LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  12
Results 1 to 5 of 5
Thread: Safety Harness for my Cerbrel Palsy Grandson
    50+ Posts
    Apr 2018
    Calgary, Alberta
    Default Safety Harness for my Cerbrel Palsy Grandson
    Thought I would pose the question to the board.
    I have a 2008 Honda GL1800 Lehman Monarch and one of the reasons I bought it was to take my 12 year old grandson riding with me. He has cerbrel palsy on the right side, can walk reasonably well but only has the use of his left hand. Want to give the little man some pleasures and having him riding with me will be one of them.
    Has anybody got any suggestions about some sort of safety harness to make sure he doesn’t come off the back passenger seat? Any suggestions would be appreciated.
    Mar 2011
    mountain home,ar. USA
    I'm making this recommendation based on the belief you understand your grandson's capabilities and limitations.
    If he understands fully what he is doing, then I would install a set of Kuryakyn passenger armrests. After helping him mount the trike, simply tie the two armrests together with some type of quick disconnect system that will keep the armrest from moving outwards. That should prevent him from sliding off. Depending on his physical size, you might even have him wear a life preserver to fill in the space so he is "tucked" in securely and can't be jostled from side to side.
    This may take some trial and error but I think you can come up with safe system that will allow him to share the joys of riding with you. Best of luck and here's hoping for many wonderful memories.
    First, let me applaud you in your efforts to provide him with some simple pleasures that might not otherwise be available to him.
    No comparison here, so don't take this wrong.
    I had a Doberman that loved to ride. He loved sitting in the rear seat. I ended up getting a harness and using two leashes, one on each side to the side of the harness. He could of slid his back side of the seat, but, he never did.
    You might be able to get like a climbing harness and add D rings to give you more attach points. I do like the life preserver idea, although it may get warm.
    Good luck with this, it's an honorable pursuit.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    You might post this inquiry in the Late Nighters Unite thread.
    Our TrikeTalk member Consitter (Scott) has a special needs daughter that he takes for rides on his trike. He is usually on that thread at night.
    50+ Posts
    Apr 2018
    Calgary, Alberta
    Excellent idea, as I will go to the local Mountain Equipment Co-op and check out some climbing harness equipment. Thank you for the idea!
  1. First time riding trike with my grandson on his own trike
    By GrandpaDave in forum Trike Travel
    Last Post: 06-17-2018, 03:29 PM
  2. Prayers for the Grandson
    By desertclassic in forum Thoughts & Prayers Sanctionary
    Last Post: 01-03-2017, 09:34 PM
  3. Took the grandson on his first ride!!!
    By bayoudave in forum General Discussion
    Last Post: 07-22-2014, 11:33 AM
  4. New Grandson
    By rmrc51 in forum General Discussion
    Last Post: 03-13-2012, 07:26 PM
  5. URGENT!!!!! Lighting Wiring Harness Short Issue
    By Gorilla in forum Stallion Trikes
    Last Post: 12-27-2008, 06:45 PM
