Likes Likes:  766
Thanks Thanks:  3
Page 12 of 46 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 221 to 240 of 913
Thread: Anyone else?
  1. #221
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Shaping up and nearly to size.
  2. #222
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    They remind me of the mofoco heads. But there valves were smaller lookin. Great job though.
  3. #223
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    That they are. The 050 heads.
    Other than they were 54cc and a step, they are fine for a smaller engine.
    These are 42 in, 37.5 out. No step, 60cc chamber now.
  4. #224
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Not much done lately.*
    Frame sand blasted.
    Put some filler on the top joints.
    Priming and smoothing down the see me pieces.
    And yes.
    That is on the front porch where i can hit it a lick every now and then as i pass by.
  5. #225
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Are you going to paint the frame or have it powder coated?
  6. #226
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Paint.
    No place local (including myself ) that does powder.
    I have a lot of stuff i would like to powder.
  7. #227
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Cutting notches in lifters.*
  8. #228
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Lifters done. Cam de-burred and chamfered.
    I am thinking i will drill oil squirters in the 1.4 ratio rockers.
    Researching spark plugs.
    Gotta find something that fits the aftermarket heads, heat range, the modified chambers, and the ford coil.
    This might be the one.
    Now i gtta get back on the machine work on the heads.
  9. #229
    good job. coming along well
  10. #230
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Still ever so slow.
    So busy with my girlie, with STEM Academy, choir, band, robotics club and the city theater guild. I have spent a lot of time with her hualing her around. Then helping her robotics team.
    I gotta get focused back on my project and finish something.
  11. #231
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    Still ever so slow.
    I for one understand what your saying,,, I been working now and then on my trike build I too need to give my project a little more time as I would really like to get a ride on it this coming summer!! so
    "here's hoping you find the time to finish your up"!!
    myself and many others will be excised to see the results
    magoo
    mike aka magoo
    hd sidecar rig/building v6 supercharged trike
    "even a blind squirrel finds a nut once in awhile"
  12. #232
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Still no more progress with the trike.
    Robotics competition day for my little girlie.
  13. #233
    How'd she make out?
  14. #234
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Just got home, pic uploading.
    Gimme a minute
    The winning team.
    Can you tell which one is mine?
    First place trophy and a golden ticket, free pass to state finals including entry fee for the team.
  15. #235
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Frigging awesome Rex!!!!!!!!!!!!!!!!!!!!!!!!!!
  16. #236
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    That's the way to do it. Congratulations , and give um hell !
  17. #237
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Sorry folks.
    I lost a few pics on photobucket. The phone app seemed to crash. Was endlessly uploading the same batch of pics over and over. I had to delete the whole upload to stop it. It was only one of the more recent batches of pics. Hopefully it all works like it should now.
  18. #238
    Way Kewl
  19. #239
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Back on the oil pump.
    Cut o ring grooves in the body and the face for a positive seal on the suction side.
    Plugged the pump outlet.
    Then moved the outlet over and out the face.
    So now it looks like this inside the pump.
    And this on the outside.
  20. #240
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Oh holy crap what an awesome idea putting orings on the face and body!!!!
    Crap, I should send ya a pump and have you cut the oring groves!
    Just a guess, but are the body orings a 200 series and the face a 100 series oring?
    And just a suggestion; I would use Buna 90 durometer and not 70 durometer due to the heat around the body of the pump. 70 durometer would probably be fine for the face.
    Man o' man what a great idea though!!!!
    Hmm, I have an extra pump and a buddy of mine that has a lathe. I might give that a shot...........If ya don't mind me using your idea brother.
