Likes Likes:  219
Page 12 of 15 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 221 to 240 of 297
Thread: Post Your VW Trike Pics
  1. #221
    Welcome Gleep ... you found a great bunch of VW Guru's here ... so much so ... i'm looking for a vw trike ...
  2. #222
    Aug 2015
    fresno
    Default Info for the Carb
    Here's some pic's of what's under the seat and tank. The carb is a Keihin CV 40mm, polished bore, 48 pilot and 185 main jets. Needle is set (adjustable needle) with the clip 1 notch below center. The pressure spring on the top of the diaphragm has had 1 1/2 coils cut off to make the needle come up sooner. The vacuum hole in the slide has been over drilled to 1/8". The intake is 1 1/2" exhaust bends fitted together and TIG welded. There's a brace from the bottom carb bolt to a hole in the top of the transaxle case to stabilize the carb and manifold. Air cleaner is from a Harley Twin Cam, cover removed. Snug fit but it works.
  3. #223
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    That is an excellent looking setup Gleep!
    That 40 carb feeds the engine good being a 1776?
    Reason I have asked these questions is that I am sooooooooooooo fed up with fooling around using the dual POS EMPI 40 HPMX's that I am looking for different options.
    I have thought about grabbing one of the 2bbl progressive carbs but I have mixed feelings towards that route due to some fairly bad reviews.
    The old time Weber's 2 bbl progressives were great but the new EMPI version has some fairly bad reviews.
  4. #224
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Well stinger, gleep did a lot of research and question asking on his build.
    One thing is the choice of cam to use with a single barrel.
  5. #225
    Aug 2015
    fresno
    CB 2208 cam. 8:1 CR. 53cc chamber "stock" heads from MOFOCO. The carb is gravity flow (eliminated the fuel pump) and it's never "starved". Power rolls on good from idle all the way up to highway speed, nice and smooth. In the county roads ans twisties along with hills, it'll roll on fro about 15 on up to 60 in 3rd- perfect cruising gear.
  6. #226
    welcome aboard Nice trike good job
  7. #227
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Yea right?
    Not sure how well something like that would work for a 1835 with big heads, 125 rockers and an Engle 110 cam.
  8. #228
    Aug 2015
    fresno
    True- but a couple choices remain. I had an 1835 in a bus, big valve heads, 9-1 CR, forgot what cam but it came from Claudes as well as 1-1.25 rockers. I had the Weber progressive on it (single) and it ran like a stripped ass ape. The Weber progressive is fairly easy to set up to- there's lots of people running them and lots of infor and experience out there to get it real close bolting on first time. That really was my first choice but just didn't have enough room under the tank with the way it came together. Still have the carb sitting here.
    On the other hand, the CV was a true "shot in the dark" with no one I could find ANYWHERE ever using it to power a VW engine. I DO know that it will power a 110" Harley (I do those too) so I figured "nothin ventured, nothin gained.
  9. #229
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Right Gleep. The trouble is, it is pretty tough to actually get a true Weber 2 bbl progressive. Everyone is selling the dang EMPI crap and it is just that.........Crap.
    I have a fella here in town that actually has an original Holley Bug Spray. Not sure how well that would work but I think I'm willing to give that a shot. Them were, however, basically a performance upgrade for a stock 1600 so not quite sure how well it will work on an 1835.
    And, I know its long overdue, but here is a few pics of my VDub trike.............Finally.
Size:  715.1 KBName:  IMG_0034.JPG
Size:  482.2 KBName:  IMG_0035.JPG
Size:  359.0 KBName:  IMG_0036.JPG
Size:  458.3 KBName:  IMG_0037.JPG
Size:  495.3 KBName:  IMG_0038.JPG
  10. #230
    Aug 2015
    fresno
    Nice!
    I've found, with Webers, that if you get them good and clean on the inside, get 'em dialed in, keep your fuel filtered and the pressure @ no more than 3 pounds they work good. Have you thought to just run a single Weber in the middle?
  11. #231
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by gleep_54 View Post
    Nice!
    I have thought about running just a single in the middle. I may give that a shot. Of course these aren't actual Weber's. These are the EMPI knock offs.
  12. #232
    150+ Posts CaveManDave's Avatar
    Apr 2016
    Spokane, WA USA
  13. #233
    Apr 2016
    Spokane, WA USA
  14. #234
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by CaveManDave View Post
    Well hell Dave, that looks like a Flintstone powered bug trike.
  15. #235
    Dang that's sweet looking ... nice and clean.
  16. #236
    Apr 2016
    Spokane, WA USA
    Quote Originally Posted by stinger608 View Post
    Not for long Stinger, The new engine should be ready to install right before your visit!
  17. #237
    Apr 2016
    Spokane, WA USA
    Still waiting on the builder.
  18. #238
    Dec 2015
    Chubbuck
    Hey Dave,
    What did you do for the fuel sender/guage?
  19. #239
    Apr 2016
    Spokane, WA USA
    Quote Originally Posted by Jester13 View Post
    Hey Dave,
    Built into the tank. I ordered the tank with the gauge installed.
  20. #240
    Aug 2016
    Austin, TX USA
    Default Help with a conversion
    I am a US Army Vet, I own a VW Trike, manual transmission. It has been sitting for over a year because I lost my left leg. Does any one know of a way to convert the foot brake into a hand brake OR convert the foot clutch into a hand clutch? Either way I need to free up the left leg side since I have no use of it and I truly would love to ride my trike once again.
  1. Post Your BMW Trike Pics
    By Papa Zook in forum BMW Trikes
    Last Post: 08-12-2016, 09:29 AM
  2. pics of the new trike
    By cooltech in forum General Discussion
    Last Post: 09-10-2013, 05:39 PM
  3. trike build more pics
    By ade747 in forum General Discussion
    Last Post: 04-01-2013, 09:20 AM
  4. Our New Trike Pics
    By skuuter in forum Honda Trikes
    Last Post: 07-11-2010, 03:36 PM
