Results 1 to 16 of 16
Thread: front tire for TriGlide
    Mar 2011
    Boise Idaho
    Default front tire for TriGlide
    Can any one tell me if there is a replacement front tire like a mpa or bt 45 for a TG ? thanks
    60+ Posts
    Sep 2008
    knoxville tn. usa
    Default Re: front tire
    Michelin is making the Commander II for the Harley"s. I have had one for about 6,000 miles and it seams to be wearing better than the Dunlap's. Most Harley dealers are carrying them and they are a little cheaper than the Dunlap's. Hope that helps!!!!
    Oct 2010
    USA
    yea just looked up that commander 2 tire and people are really liking them over the dunlops..
    Contributing Member lzski326's Avatar
    Nov 2008
    Mark, Illinios 61340
    I'm sticking with the Dunlop. i got 17000 out of the first one, and 18000 on this one and still dont look to bad. just my opinion.
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    Just bought a new Dunlap, hope it wears as good as the last one. Got over 20,000 and still counting , but plan on changing soon.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Really like the way the Commander II performs. I am also using the Micheline HydroEdge on the rear. The two seem to go together real well.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Oct 2010
    USA
    Quote Originally Posted by Keystone View Post
    What difference are you feeling seeing with these tires?? One day I will have to replace the tires and like to make a decision on what to buy in the future.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I don't know how everyone is getting such high milages, but I just turned 10k and the front stock tire is in need of a replacement. Today I'm having the dealer put a rear tire (not trike rear tire-lol)on the front in reverse and see how that works.
    Oct 2010
    USA
    what tire pressure are you running on the front?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Most of the trikes are running tires that were originally intended to be rear tires on the front of their trikes. Reversing the rotation makes a rear tire suitable for a front position on a trike and the extra tread depth makes them get better mileage. I wouldn't suggest that for a 2 wheeler even though the double-dark-siders are doing just that.
    I was using the Michelin Commander on the 16" front rims of the Harley-Davidson, but for about the last 20 customers I have changed to a Dunlop GT501 130-90-16. Looks more like a front tire and I think it will eliminate any hydroplaning.
    Dunlop GT501 Sport Bias Rear Tire - Street Bike - Motorcycle Superstore
    Jim Murphy
    Iron Butt Rider 2001
    GLEN ELLYN, IL. USA
    Dealer said he will put a Dunlop rear tire on the front in reverse.
    He didn't want to until he read the forum.
    100+ Posts hdruss's Avatar
    Mar 2011
    chicago,illinois
    GaryD can you talk a little bit more about using a rear tire on the front. Is this a stock rear tire from an Ultra or something else?
    Pforzheim, Germany
    Hello,
    i use the Michelin Commander II on front, and on rear Michelin Energy Saver and are very happy.
    Reg. Günter from Germany
    Sep 2009
    Near Myrtle Beach SC
    Quote Originally Posted by hdruss View Post
    Here is a older posting that will answer your question >>
    http://www.triketalk.com/forum/harle...nt-tire-11544/
    50+ Posts
    Nov 2011
    Carencro, LA, USA
    My 2012 trike is the 4th Harley that I have owned and I have never had any issues with the stock Dunlop tires. On my 2009 Streetglide I got almost 18,000 miles on the back tire and more than that on the front tire and this was the same time that Harley had a recall on tires. I have a little over 10,000 on my trike and they all look like I just rolled off the showroom floor. Harley uses them for a reason and I am a believer in the "If it isn't broke, don't fix it" theory.
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    4Harleys? 2wheelers are different as comparing Oranges to Grapes. The tie has a different job to do on a Trike. The sidewall needs to be stiff. Argue all you want. The rear tire bias ply is the only choice.
  1. TriGlide Front Tire
    By tjmac49 in forum Harley Tri Glide
    Last Post: 07-10-2018, 08:22 PM
  2. Front Tire Again
    By Smitty Werben Manjensen in forum Harley Trike Conversions
    Last Post: 04-21-2013, 08:00 AM
  3. front tire
    By trucker in forum Honda Trikes
    Last Post: 08-03-2011, 08:51 PM
  4. Front Tire
    By subeetrikerdon in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-16-2010, 11:22 PM
