Likes Likes:  3
Results 1 to 20 of 20
Thread: Lower faring container
    70+ Posts Tomswede's Avatar
    Jul 2018
    Lugoff, SC, USA
    Default Lower faring container
    Does anyone know what this little container in the right side of the lower faring is for?
    it appears to be empty?
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Quote Originally Posted by Tomswede View Post
    Yep it is your coolant reservoir. Should be full to the line on it. Might want to get it checked out - see your owners manual or service manual.
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    For antifreeze.
    Its the overflow/return tank for the radiators , When you fill it make sure you use the right antifreeze, That bottle looks awful clean....Is it a new Trike...And if so bring it back to the dealer...
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Your welcome
    Jul 2018
    Lugoff, SC, USA
    Thanks, no it's a 2016 bike, bought it used last year, have only put 1k miles on it
    Jul 2018
    Lugoff, SC, USA
    Quote Originally Posted by Koolbreeze View Post
    Thank you, got the bike used, not sure it came with either om or sm, but it sounds like something important , so worth looking in to
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Looking at your profile Tom, you state your engine is a 117 SE, what I don't know is if the 117 is even water cooled if it was an upgrade from stock. My suggestion is to find out fairly soon about it.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    2016 tri is a 103 engine & water cooled. Nice to have a 117 but not sure if water cooled. Are you sure it is 117 ?
  11. #10
    Jul 2018
    Lugoff, SC, USA
    Thanks for your question , when I bought the bike I got paperwork showing the bike originally having the 103 engine with water cooled heads, the original owner had HD install
    the Screaming Eagle stage 3 kit with the larger components to supposebly bring it to a
    117 ci engine, what confuses me is there is a see-thru container mounted on the frame in front of the gas tank that I thought was the coolant reservoir ,
  12. #11
    Jul 2018
    Lugoff, SC, USA
    This is the other container
  13. #12
    That looks like your rear brake mater cylinder resivour
  14. #13
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    That container is for brake fluid.....
    I just did a search.
    Harley's new Screamin’ Eagle Stage III 103 Performance Upgrade Kit (P/N 92500028, $969.95) may give your bagger that extra grunt for smoother running uphill. This street-legal, Stage III kit gives 2014-later Harley-Davidson Touring models with an Original Equipment Twin Cam 103 engine a boost in everyday performance while maintaining the factory warranty. Designed for use with stock cylinder heads, this street-performance kit produces big torque gains at lower RPM, with the potential to produce 88 horsepower and 100 lb-ft of torque.
    The Stage III kit includes high-compression 10.5:1 pistons, big torque SE-585 cams, Perfect Fit pushrods, a high-performance diaphragm clutch spring, high-lift valve springs and gaskets. It does not fit Trike or Twin-Cooled models, and installation requires the separate purchase of primary cover gasket. All EFI-equipped models require ECM calibration (priced separately). See an authorized Harley-Davidson dealer for details. Labor cost not included.
    NOTICE IN THE info "It does not fit Trike or Twin-Cooled models"
    I think you need to have a dealer tell you WHAT you have.
  15. #14
    Jul 2018
    Lugoff, SC, USA
    First, let me thank you for educating me about my bike, now, I went back to my paperwork
    and I need to revise my previous info, it shows a part no 92500018 described as a stage 4
    race kit for the 103 CI engine
  16. #15
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I like the perfect fit pushrods
  17. DKCustoms postbit
  18. #16
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    So all this being said ,you have a 103, which is water cooled & you need some coolant in that tank. A bottle is around $12. fill to the line (a little hard to see) line is around half way up. Fill by pulling out the rubber plug. Run a bit & check again. You may need to do a few times as Dealer told me getting all the air out of this system can be hard. Best of luck Still think you should go to a dealer to find what you have ..I can't find that part #
  19. #17
    Yea.....It would be a bummer with Un-Perfect fit pushrods........
  20. #18
    Dec 2012
    Santee
    The rear brake fluid reservoir is mounted in front of the gas tank.
    Ray
    2017 Harley Triglide
    Tijuana Border
  21. #19
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Sooo, how about an update here. Did you ever find out what you have ??????
  22. #20
    Dec 2013
    Clarion PA USA
    Welcome to the forum from Western Pennsylvania good luck figuring out what exactly you have travel safe Fred.
  1. Indoor Shooting Range In A Shipping Container
    By WOTS in forum The Gun Enthusiast
    Last Post: 03-30-2017, 06:24 AM
  2. Reckless Faring on a Free Wheeler
    By Byrdman9942 in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-16-2017, 10:31 AM
  3. Expanding...into a Container!
    By DK Custom Products in forum General Discussion
    Last Post: 02-01-2017, 07:00 PM
  4. 2014 Triglide Faring and fender Bra
    By Alan Oakley in forum Harley Tri Glide
    Last Post: 07-15-2014, 07:48 AM
  5. Faring
    By whitefatboy in forum Harley Trike Conversions
    Last Post: 05-14-2011, 05:34 PM
