Likes Likes:  28
Thanks Thanks:  1
Results 1 to 20 of 27
Thread: Manual Pump for Air Shocks
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default Manual Pump for Air Shocks
    Alright, after much research & reading 1,000's of reviews, I ordered a hand pump for adjusting the air shocks on our Freewheeler & I am sure it will work on other models also.
    It is a AlphaMoto Air Shock Pump For Harley Air Shocks 0-60 PSI.
    I have played with it for 2 days now & I am declaring it a winner.
    It is well made, compact & very accurate. It has a bleeder valve for micro adjusting the air down to the perfect setting & when you unscrew the hose from the fitting, I saw/heard no air loss. It was on E-Bay for $23.85 with fast, free shipping.
    Here is a link:
    https://www.ebay.com/itm/AlphaMoto-A...97.m4902.l9144
    Oct 2017
    St. Louis, MO USA
    1 other item. In my research, I found some pumps that look very similar, but have a 300 psi gauge & you are better off with 1 in the 0-60 range as our max pressure on our air shock system is 50psi.
    I keep mine in the 15-20 psi range. I think the higher range is for mountain bikes front suspension.
    Good find Michael, probably better than the HD one and cheaper 2
    Oct 2017
    St. Louis, MO USA
    Thanks Jack, I forgot to mention, this is compact, lite & would travel very well. I'm guessing it's about 8-9" long.
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Does anyone use these to check tire pressure?
    Bill
    R I P MANDY
    Quote Originally Posted by BillR View Post
    I use a Ryobi battery powered air pump, Its digital, I just set the dial to the PSI i want press the button and it stops at the set PSI..
    Oct 2017
    St. Louis, MO USA
    I have a digital tire gauge that I like, but I would not want to try to pump up a tire with this, as it's a low volume pump.
    I guess you could use it as a tire pressure gauge, but screwing it on/off would get tedious.
    4750+ Posts
    Mar 2015
    Texas
    I already had a Fox Racing hand pump and you are right about being careful with the use of it. But you lose 2 to 4 pounds of air putting the pump on and off so figured, why not use it. It works just fine. Mine goes to 150 pounds. Work fine on my 07 electra Glide and works fine with my Indian now. Although I got another from Indian anyway. I person might think they could air up a tire and I suppose you could but it really does put out a very small amount of air. There are better tools for tires.
    https://www.ebay.com/itm/FOX-RACING-...FXDvzO&vxp=mtr
    American Legion Rider
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Might take some time ..... a week or two .....
    Name:  big flat tire.jpg
    Jim Murphy
    Iron Butt Rider 2001
    Oct 2017
    St. Louis, MO USA
    I got a 50 mile ride in and it was fantastic! I really enjoy the Freewheeler & was missing the fun during our recent cold stretch.
    Before I left, I checked the tires & set the front to 34psi & the rears at 24psi. I had been running the front at 36 psi per the manual, but it just looked a little overinflated, judging by the wear pattern. I'll see if this helps with the wear.
    I stopped & took 2 psi out of the shocks & it was a smoother ride, coupled with the rear tire adjustment. 20 psi in the shocks is too much for me for 1-up riding.
    The 0-60 psi gauge is better for this application because you don't want to use any gauge in the bottom or top of it's range. You get your best accuracy in the mid-range of it's scale.
    1000+ Posts dannymax's Avatar
    Jan 2018
    Upper Hudson Valley, NY
    Based on MDO's recommend I grabbed one of these pumps off fleabay for $24 and have to agree....the little pump is well made, works smoothly and would travel easily in the corner of the trunk. I'm glad I got it, thanks for passing this on MDO.
    Here's the link....unfortunately the guy doesn't have any more available at the moment.
    https://www.ebay.com/itm/AlphaMoto-A...72.m2749.l2649
    2017 Freewheeler
    Billet Silver
    Compassion for animals is intimately connected with goodness of character....and it
    may be confidently asserted that he who is cruel to animals,cannot be a good man.
    Oct 2017
    St. Louis, MO USA
    Glad you got 1 dannymax.
    Im happy with it. Just for grins, I hooked it up to my tires & used the bleed valve to take out a couple pounds.
    The analog gauge is consistent with my digital tire gauge.
    Jan 2018
    Gotta be honest here....10# is just not enough shock air for a 6' 5" 240 pound driver! But after putting in another 20# with my new little pump the difference was like night & day! Went for a quick test ride around the block and didn't come back for an hour & a half!! The 'block' grew & grew!!
    2017 Freewheeler
    Billet Silver
    Oct 2017
    St. Louis, MO USA
    It's a burden when you have to do test rides for research, but someone has to do it.
    I have been running around 20 lbs. in my air shocks on my FW.
    I also settled on 34 in the front tire & 24 in the rears & I'm happy with that set-up.
    Jan 2018
    I haven't done any tire pressure experimenting yet but 34/24 sounds like a good combo to go with. And I now have the technology to drop 1/4 lb. from any chosen tire should I decide to...kinda like Dale Earnhardt!
    2017 Freewheeler
    Billet Silver
    Jan 2018
    It's a huge burden for sure MDO....but never being one to shirk responsibility I slogged thru endless miles & hours in the interests of research.!
    I'm currently at 21 lbs and it seems to be pretty friendly....I will continue the research tho.
    2017 Freewheeler
    Billet Silver
    Oct 2017
    St. Louis, MO USA
    Something else I have noticed about the FW shock system on my trike & I am very happy with is that it does not loose any pressure. After close to a year of ownership, I am glad to state there are no leaks at all.
    I should not say this too loud, but I am definitely 1 of the lucky ones as far as the quality & finish of my FW. No issues to date. They need to rear their ugly head soon, as I am approaching my last year of factory warranty.
    Jan 2018
    Same here on the no loss of pressure MDO, pretty surprising really cuz there's potholes around here that could swallow up a Peterbuilt! Well, most of one anyhow!
    2017 Freewheeler
    Billet Silver
  19. #19
    OOOPSSSS Now ya did it
    I sure hope you have not jinxed your self
  20. #20
    90+ Posts Saammi's Avatar
    Jun 2018
    CT, USA
    Just ordered one on Amazon.
  1. Parts manual/ service manual
    By ODDOMAN in forum Stallion Trikes
    Last Post: 02-11-2021, 08:01 AM
  2. Fairing - Air Vent
    By Thomas L in forum Harley Tri Glide
    Last Post: 08-21-2020, 05:16 AM
  3. air shocks pump
    By glaswurks in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-04-2018, 09:37 PM
  4. AIR RIFLE
    By BIG DENNY in forum The Gun Enthusiast
    Last Post: 01-01-2018, 12:29 PM
  5. Air pump for RZ seat
    By OldFart in forum Harley Trike Conversions
    Last Post: 06-22-2016, 01:33 PM
