Likes Likes:  2
Results 1 to 13 of 13
Thread: Honda Valkyrie Reverse Gear.
    BLACK DRAGON
    Guest
    Smile Honda Valkyrie Reverse Gear.
    Info request -
    I see in my service manual and talking to dealer that reverse gear is in the Honda GL1500 tranny. Valkyrie had reverse option for 1 year only.
    Does anyone know what is needed to put outside selector on 2001 Valkyrie to use the reverse gear?
    Thanks Terry.
    200+ Posts FBTRIKE's Avatar
    Nov 2008
    Pine Colorado
    Default Re: Honda Valkyrie Reverse Gear.
    Hey Terry, I don't know if you have considered a drive line reverse......You might want to contact the guys at
    JAXPORTS.com....they have some interesting stuff....
    good luck
    In memory of my brother Steve....
    BLACK DRAGON
    Guest
    Thanks for info, I will look into it.
    Terry
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Terry, I could be wrong, but the only Valks I know of with reverse were the ones sold to the Japanese Market. Id say it would be near impossible to add the reverse setup without major modification (ie: machining) to the engine case. Youd also have to have the other components which would be tough to get ahold of.
    BLACK DRAGON
    Guest
    Smile Re: Honda Valkyrie Reverse Gear.
    Thanks for info Bazooka. You are correct in the fact that Hponda shipped valkyrie's with reverse in 1999 to Japan. The GL1500SE Goldwing has reverse also with a reverse selector. In my service manual it shows all the GL1500 transmissions have the reverse gear in the tranny.
    I want to find out what is needed externally on the Valkyrie to shift into reverse? Is it possible to add on or buy the parts same as GL1500SE wing has?
    Thanks for answer.
    PS, rain and snow here. My ride is under the covers for now.
    The Honda reverse gear is run by the starter motor. No American Valk has a reverse. I also believe they made a Goldwing 1500 without the reverse, in the early 90s, and called it the Interstate model. A friend has a Valk and asked the local Honda dealer about adding a reverse. Was told yes, it was possible, but the work would exceed the value of the bike. In other words, its not plug and play.
    TOI - Michigan CadtoChrome's Avatar
    Dec 2008
    Oakley, MI
    Quote Originally Posted by BLACK DRAGON View Post
    Info request -
    Thanks Terry.
    I am looking into this very option, On the surface it appears doable but before
    I stick my foot too far in, lets just say I am looking over the part lists between the two bikes to see how many have to be changed/added and what may have to be done to the valkyrie Vs the 1500 wing.
    Yes, Valkyries sent to Japan had reverse while the US models did not.
    Chuck
    Feb 2008
    Anderson, Missouri
    Have a buddy down in Arkansas with a Valk Interstate trike. He says he has the "Flintsone Reverse Kit" installed.
    BLACK DRAGON
    Guest
    Thanks everyone. It is not that important right now and I will keep looking and asking. In the mean time I will use the flintstone reverse also.
    We always plan our docking so we can ride out!
    Keep it shiny and up right!
    Terry
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    They put Rev on Harley trikes I wonder if it could be added to the Valk.
    Sep 2016
    Melbourne fl us
    Default Yes Valkyrie with reverse
    It sure can not cheap but is and had been done.
    20+ Posts shadow1111's Avatar
    Feb 2018
    Ahwatukee,Arizona
    Default REV
    Well, from what I've read, it would be cheaper to buy a Valkyrie in Japan and ship it home........
    ​~ Degotoga ~
    2000 Valkyrie / DFT
    Do DA DA go hv i
    Nov 2021
    Hellertown, PA USA
    Default custom shop adds reverse gear to Hondas...
    I had the same question and have been looking around-- found this https://www.unbcustoms.com/blog/2020/2/7/honda-f6b-trike-conversion-with-a-custom-reverse they could make money showing others how to do this...
  1. Honda Valkyrie trike kit
    By saab9k in forum Honda Trikes
    Last Post: 10-13-2015, 02:28 PM
  2. 2014 Honda Valkyrie
    By Gabby Hayes in forum Honda Trikes
    Last Post: 11-27-2013, 04:37 PM
  3. reverse gear
    By icedad in forum Honda Trikes
    Last Post: 12-24-2012, 07:15 AM
  4. Reverse for your Valkyrie VTX Trike?
    By grumpy in forum Honda Trikes
    Last Post: 11-04-2011, 08:20 PM
