SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  1
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: Erickson wheel chock kit
    90+ Posts
    Nov 2019
    Omaha NE
    Default Erickson wheel chock kit
    Anyone use this product or something similar to tie down the rear of their Trike?
    https://ericksonmfg.com/product/whee...and-strap-kit/
    Quote Originally Posted by Blueraven View Post
    Those wheels on the side by are clear of the fenders but with a Tri-Glide I don’t think you can get the straps around the tires with out damage to the fenders?
    90+ Posts
    Nov 2019
    Omaha NE
    The way the fenders are on a Tri-Glide you’re probably right this setup wouldn’t likely work.
    However on a Freewheeler which is what I’m tying down the fenders flare out in the back so access shouldn’t be an issue.
    Free wheeler or triglide it definitely won’t work on the front tire don’t know about the free wheels but tri-glides come with tiedowns on the back axle,..
    30+ Posts
    Nov 2021
    Castle Rock, WA, USA
    Default Freewheeler has tie-down loops
    Owner's manual is the same for Freewheeler and for TriGlide:
    2021 HARLEY-DAVIDSON® OWNER'S MANUAL: TRIKE MODELS
    The rear axle has steel loops on the bottom (left and right sides) which may be used to tie down the rear end of the vehicle when transporting on a trailer.
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by Evets View Post
    I know what the books states concerning the hooks in the rear but that’s not what I’m inquiring about.
    What I’m inquiring about is has anyone used the Erickson wheel chock kit or something similar.
    I think for Tri-glide riders the answer is likely no.
    Dec 2012
    Santee
    I have a set of straps that are the same as used on auto transporters with the mounts mounted to the bed of my trailer. it has three attachment points and ratchets down the rear tires. I don't remember the name of the company but they came out of Dallas, Texas.
    Ray
    2017 Harley Triglide
    Tijuana Border
    90+ Posts
    Nov 2019
    Omaha NE
    Well I got the Erickson wheel chock kit installed.
    First; if you’ve got a Triglide save your time and move on this ain’t going to work for you.
    The way the Triglide fenders wrap the wheels in front and back will likely not allow for enough space.
    I think you could ratchet down the straps but there’s not enough clearance to release the straps.
    If you have a Freewheeler, UTV, ATV, lawn tractor or a car to trailer this setup is pretty sweet.
    Installation was easy and it only takes a couple of minutes to strap down the rear wheels.
    I think with this setup all you really need is this kit and you’re good to go.
    I however like to go overboard so I ended up strapping the rear hooks and securing the front.
    Took the rig for a short ride down the highway and down a known bumpy back road and the Freewheeler never moved.
    On a final note; when unloading you have to be on level ground or facing uphill.
    The electric reverse motor isn’t strong enough to get over the rear chock if the bike is facing downhill.
    If you notice in the attached pictures the Freewheeler is facing down a slight slope in my driveway.
    I could not off-load the Freewheeler in this position as I popped the reverse breaker so I had to pull out into the street to get the trailer level.
Size:  1.03 MBName:  EEF54E86-B3F8-4AC2-A311-9E1DDCB6E424.jpg
Size:  1.07 MBName:  DBEE54BE-CC09-453E-9906-BD1E2D513AB1.jpg
Size:  1.08 MBName:  D54F15F1-05AB-419D-8DBF-E2D9F69CB7F8.jpg
    100+ Posts NJtony's Avatar
    Oct 2021
    Manahawkin
    I have them on my trailer. They take a while to install to make sure they are in the middle of both tires to rachet down. I used them for a can am F3 spyder. The thing you have to be carful with is make sure that you are in the middle of the tire when you strap it down. You have to rachet the tire down pretty tight, then after you drive for a while you need to check the straps.
    When I was trailering my Can am one of the straps came off . So check the tie down straps a lot.
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by NJtony View Post
    Very sound advice.
    That’s why unless I’m just taking the Freewheeler someplace locally I would never just rely on the 2 rear tire straps.
    The time and expense to add 2 straps to the rear and 2 to the front end is far less time and expense than trying to get the Freewheeler out of the ditch and back onto the trailer when it decided to egress itself from the trailer.
    Since 2011.. Whenever I have to trailer one of my trikes I just Ratchet strap it on the two hooks on the rear axle and one strap through the front wheel with a towel under the strap to protect the wheel I never had a strap come off/lose or the trike move at all..
    90+ Posts
    Nov 2019
    Omaha NE
    I wanted to post a follow-up on this Erickson wheel chock kit.
    After a few load/unloads it is apparent that getting over the rear chock with the electric reverse in my opinion puts too much stress on the reverse motor.
    Since the front of the rear wheels were tight against the front chocks anyway the rear chocks really weren’t serving any purpose so I decided to remove the rear chocks and replace them with 6”X5” e-track plates.
    These e-track plates provide the same function as the rear Erickson chocks did which is simply a tie down point but are only about 1/2” tall.
    So in my opinion if this type of setup is desired I would simple go with either e-track plates in front and rear of the rear wheels or perhaps better would be to put down two extended length of e-track rails and park the rear wheels on the track, then take two 2” ratchet e-straps and secure the rear wheels.
    In closing just so as to be fair; nowhere does Erickson state that their wheel chock kit works for a Harley Freewheeler.
    I simple thought it was a good idea and decided to try it out.
    I still have a good tie down system but could have gotten the same results a little cheaper than the $50 I spent on this kit
  1. Aluma TK-1 Wheel Chock placement
    By Dockem in forum Honda Trikes
    Last Post: 10-26-2018, 09:56 AM
  2. New Enclosed Trailer for Tri-Glide now to decide on a chock
    By hardwickbv in forum Harley Tri Glide
    Last Post: 12-28-2017, 02:52 PM
  3. Replies: 23
    Last Post: 05-21-2016, 09:22 PM
  4. Condor Wheel Chock in a Toy Hauler?
    By Ohio Eddie in forum Trailers / Campers
    Last Post: 12-02-2012, 04:51 PM
  5. Swivel-Wheel Trailer behind 5th wheel
    By Doc Dyna in forum Trailers / Campers
    Last Post: 10-16-2012, 10:04 PM
