Likes Likes:  27
Thanks Thanks:  2
Results 1 to 20 of 40
Thread: 1984 goldwing with the shakes!
    20+ Posts
    Mar 2021
    Morgan Hill
    Default 1984 goldwing with the shakes!
    new to trikes but not motorcycles, just got a 1984 goldwing trike wants to shake the bars out of your hands at 30-40 mph never tried any faster after that, got a PM into papa about this. would like to hear any input on my problem . thanks
    two ideas of mine first steering head bearing nut needs tightening to 40 lbs also possible rear tire pressure
    Quote Originally Posted by dd trike View Post
    Dave.......Can't help with the shake....But i will Welcome you to Trike-Talk....
    20+ Posts
    Mar 2021
    Morgan Hill
    Default trike
    thank you, should have also said it steers like a mack truck kills your arms.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Needs a set of raked triple trees, but I only have trees for the GL1500s and GL1800s. You might try a Google search for GL1200 rake kit or GL1200 raked triple trees.
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Re; The shakes. Two things come to mind. How old are the tires? You could have tread separation. Second item to check is steering head bearing.
    As to steering like a truck, a rake kit will take care of that. Good luck and welcome..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    20+ Posts
    Mar 2021
    Morgan Hill
    Default thanks
    just no rake kits for this old bike, my buddy in crime was one of the top 10 bike builders back in the day with Indian Larry, Arlen Ness, Jesse James etc, says we will cut the neck pull it out no big deal. will let you all know how it works out.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Hope you buddy can help. Welcome to Trike Talk Dave!
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    Be careful, cutting the neck to change the rake moves the trail the wrong way. Raked trees shorten trail, raked frame lengthens trail.
    Jun 2010
    Indianapolis, In.
    More rake does two things: one, it makes the wheelbase longer, and two, it generally increases a motorcycle's trail.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Just my 2 cents worth. Unless trike has sentimental value or other personal reasons, l would consider selling it and upgrading to a 1500 wing trike. More power and available parts. If you shop around you can locate a decent 1500 trike with raked kit in the 5-8 k range.
    I purchased this 1988 1500 with motor trike kit and rake kit for 2800$ on Craigslist last spring. It’s not a beauty but it’s comfortable and dependable. Just recently retired and sold my Stallion and have made this my last trike. Have been offered 5000$ several times but gonna keep it cause it’s cheap comfortable dependable and lots of if power to pull my kwik kamp trailer. Cruise interstates at speed limit all day and lots of parts available. Just my opinion but you know what works for you. Good luck with your wing trike.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Deals like that are rare to unheard of around here, just sayin.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Adding raked triple trees (rake kit) always decreases the trail, which results in much easier steering. That is the specific reason that aftermarket trike rake kits were developed.
    Oct 2010
    Deals like that are rare to unheard of around here, just sayin.[/QUOTE
    have gone as far as CA to purchase trikes. Been lucky so far.
    20+ Posts
    Mar 2021
    Morgan Hill
    Default shakes
    OK trike has 64 thousand miles on it, riden by a woman, something must have happend could not have always shook like this? (does need a tire and fork seals leak) NEED HELP !!!!!!!! thanks
    Jun 2008
    Lovington, NM, U.S.A.
    I've done some digging around and found them for a GL1200. https://www.customtripletrees.com/TR...NDA/honda.html
    When were the steering head bearings replaced? Tire wear pattern? Lifting the front wheel off the ground you can check the condition of the bearings, notchey or loose?
    Retired trike builder
    KISS, start by jacking up the front end. Observe and note any looseness and or binding in the fork and wheel bearings. Spin the front tire to check for high and low spots and wobble. With 60K I would be replacing that tire just because. Good Luck and let us know how it goes
    Jun 2010
    Indianapolis, In.
    Interesting. I got my info off the internet. It’s never wrong is it? LOL
    Patriot Guard
    Was a LEO
  19. #19
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Tom, of course the internet is never wrong. With so many experts out there, it has to be right. Right?
  20. #20
    Oct 2010
    RIGHT!!
  1. 40 mph shakes!
    By nkpdblue in forum Yamaha Trikes
    Last Post: 02-03-2012, 10:44 PM
  2. 1984 GL1200 Manual
    By drumdoctor in forum Honda Trikes
    Last Post: 07-20-2011, 06:20 AM
