Likes Likes:  4
Thanks Thanks:  2
Results 1 to 16 of 16
Thread: Rear brake pads
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Default Rear brake pads
    Looking at EBC rear brake pads, they have double sintered pads and semi sintered pads, those of you that have used these pads which did you use and what did you think of the performance.
    I used the double sintered on my 2011 Tri-Glide I didn't have any problems with them and much better stoping power than with the stock pads......
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    hey steve, i had them on my 16 for about 2 yrs (double).. lots of dust,but worked well. when time for the 20, i will go back to lyndall gold. used for years on 2 wheeler. best ever for me. they had quit making for trikes ,but have started again.
    I am using these, way better than OEM with very low dust
    https://www.jpcycles.com/product/804...ear-brake-pads
    Jan 2009
    MA,
    I just purchased the EBC double HH front and rear for my 20 have not installed yet , stock pads have to much dust , I could not find Lydell that fit a 2020 ? I will install when I replace my two bent rear wheels, put them on the tire balancer a while back and I don't Know how they got that bent ? What sucks is I sent then out & had them PVD coated black chrome , which was not cheap .
    Dec 2013
    Clarion PA USA
    Are you sure you got your wheels back? Just sayin...
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Call them. I know they have for 2019, so I bet they fit the 20, maybe have not updated the list
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    checking EBC website "Harley Davidson Trike FLHTCUTG Tri Glide Ultra Trike 2014-2021
    I would think Lyndall would fit also same years.
    Jan 2009
    MA,
    On my 20 the rear brake pads do not look like the picture Jack posted ? But I have not installed tem yet .
  11. #10
    Jan 2009
    MA,
    Quote Originally Posted by Fearless View Post
    Yes bent, put them on spin balancer side to side one is 90 thousand's the other 120
  12. #11
    Dan, here is the EBC fitment
    • Harley-Davidson®
      • Trike Freewheeler FLRT : 2015–2020
      • Trike Tri Glide Ultra Classic Anniversary FLHTCUTG : 2018
      • Trike Tri Glide Ultra Classic CVO FLHTCUTGSE : 2020
      • Trike Tri Glide Ultra Classic FLHTCUTG : 2014–2020
  13. #12
    Jan 2009
    MA,
    [QUOTE=Jack Klarich;806041]Dan, here is the EBC fitment
    • Harley-Davidson®
      • Okay I went back and checked tri glide brake post , the poster PTR has a2020 tri glide screamin eagle and wanted to to change pads the post was started on 2/6/20 he had a hard time to get rear pads , he ended up with part # FA631HH , if you look them up it say's that they fit Spyder's ? They fit 2020 tri glides also , I bought the one's you have pictured on ebay and they don't fit . check out that post you will see ?
  14. #13
    Look @ part number Mfr Part #: FA641/4HH EBC rear pads
  15. #14
    Jan 2009
    MA,
    Mine are the FA631HH the FA641/4HH do not fit 2020 Look back at the post by PTR . check it out
  16. #15
    Jan 2009
    MA,
    I never thought of that ??????????????????????????????????
  17. DKCustoms postbit
  18. #16
    It looks like the calipers changed in 2020, that would explain the change of design on the pads
  1. Rear Brake Pads
    By FRR in forum Harley Trike Conversions
    Last Post: 03-31-2014, 11:43 PM
  2. rear brake pads
    By arnie in forum Harley Trike Conversions
    Last Post: 02-23-2014, 08:40 AM
  3. Rear Brake Pads 2013 Tri Glide
    By JJHog in forum Harley Tri Glide
    Last Post: 07-23-2013, 07:37 AM
  4. Rear brake pads
    By tri glider in forum Harley Trike Conversions
    Last Post: 03-13-2012, 08:43 AM
  5. replacing pads on rear brake
    By wriddle in forum Harley Trike Conversions
    Last Post: 02-14-2012, 08:03 AM
