Likes Likes:  8
Results 1 to 16 of 16
Thread: Passenger grab rails
    Apr 2021
    Brownsburg, Indiana
    Default Passenger grab rails
    When I sold my 2012 Ultra Limited I kept the passenger grab rails. I thought I would put them on the Tri-Glide as the wife really misses them. Don't fit! After checking Harley's parts catalog I find they won't fit a trike at all and none are listed for a 2009-2012 Tri-Glide. Has anyone modified a set of Ultra Classic grab rails to work for these trikes? I can't seem to find an aftermarket set either. It seems like there should be a way to reconfigure the stock ones so they will work but my mind just can't seem to get a handle on it. (no pun intended)
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    That is the first thing I removed from my trike, it is sitting on top of one of my cabinets in the garage. Off my 17.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Doc Comer View Post
    It is surprising that they don't fit.
    Here is another possibility that was shown to me by a Customer. It is something I am considering doing.
    You can use some Freewheeler handles, with very slight trimming, and put them on a Tri Glide. Here is a photo of them-
    www.DKCustom.com
    Apr 2021
    Brownsburg, Indiana
    Thank you Kevin but I have the trike saddlebags and there would be no place to mount them. It looks to be a good idea though.
    Doc
    Apr 2021
    Brownsburg, Indiana
    Doc
    1000+ Posts
    Aug 2016
    Des Moines IA US
    You didn't say what year of trike you have but I'm gonna say a 2012, have you search everywhere for these, basically I did a little research and found some on Parts Giant and they are from Drag, around $109 I believe, look on amazon, ebay, I'm sure you can find some and if it a 2012 maybe they didn't have grab bars on them at all, I don't know for sure, I would check with harley dealer also. As Kevin said I'm surprised you couldn't get the ones off your limited to work or maybe modify it a little to work, just a thought. I know when I bought my 2016 the grab bars were in the tour pak and I had them put them back on with a bunch of other work I had done before picking up, I now have a 2018.
    All for now Trampas
    All for now Trampas
    Apr 2021
    Brownsburg, Indiana
    Default Grab Bars
    I have looked at all of the usual places. Harley, Amazon, Ebay and the general internet. I find everyones part will fit a tri-glide '13 and up. Some even say theirs won't work with a Hammock seat. It has the seat off the Limited and it worked with it. I am going to cut the mount and do a little hammering, bending and twisting to see what I can do.
    Doc
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Doc
    If you ruin it hammering & twisting on it. I have a spare one.
    1000+ Posts
    Aug 2012
    Pendleton, Oregon USA
    Default Grab bars
    I put them on my 2010 FLHXXX with the Hammock seat, had to trim the foam just a little so the bar fit, worked GREAT, I’ve had this setup for probably close to 10 years now and NO ISSUES……..Love it (also use the drivers backrest from time/time).
    Hooe this helps!
    Pete
  11. #10
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    I just looked on E-Bay. They had 3 used listings for the passenger hand rails. $39.00 to $49.00. for the 2012 tri-glide. Hope this helps.
    2022 Tri-Glide Black.
  12. #11
    Sep 2022
    Cedarburg, Wisconsin, USA
    Quote Originally Posted by 520fd View Post
    I just removed my passenger rails to install a tallboy seat and backrest on my 2013 TG. I had an adjustable backrest and stock seat. The seat would not fit correctly with the rails and the gap in the seat was not inline with the receiver in the adjustable backrest mount.
    More parts on the shelf and another hundred dollars later all is good.
  13. #12
    Quote Originally Posted by Gregory Chapman View Post
    Hey Gregory’ Welcome to Trike Talk…..👍👍
  14. #13
    Nov 2018
    WATERFORD
    Default passenger grab rails
    I bought a 2014 Tri glide and removed the stock rails and replaced them one from a 2010 street glide. The stock ones dug into my wife's legs because they sat too high, and she is 5'1". They were not supposed to fit but I had no problem installing them.
  15. #14
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Default Grab Rail padding
    has anyone added better grip to the existing passenger grab rails? Wife complains that the thin metal is tough on her hands. Harleys sells a set but says it won't fit a 2018 trike. Dennis Kirk had some but looks like discontinued.
    2018 Tri Glide Ultra Classic. Vivid Black.
  16. #15
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Quote Originally Posted by David792 View Post
    Check with the leather crafters and see if they can make some lace on ones.
  17. DKCustoms postbit
  18. #16
    Thumbs up
    Quote Originally Posted by Old Road Dog View Post
    This is a easy to do option
  1. Passenger hand rails
    By Rev J in forum Harley Tri Glide
    Last Post: 06-16-2017, 10:55 PM
  2. Passenger Grab Handles
    By aussie in forum Lehman Trike
    Last Post: 09-05-2013, 11:07 PM
  3. Passenger Grab Rails
    By Smoken'JOE in forum Honda Trikes
    Last Post: 06-29-2010, 02:48 PM
