Likes Likes:  12
Thanks Thanks:  2
Results 1 to 20 of 21
Thread: Tone ring gouge marks
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Default Tone ring gouge marks
    Has anyone who has pulled their axles noticed gouge marks in the tone ring housing? Exact same on both sides.Name:  0.jpg
Size:  39.9 KB You can also see the rust at the top of the bearing race. Passenger side came right out while left side needed a slide hammer.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    Quote Originally Posted by Rogue1 View Post
    Did you Traction control or ABS lights go on??
    Cheap bearing retainer plate allowing too much end play of axle
    These are the fix
    https://www.dkcustomproducts.com/axl...reewheeler.htm
    Oct 2018
    Ramseur NC USA
    These are the fix
    I have had the DK retainer plates for a couple months and I'm just getting around to installing them now. One of the local dealers here wouldn't even touch it if I brought the axles in. They said they didn't have the equipment to do it? I said so I have a Harley-Davidson product that you won't work on very interesting. Asheboro machine shop said no problem bring them down dropped them off yesterday should pick them up today.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    mine had marks at 10k already. Had the DK retainers installed. Much beefier plate & also O ring gasket designed into the plate. GOOD Quality stuff
    Oct 2018
    Ramseur NC USA
    No traction control or ABS lights, just changing the retainer plates and bearings.
    That is funny, sounds like they don't know how to
    I would bet they DO have a press
    Oct 2018
    Ramseur NC USA
    Gentlemen, thank you for your input.
    Sometimes dealers don’t wanna work on stuff that they didn’t sell I don’t want to end up owning it if something breaks.. Bring a pair of old eyeglasses in to an optometrist and ask them if they can put new lenses in and see what they tell you….
    I had my own one-man business (shop ) and I can’t tell you how many times I help somebody out they come back six months later and said you worked on this last and now there’s something wrong with it ..And now it’s my headache…!
  11. #10
    Oct 2018
    Ramseur NC USA
    I know EXACTLY what you mean. I ran an independent shop for 15 years before I got into the Department of Corrections. Just one example I did a tune-up for a guy on his bike I don't remember the bike ( this was back in the late '70s when you actually did real tune-ups points plugs, valves, oil) 3 months later he comes back in bitching and moaning his shifter shaft seal is leaking and I was the last one to work on it. We had words and he left.
  12. #11
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    This is the very reason I quit doing cam installs, brakes, ect.
  13. #12
    Oct 2018
    Ramseur NC USA
    I've never had a dealer refused to work on my bike even if I didn't buy it there. If it's something under warranty any Harley dealer has to work on it. Of course this isn't warranty work but I was just taken back when they refused to work on it. Two other dealers I go to local said sure bring it in we'll do it.
  14. #13
    Being the Devils Advocate.....That dealer might of had a bad experience at one time taken in other peoples headaches.........
  15. #14
    1500+ Posts
    Apr 2016
    Dayton Ohio
    When I replaced my axle bearing retainers mine looked the same. Also I took the sound advice from jack Klarich and removed the seals on the bearings very carefully and hand packed the bearings with grease. I was shocked to see how little grease was in them from the factory.
  16. #15
    Oct 2018
    Ramseur NC USA
    Very true
  17. DKCustoms postbit
  18. #16
    Oct 2018
    Ramseur NC USA
    I did the same although they looked pretty good, I packed the shit out of 'em.
  19. #17
    Good on you
    Most sealed bearings I have cleaned out and repacked were not fully packed IMO
    of note also, the consistency of the grease was that of Vaseline
  20. #18
    Oct 2018
    Ramseur NC USA
    These are the fix
    I understand what you're saying Jack. What I don't understand is how the retaining plate has control of the end play of the axle. The hole in the retaining plate is a lot larger than the actual diameter of the axle, if it's not a tight fit around the axle how does it control the movement? I must be missing something.
  21. #19
    The retainer plates are stamped steel and flex a lot, especially during hard cornering
    This causes the plates to distort some, thus not holding enough pressure to keep the axles from even slight movement, this will give the score marks inside the axle housing
    This is not new, we saw many cars and trucks with the very same stamped bearing retainers, mid 70s saw quite a few Ford trucks with sheared axles from what I believe
    to be cause and effect of the retainers
  22. #20
    Oct 2018
    Ramseur NC USA
    Jack, I believed every word you said. Your advice hasn't let me down yet. But I saw it with my own eyes. Sometimes that's what it takes with me. I took the retainer plates off and laid them on a surface plate. They were both warped. The worst one I could slide a 20 thou feeler gauge under one end between the surface plate and the retainer plate. It's not much, but there it is, both of them were warped. It's hard to believe that that little amount of warpage caused the problem I found. But it did. Thanks for your input
  1. 2019 RED and Silver Two Tone
    By hddocfl in forum Harley Tri Glide
    Last Post: 12-02-2018, 12:02 PM
  2. Boot Marks on Chome Heat Shields and Exhaust Pipes
    By TonkaDriver in forum Harley Tri Glide
    Last Post: 04-27-2018, 12:10 PM
  3. No more heel marks
    By Zammy in forum Harley Tri Glide
    Last Post: 06-05-2015, 04:11 PM
  4. Tone of your mufflers
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 04-20-2012, 05:19 PM
