Davep2rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep2DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Likes Likes:  3
Results 1 to 19 of 19
Thread: VW TRIKE riding dynamics
    1500+ Posts
    salt lake city, ut
    Default VW TRIKE riding dynamics
    I have become a real trike hore lately, my whole garage will be full of them if I don't control myself.
    My question is: how difficult is it to get used to shifting a VW based trike, around town and in the twisties? It seems to me like you would be doing a lot of one handed steering, and the clutch pedal is where the shifter used to be, no front brake! I had a rough enough time adjusting to my HD trike conversion, I might need shock treatments or a lobotomy to do this!
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Default Re: VW TRIKE riding dynamics
    Don't take long to get use to shifting with your left hand. The way the gears are, you can lug them down thru the twisties and still have the torque to pull without downshifting in the middle. Mine jumps out of third under acceleration so you have to hold it in. I can one hand the 35-45 mph turns and I have M/S with short bars. I wouldn't own one without a front brake. I wouldn't trade mine for a Harley or a Goldwing.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    You get used to it real quick and it is a grin to ride. I put my lever below left leg, behind my knee.
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Quote Originally Posted by americanbadass View Post
    Get you an autostick[very little shifting] or get you a full automatic, no shifting at all and then you can ride and enjoy the breeze and scenry too.
    Feb 2008
    Anderson, Missouri
    The Blue Trike, a Trike Shop Runabout, had a full auto tranny. Gloria also had Dick at the Trike Shop put in a foot accelerator pedal so it had foot controls just like a car.
    200+ Posts
    May 2011
    Orlando,Fl--USA
    If you put the shifter between your legs, you can shift with either hand---OR
    go to full auto.
    Ride safe!!! Lots of idiots out there!!!
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    Quote Originally Posted by drumdoctor View Post
    go to full auto.
    I didn't think that vw made a full auto tranny?
    550+ Posts
    Feb 2012
    tupelo MS
    Quote Originally Posted by East Coast View Post
    Was in a station wagon, with pancake engine.
    80+ Posts classicfins's Avatar
    Feb 2011
    Ruston, La USA
    Quote Originally Posted by saab9k View Post
    How hard is it to convert over to one of the automatics? My trike has a 4sp, but I'm thinking of converting over to a full auto sometime down the road so my wife can ride it easier. I'm thinking it would probably be just a bolt in swap?
    Doug Young
    Ruston, La
    Proud VW Trike Owner
    '86 Stallion built by Arizona Trikes
    Some people are like slinkies...
    Not much good for anything, but they sure are fun to push down the stairs...
    TOI - Oregon champsman97045's Avatar
    Jul 2010
    oregon city, or usa
    my vanagon had a full auto and the only drawback was the waterboxer engine
    Life is short, Break the rules, Forgive quickly, Kiss slowly, Love truly, Laugh uncontrollably, And never regret anything that made you smile.
    50+ Posts duane43344's Avatar
    Aug 2010
    Bullhead City, Az US
    My RoadHawk has a full auto connected to a 2333cc VW @ 145 HP. Works like a dream
    70+ Posts
    Mar 2009
    Vale, NC USA
    Quote Originally Posted by classicfins View Post
    Switching over to an auto is not just a bolt in swap. The type 3 auto has a different mounting system than the type 1. You have to cut off the frame horns on the rear section and build a frame and weld it to the torsion tube to mount the trans. The auto is quite a bit larger than the manual transaxle. If you do find an auto, be sure and get the flex plate and auto specific gland nut as they are getting really hard to find.
    Feb 2011
    Ruston, La USA
    Quote Originally Posted by chromedome1964 View Post
    She'll just have to shift.. lol
    Doug Young
    Ruston, La
    200+ Posts ea81slush's Avatar
    Nov 2011
    Strathbogie Victoria Australa
    I have full VW automatic on Tweety.
    In Australia they came out as an option is several designs around 1968-1975 the fastback, squareback (wagon) and notchback (sedan) and combi's.
    It is certainly an easier ride and I prefer it over changing gears.
    The flexplates are harder to get now in Oz. Although when I sold my VW 1916 engine and installed the Subaru ea81 the adapter plate came with a new custom flexplate as a kit. That was from John Sherman of VW conversions in Queensland. So if you are desperate try him.
    One original flex plate had faulty rivets and one broke free and peirced the rear main seal on the engine. Wondered what that rattle was!!
    The type 3 full auto tranmission is robust, smooth and easy to service. You can place the auto selector in the middle of your tank. A few more things:
    - If you ever split the transaxle to the auto box use two seals there. They tend to leak over time and two will fit.
    - I tend to overfill my transmission just a little. If fluid is on the full mark try going slowly up a steep incline. If you tend to lose transmission grip then your level is too low.
    - The kickdown is controlled with two systems, one is with an electrical switch on your throttle. The other from a vacuum line to a solonoid at the back of the transmission. To adjust your kickdown pull the vacuum line off the solonoid. Use a small flat screwdriver on a tiny screw in the middle of where that tube goes in. To make the kickdown more reactive and allow it to hold gear longer unscrew the screw a turn at a time then test ride. There is also another adjustment on top at the front of the tranny. I suggest you leave that one alone. I think it adjusts a band. That one is for the experts...if you find one alive?
    Dont expect miracles from this old fashioned transmission. Treat it well and it will last a long time in a 500kgm trike.
    One more thing. Since I've supercharged the ea81 the limitations of the transmission have almost disappeared. The extra low end torque allows for much better engine response. Auto's can feel sluggish. but with 80 or more hp at the wheels it is a dream to ride and a dream to tow trailers. It has become a totally different animal. With both hands on the bars!
    You can see the auto selector in this pic.
    http://www.youtube.com/watch?v=HXwh4z8d66o
    Subaru ea81 SPFI manifold, 32/36 carb, VW auto
    Trike talk trike of the month Jan 2012
    N3W (Aust) most outstanding trike 2012
    UKtriker trike of the month June 2012
    90+ Posts
    Mar 2012
    Osage Beach, MO. USA
    Just like Duane, my Roadhawk has auto tranny with 140 h.p. Shift into drive and don't worry about shifting again until you stop. Plus, my RH cruises easy at 80 mph without a sweat.
    2 bb
    Dec 2012
    Mackay, Queensland. Australia
    Quote Originally Posted by vwmaniac View Post
    Now ya talkin!
    Dec 2012
    Smoky, tell me again why we have full autos?
    pilch
    20+ Posts CAG's Avatar
    Aug 2018
    Fleming Island, Florida, USA
    Quote Originally Posted by 2blackbelts View Post
    2 bb
    Hi Doc, I'm curious ... are your RPM's around 4K at 80 MPH? Mine are 3K at 60, 3.5K at 70 and 4K at 80. 70 MPH yields @ 18 MPG Hwy. Thanx, ^v^
  19. #19
    Quote Originally Posted by CAG View Post
    Hawk......The post you are Quoting is from 2012......And CAG-Doc. Hasn't been online since 2017........
  1. Which is the smoothest riding trike?
    By Calgary in forum Miscellaneous
    Last Post: 11-03-2013, 05:51 PM
  2. Custom Dynamics
    By FLTR2008TRIKE in forum Accessories
    Last Post: 12-18-2012, 11:05 AM
  3. New Guy, Trike riding experiences?
    By kens09 in forum New Member Introductions
    Last Post: 07-09-2011, 01:40 PM
  4. My trip to Traxxion Dynamics, the suspension upgrade experts.
    By mpolissky in forum General Discussion
    Last Post: 06-18-2010, 10:24 PM
