Likes Likes:  3
Thanks Thanks:  1
Results 1 to 17 of 17
Thread: Another Cruise Control ?
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default Another Cruise Control ?
    2015 Freewheeler cruise amber light will come on but speed will not set so no green light. There are no codes showing. Have ran the cruise diagnostic with the buttons, amber light just stays amber never goes to green. Whats next????
    That is odd for sure
    Have a look here and scan your ECM for a DTC
    Most often the cruise control problems show up with a brake light switch code http://www.motorcycletireco.com/moto...y-fault-codes/
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default Cruise problem
    Thanks Jack
    I have already ran all suggestions that I could find. First thing was to check for DTC codes and there are none. Cruise speed just will not set. Was working find until a few days ago.
    Very strange indeed. Harley has had a fair share of these new handle bar switches, I hope your left switch pak is not going bad. Does everything else work OK including the clutch switch?
    40+ Posts
    Aug 2019
    Ocala FL USA
    Yes sir everything seems to be in order except the cruise. I was already thinking about the switch pack.. I have already checked on switch which is costly for a switch. Would like to know for sure it is bad before I spend that money.
    thanks for your knowledge, If i find out for sure I will let you know..
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Quote Originally Posted by USMC Old Dog View Post
    Check your fuses, especially the 5amp.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    If all fuses are good, it sure seems like the switch is bad. If you do have to replace the switch pack, you can upgrade to illuminated ones for about 10-15% more.
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default cruise control
    Latest on my cruise problem. My local indie spent over an hour this morning checking all he could and even had a new switch pack and put it on to check and nothing changed. Fuses good cleaned connection behind air cleaner nothing changed. Ign on push cruise and amber light comes on. Twist throttle forward and hold and amber light begins to blink green then amber etc. Tried same on another bike and green comes on and stays on until throttle released. What do you think twist grip sensor or something else.
    Thanks in advance
    Very strange for sure. What I have seen is when a sensor voltage gets out of parameters on these can bus systems it will set a DTC. It can have a code stored without a check engine light on, my 15 Freewheeler did that when the throttle by wire voltage was not correct.
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default Cruise
    Anyone know what is indicated when I put ign on, push cruise on and then turn throttle forward and hold there then amber cruise light begins to blink green and amber as long as the throttle is held forward. Back to steady amber when throttle is released. Cruise will not set and all diagnostics have been tried and all else that has been suggested in this thread.
    300+ Posts
    Mar 2018
    Waelder, Texas
    I have no idea how to check for a signal, but it seems the speed sensor also comes into play. Mine will not set at 90mph or above. I probably shouldn't have posted this, but maybe it's something else to look for.
    Quote Originally Posted by RKplus10 View Post
    I believe that is how it is programed just like it will not set below 30 either.
    300+ Posts
    Mar 2018
    Waelder, Texas
    &lt;br&gt;<br>
    Yeah, I wasn't implying that I had a problem. If there is a (factory set) minimum and maximum speed that will not allow the cruise control to set, then I was suggesting that maybe the OP's problem was related to the speed sensor's signal. Just a thought.
    Oct 2017
    St. Louis, MO USA
    Did you run the diagnostic that Jack linked to? It test everything in the circuit. Watch the video and run it again. It tests your:
    1. Cruise control switch
    2. Clutch switch
    3. Front brake switch
    4. Rear brake switch.
    5. Throttle switch.
    These are what will keep your CC from working.
    40+ Posts
    Aug 2019
    Ocala FL USA
    2. Clutch switch
    5. Throttle switch.
    Thanks for suggestion but this has been done several times and nothing comes on except when throttle is twisted forward and held, then as stated before green light begins to flash.
    You sure have a strange problem that seems to defy all the checks you have done
    I wish I had a solution for you
    When you find the solution let us know what it is so it can be shared with others
    Best of luck to you
  1. Cruise control problem
    By lamornawing in forum Honda Trikes
    Last Post: 03-26-2023, 02:48 PM
  2. Eat broccoli & get a free cruise control!
    By Dante221 in forum Harley Trike Conversions
    Last Post: 08-21-2011, 03:40 PM
  3. Electrical problems - horn, cruise control
    By gctrikeguy in forum Stallion Trikes
    Last Post: 07-23-2011, 07:21 PM
  4. No brake lights...no cruise control
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-24-2010, 11:38 PM
  5. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
