Likes Likes:  2
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: New tires correct position
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default New tires correct position
    Just bought new rear tires for the CSC. Two questions. The wheels have ten holes for the five studs. Five holes have a kind of recess, five are just regular holes. Does it matter which five I use? And one wheel has an L in marker ink on it and the other an R, does it matter which side they go on?
    Gerald
    Quote Originally Posted by geraldlanc View Post
    Gerald
    I would think ''L'' Is left......''R'' Is right..... Where did you get the wheels and tires from.......
    austin tx usa
    Tires from Discount Tire, same size as original and the wheels are original as well from CSC. The question is, does it matter which side the wheels go to.
    Did you purchase wheels and tires? If the wheels are stamped Land R they will be directional for air flow to the brakes. What kind of lug nuts did you take off?
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    You should have dimpled holes to accommodate the lug nuts. Don't know what the other holes are all about. Unless you have directional tires it makes no difference which side, L or R you install the wheels on. Your wheels should be the same. Just check to see if you have directional tires and mount accordingly..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    austin tx usa
    The trikes wheels and lug nuts are original CSC components, tires are new as of today. The wheels are not stamped, just marker ink.
    I would think if they went and marked them Left and Right that the way they go...
    Just to add sometimes theirs a little arrow on the sidewalls to show the direction of rotation
    If you are not sure call them to ease your mind...
    austin tx usa
    Default Job done
    The ten holes; five have “dimples” and look like those would be the ones to use. But they are very, very slightly further from center, just enough to be almost unnoticeable. The other five are closer to center. Once I got the tires inside the wheel well, the rest was easy. One thing to do differently; do one side at a time and don’t lift the entire rear.
    Thanks for the help
    Gerald
    Thanks for the help
    Gerald
    Be sure to recheck the torque on the lug nuts after about 50 miles
    austin tx usa
    Thanks for the reminder, I would have missed that.
  1. Trike position in ride formation
    By minnleeboy in forum General Discussion
    Last Post: 10-07-2011, 05:16 PM
  2. Seating Position
    By rmrc51 in forum Honda Trikes
    Last Post: 04-30-2009, 06:27 AM
  3. Trike Centre of gravity position (longitudinal and vertical)
    By sophtayl in forum General Discussion
    Last Post: 01-21-2009, 11:51 PM
