gfaltersack3Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Likes Likes:  6
Thanks Thanks:  4
Results 1 to 13 of 13
Thread: Starter Relay Replacement
    Mar 2018
    California
    Default Starter Relay Replacement
    2005 Honda Goldwing with Champion Kit. I need to replace the A and B Starter Relays. I had done that previously on a 2004 and remember having to loosen the left saddle bag and remove the rear fender. Now having a trike I am faced with having to replace the relays on this. I still need to be able to access the back relay but there is no saddle bag to loosen or rear fender to remove.
    Has anyone had to replace the starter relays on a trike conversion?
    Suggestions would be appreciated.
    Thanks in advance.
    Quote Originally Posted by rfkurtz View Post
    Thanks in advance.
    Robert i can't help you on the relays......But I Can Welcome You To Trke-Talk...
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Robert, Welcome to Trike Talk from West Virginia.
    You will need to remove the left rear wheel and probably remove the reverse resistor to access the A & B solenoid. Be sure to secure them back into their rubber holders.
    Jim Murphy
    Iron Butt Rider 2001
    750+ Posts
    Jan 2010
    east windsor ct
    seems this may be a common problem??
    generally bike solenoid are small.. so any time there is an issue i replace them with a ford style https://www.amazon.com/Ford-SW3-Star.../dp/B004PKC1YO
    probably 1/4 the cost and twice the amp capability
    200+ Posts
    NC Triker's Avatar
    Jul 2012
    Supply, NC
    On my 2006 GL1800 with Motor Trike kit I replaced the A&B solenoids. I think I had to remove the battery and battery box to make room to get to them.
    Mar 2018
    California
    The relays came in from Partzilla and I installed them today. Fortunately it was not necessary to remove the left rear wheel. I removed the battery and battery box and was able to change out the two relays and after replacing them in the boots. It was necessary to recharge the battery. I installed the battery that was fully charged and attempted to start the trike and nothing, no noise at all. What do you think is going on?
    Jun 2008
    Lovington, NM, U.S.A.
    By chance has the reverse button accidentally been pushed in?
    Retired trike builder
    Mar 2018
    California
    Quote Originally Posted by trike lady View Post
    No, I did exercised it. Light went on and off but was off when I tried to start it.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    I know nothing about an 1800 but with that said have you tried squeezing the clutch lever while pressing the start button?Possibly something going on with the kickstand switch.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    Mar 2018
    California
    Goldwing was converted to Champion Trike in 2005. No kickstand.
    Sometimes the installer will take off the kickstand and then just leave the switch intact..?.
    Aug 2016
    devine
    Default Starter relays
    I replaced by "B" relay what a PITA in my 05
    and it wasn't triked. I have an 08 with csc kit don't look forward to that job. good luck
    Quote Originally Posted by jd4020 View Post
    James ,,,,,,,,,Welcome to Trike-Talk............
  1. relocate relay box
    By landperson in forum New Member Introductions
    Last Post: 07-10-2017, 07:34 AM
  2. GL1800 Emergency Relay Pack
    By Gold Rush in forum Honda Trikes
    Last Post: 06-14-2016, 06:44 AM
  3. Location of Reverse Relay on 2006 GW Motor Trike
    By paid4c4 in forum Honda Trikes
    Last Post: 06-13-2016, 04:52 PM
  4. GL 1500 Relay Cover
    By eastkytriker in forum Honda Trikes
    Last Post: 05-05-2015, 06:32 AM
  5. Relay removal with trike kit
    By Teal in forum Honda Trikes
    Last Post: 06-02-2012, 08:39 PM
