Likes Likes:  7
Results 1 to 5 of 5
Thread: Rear differential oil
    20+ Posts MAMPORRERO's Avatar
    May 2018
    HIALEAH,FLORIDA,USA
    Default Rear differential oil
    I have a 2015 gl 1800 trike lehman monarch ii with straight differential, and i need to know what amount of oil it need and if it is recommended to put mobil 1 synthetic 75w90, it has 3000 miles only. Thank you.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by MAMPORRERO View Post
    Danilo,
    If your conversion was built after 2013, it has a Champion Axle. I would suspect 75-90w synthetic would be suitable. I don't think it is necessary to change the oil with only 3K miles. I would make a change at 10K and if you keep it longer than 40K, change it then also.
    Jim Murphy
    Iron Butt Rider 2001
    May 2018
    HIALEAH,FLORIDA,USA
    Default REAR OIL
    Thank you Lee, i know it is not time to change the differential oil but i want to put synthetic as i do with the engine, i am mechanic but i wanted to know the opinion of a person like you who has broaden knowledge about trike lehman.again thank you very much.
    Mar 2016
    North Carolina
    Danilo,
    Lee:
    Do you have any suggestions on how to change the rear end oil on a 2008 Renegade trike?
    Martinsburg, WV
    Quote Originally Posted by MarineDoc View Post
    Lee:
    Lehman Trikes used several differential throughout their original production. The differentials were either greaseable or sealed. Unlike the shaft drive wet differential version (used in shaft drive motorcycles), the belt drive rear differential is mostly exposed and used chassis or wheel bearing grease.
    It is depending on the specific rear axle you have whether or not it is greaseable.
    Jim Murphy
  1. How to change differential oil?
    By mhgoldwing in forum Roadsmith Trikes
    Owners Forum
    Last Post: 02-19-2024, 05:02 PM
  2. Differential gear oil change
    By the paparazzi in forum Yamaha Trikes
    Last Post: 04-07-2015, 10:38 AM
  3. Replies: 6
    Last Post: 09-25-2014, 10:44 AM
  4. Differential oil
    By katonka in forum Honda Trikes
    Last Post: 08-06-2014, 08:46 AM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
