM
  4. having a hard time resizing
    By Vern & Kathleen in forum Stallion Trikes
    Last Post: 06-07-2008, 08:13 AM
