Likes Likes:  1
Results 1 to 20 of 40
Thread: Harley Front Tire???
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Default Harley Front Tire???
    I have searched "front tire" and all I get is front tire changes for Honda. I found one for a Harley and the person used a MU85B16 rear tire. They did not say if they mounted backwards.
    Has anyone put a rear tire on the front of a triglide? Which rotation direction? I notice the MU85 has 11/32" tread depth, the stock front tire has 5/32". What type of tire? What size?
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
    TOI - Virginia VaThumper's Avatar
    Feb 2011
    Williamsburg Va
    Default Re: Harley Front Tire???
    I used a Bridgestone Battle Axe? tire mounted in reverse and it is doing fine after only 6000 miles no wear.
    2010 HD TriGlide,FullSac,Heavy Breather,Vance&Hines Deluxe Mufflers&FuelPack,30Tooth Sprocket,Willy Shinny Wheels, Chrome&More Chrome:Party:
    Jan 2011
    The Villages, FL
    Quote Originally Posted by VaThumper View Post
    I cannot find a 16" Bridgestone on any of their websites.
    Sep 2009
    Near Myrtle Beach SC
    Im running a Dunlop MU85 in reverse direction on my Roadglide trike. Currently I have close to 10k miles on its wearing great. The only thing I would advise you to do is measure the width between your front bumper. I think its slightly smaller then the fender is.
    Tom
    100+ Posts pigbike's Avatar
    Apr 2012
    Odessa, Florida
    Am I missing something? Why do you mount the tire in reverse????
    My Roadglide also has the MU85 mounted reverse rotation. 15k and still looks new.
    Sep 2009
    Quote Originally Posted by pigbike View Post
    This will explain it >>>> Tires Directional Arrows Explained By Avon Tyres at Cyril Huze Post
    Feb 2011
    Williamsburg Va
    The tire I used i Mfg Part# 072664. I ordered it from Partsbandit.com. It is 130/90V16 rear tire mounted in front in reverse.
    Apr 2012
    Odessa, Florida
    Quote Originally Posted by FLTR2008TRIKE View Post
    Ok I understand why you reverse a rear tire when you put it on the front. I'm still a little confused why someone would go buy a rear tire to put on the front. Why not just buy a front tire?
    Sep 2009
    The rear motorcycle tire has a flatter profile to give you more contact area when mounted on the front and the rear tire has more tread depth 11/32" compared to 8/32" for the front. Im looking at 25k miles minimum wear on my current front mounted rear tire. The best mileage I could get out of stock front tire was 15k.
    150+ Posts KRUZR's Avatar
    Oct 2010
    Aurora, IL, USA
    I'm using the Dunlap Rear Bias Ply E3 MT90B-16 74H in reverse rotation on the front of my converted Street Glide. It has a higher weight rating and a deeper tread depth. So I expect I won't have to replace it as often as the front 402. It maybe a little louder running than a 402. The E3 and the AVON Venom tires are the only 2 tires I never found any wild stories about.
    Black Pearl 2007 Street Glide/2010 California Side Car Conversion
    Apr 2012
    Odessa, Florida
    Now I understand,,,,Thanks for the clarification
    80+ Posts
    Jun 2009
    50 Miles North Of N.Y.C.
    Ill replace what came on the 09 triglide. for safety sake, Harley did the research and development plus I have ESP dont want to mess that up.
    5+ Posts porky's Avatar
    Jun 2012
    Crossville,Tn.
    The only thing to watch out for is rain. If the tire is mounted backwards it will send water under the rear tires in rain.
    Welcome aboard Porky, AH you do realize that we are talking trikes here. The front tire track is well out of the way of the rear tires track.
    Sep 2009
    Quote Originally Posted by porky View Post
    I have ridden through some serious rain down pours with my rear tire mounted on the front in reverse and I have had no issues with handling.
    Jun 2012
    Crossville,Tn.
    Correct but the spray of the water will spray out in the path of the rear tires. I have a 2008 and I put the tire on the correct way and spray was not as much as reversed.
    Feb 2012
    South Australia
    I have a Motor Trike kit on my 02' FLHTCUI, tried various brand's of tyre's but the best I have used (and still are) are Shinko Tyre's specificaly made for Trikes. I ride hard n fast
    & have 12000 kliks on this one so far, So go & check 'em out
  19. #19
    Jan 2011
    The Villages, FL
    I just made up my mind and installed a MT90B16 rear tire on the front with reversed rotation. On the ride home it seemed to steer better. May have just been because the old front tire was down to the wear bars I had gotten 22,000 miles on the original front tire. It was the dealers first time for doing this on a tire.
  20. #20
    20+ Posts
    Aug 2011
    mason mich usa
    I'm at 18000 and going to put on my 3rd front tire,last one was E3 MT90B16 front tire,will try the rear tire reverse thing this time ,to see if better
  1. Car Tire on Front
    By harleyman in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-30-2014, 05:36 PM
  2. Front tire
    By Daniel Warder in forum Harley Trike Conversions
    Last Post: 11-15-2013, 06:15 PM
  3. Front Tire Again
    By Smitty Werben Manjensen in forum Harley Trike Conversions
    Last Post: 04-21-2013, 08:00 AM
  4. front tire
    By trucker in forum Honda Trikes
    Last Post: 08-03-2011, 08:51 PM
  5. Front Tire
    By subeetrikerdon in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-16-2010, 11:22 PM
