Likes Likes:  29
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 42
Thread: Deflector Wings
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Default Deflector Wings
    I'd never been bothered by the buffeting coming over the tank ~ But now that I've moved to a Helmet state, it really is aggravating. So tell me the DK Deflectors are just the fix......Give me the thumbs up story and I'm in!
    Thanks - jc
    Dec 2013
    Clarion PA USA
    Default I have them and will not give them up
    Now I lifted my tank 2" and put the first generation of air deflectors on, I tweaked mine because of the dragon fly adjustable wings on Old Shiney. It seems they really work for me between the air deflectors and tank lift.If I still smoked I believe I would be able to, going down the road. I'm sure the LRS flat top windshield also plays a part of air management, but still the air deflectors also push more air on the Motor and that is a good thing. Good luck in whatever you decide. travel safely Fred
    Apr 2015
    Thanks Fearless.....Do you feel the Tank lift helped the buffeting? I've thought about the tank lift, both front and back, but not sure how it effects the gas pickup......I think if I did the lift, both would be best, and I assume it's just a matter of bolt removal etc. jc
    50+ Posts
    Jul 2010
    silver lake kansas
    I put the DK deflector on years ago to kill the buffeting coming over the tank in the cold weather. I take the plexiglass part off in the summer and leave the metal mounting bracket on. I would give the effectiveness a A+. My trike is a 2010.
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by jc1300 View Post
    I get no bugs on my fuel tank if that tells you anything all go on deflectors and lowers the tank lift also helps increase air flow on motor do both lift and air deflectors. Run your tank low on fuel easier to maneuver (lighter less gas) simple remove seat and loosen back anchor bolts remove front tank bolts really loosen rear ones get the deluxe lift with spacers for rear. don't take them all out at one time one end or the other hard to control fuel tank by yourself. I used pine wood wedge to hold up tank, I was working by myself. Really easy little tight quarters on front but doable with common tools. Be safe Fred
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    I just put these and a 1.5 inch front and .5 inch rear tank lift on my Freewheeler this evening and I think I read where you have to have a tank lift for these to fit.
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Freewheeling Ron View Post
    You will love the difference in the air over the tank. DK Customs could answer the question about the lift and Air deflectors I lifted mine two years before the air deflectors were available. ride safe Fred
    400+ Posts Recall's Avatar
    Jul 2013
    Winfield, WV, U.S.A.
    I installed the deflectors and noticed a big difference/reduction in buffeting. I too have the deluxe tank lift, but it was installed about two years ago. I believe that even without the lift you will notice decreased buffeting. I think the tank lift with the deflectors wings will give better results and as stated help with cooling.
    Dave
    2015 Tri Glide - Hot Pearl White/Blue
    82 FXR
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Quote Originally Posted by Fearless View Post
    Wish I had seen these pictures before I installed my deflectors, then I would not have mounted them on the wrong side and had to take them off and swap sides
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  11. #10
    May 2017
    Ellicott City, MD USA
    Default Baker Air Wings
    Thanks - jc
    Had Baker Airwings for a long time.... Love 'em!
  12. #11
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    The Cooling Deflector Wings at this LINK, have a drop down menu choice, letting you choose which CDW you want...a pair for a Trike with a Tank Lift or a pair for a Trke without Tank Lift.
    Tank Lifts with the Deluxe Option do NOT impact the amount of usable fuel (fuel pickup). Below is a photo of me filling up on a TG with a 1.5" Tank Lift and a Deluxe option, as you can see, the entire 6 gallons is available.
    Tank Lifts reduce buffeting (and provide many other benefits), CDW's reduce buffeting (and provide better cooling).
    The two combined provide the most reduction in buffeting, And the most cooling of the engine.
    www.DKCustom.com
  13. #12
    Apr 2015
    Ok Kevin, I'm sold - I'll call you Monday and put an order together - Thanks all for the input - jc
  14. #13
    Dec 2013
    Clarion PA USA
    Believe me you will really l like the results. I do. Ride safe Fred
  15. #14
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Add me to the positive side! I did the 1.5" front tank lift and the deflectors at the same time. More wind down to the engine and less on me for sure.
    My recently installed LRS Flat top windshield made for even less helmet buffing.
    It is what it is.
    16 Tri Glide vivid black
  16. #15
    Apr 2015
    Sorry for the Delay Kevin ~ I did order the entire program {lol} this morning over the phone. Dwayne was very helpful and made the process smooth as silk. I'll let you know how it works out for me and the wife. Probably get tank lift and the deflectors on this weekend.
    Thanks for the help DK!
    jc
  17. DKCustoms postbit
  18. #16
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    jc
    Good to hear about Dwayne...he is good people, and an important part of the DK Team.
    Appreciate your business, and I hope you enjoy the parts on your Trike as much as I do on mine.
    www.DKCustom.com
  19. #17
    I have to say WOW Thanks DK, What a change and Peace of mind
  20. #18
    Apr 2015
    Default Oh well....the best laid plans
    Important Fitment Note: "Bikes with Batwings generally need to have the handlebars pushed pretty close to the fairing to acccomodate the tank lift"
    Stated pretty clearly on back page.....but ya don't know until you go thru the entire install to prove that statement correct. How are you guys making this work on the trike. I know I put taller bars on and pulled them to me to not have to bend over to turn.....disappointing....
  21. #19
    Dec 2013
    Clarion PA USA
    JC I'm not sure which bars you changed to but my 2+2 wide sweepers I have no clearance problems. I chose them in part for the convex shape everything works just fine. 2" lift no problem and I could bring them back a little if needed. I really wanted bagger bars or 14" apes but the way they were made I didn't think they would work being either concave or straight coming off riser. ride safely Fred
  22. #20
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yeah, that is a bummer about the clearance with your handlebars. The Tank Lift brings a lot of benefits, but sometimes it conflicts with certain handlebar adjustments. You can trade your CDW's to the version with no tank lift if you'd like. Just contact the shop on Monday.
    We get asked every day if xyz bike with abc handlebars will work with a tank lift. Unfortunately there is just no way for us to know, which is why we recommend, in the product description on the website, to check for clearance before ordering.
    IMPORTANT FITMENT NOTE:
    Please make sure this mod does not interfere with any other mods that have been done to your bike - like custom trees, handlebars, etc. You don't want to end up with a dented tank!
    We are NOT responsible for any damage done to your bike because of the kit.
    It is easy to check for clearance:
    1. With bike on kickstand, take the bolt out of the front of your tank.
    2. Loosen (do not remove) the bolt at the rear of your tank.
    3. Turn your handlebars all the way to the left and raise the tank up your desired lift height to check for clearance issues.
    4. Turn your handlebars all the way to the right and raise the tank up your desired lift height to check for clearance issues.
    Be careful when lifting your tank, you do not want to hit against something (forks, handlebars, trees, blinkers, etc.) when checking for clearance.
    www.DKCustom.com
  1. Replies: 34
    Last Post: 08-23-2023, 11:32 AM
  2. Lower wind deflector trike wings
    By refuelman in forum Honda Trikes
    Last Post: 02-22-2017, 07:46 AM
  3. DK Custom's Cooling Deflector Wings
    By 52edub in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-30-2016, 02:08 AM
  4. Wind Deflector on XXX
    By iaff84 in forum Harley Tri Glide
    Last Post: 03-12-2012, 06:06 PM
