Likes Likes:  24
Results 1 to 20 of 39
Thread: Nitrogen filled tire
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default Nitrogen filled tire
    the previous owner had all the tires fille with nitrogen, I know aircraft runs nitrogen. Does anyone here run it?, pros & cons?
    I fill them up with about 78% nitrogen....I find that works best for me...
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    Me too
    Dave
    14 HD Tri Glide
    H.O.G. Member
    Thumbs up
    Pretty funny
    Pretty funny
    Nitrogen in the tires were A gimmick started by the Florida new car dealers Association many years ago this way they can convince all the old gullible retired people that they have to come back to the dealer and pay for nitrogen in their tires every time they Needed a top off of nitrogen 😱📞
    150+ Posts
    Firewrench22's Avatar
    Oct 2014
    Kingston WA USA
    What I learned is that plain air will leak right through a tire eventually. It's the molecules other than nitrogen that pass through. Nitrogen molecules are bigger, so they don't pass through the tire rubber. If you fill with "pure" nitrogen, you won't lose air over a long period of time. It's also more stable, does not expand as much with heat, that's why NASCAR teams use it. Some Costco's have nitrogen.
    Or, you could just check your tire pressure more often.
    30+ Posts
    Dec 2017
    vienna ga. usa
    good old air works for me
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Firewrench22 View Post
    You are correct sir! It's more stable because it's much dryer than regular air.
    The reason NASCAR tires are inflated with nitrogen, rather than the normal air we pump into our tires, is due to the increased stability under hotter temperatures that the gas exhibits. It allows the tire pressure (Up to 50 pounds per square inch) to remain constant throughout the race regardless of the temperature, which can reach 200 degrees Fahrenheit. (from NASCAR's website)
    100+ Posts GRR's Avatar
    Apr 2017
    Cypress, Texas, USA
    A waste of money
    We are a two trike family: My trike is a 2004 Road King Classic with a Frankenstein conversion. My wife's trike is a 2007 Sportster with a Frankenstein conversion.
  11. #10
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by GRR View Post
    A waste of money
    For our trike's, most definitely.
  12. #11
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    A waste of money
    Another gimmick to separate dollars from your wallet to theirs. Tried it years ago,not worth the $$. Also the more you check the pressure the more of it you lose.
  13. #12
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I have only had experience with nitrogen in our motorhome tires. Month after month, cold or hot weather, the tire pressures remained the same...whether it had been driven or just sitting. It was initially housed in a climate controlled airplane hangar then moved to a storage shed that was open on one end and subject to all seasonal temperatures for several years. Nitrogen worked for us in that instance but have never put it in a car or motorcycle tires.
  14. #13
    True Nitrogen is supposed to seal the tire better than straight air
    I have had doubts about this for years and cannot see paying for what I can get for free JMO
    Keeping in mind air is 78 percent Nitrogen
  15. #14
    4750+ Posts
    Mar 2015
    Texas
    So why don't tires with air or go 78% flat if nitrogen won't go thru?
    American Legion Rider
  16. #15
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Nitrogen in the tires were A gimmick started by the Florida new car dealers Association many years ago this way they can convince all the old gullible retired people that they have to come back to the dealer and pay for nitrogen in their tires every time they Needed a top off of nitrogen ����
    I agree with the above completely.
    Back in the 1980's I experimented with and used nitrogen in my racing gokart tires.
    I had a repair shop so bottled gas was easily obtained.
    I took an old freon tank and used it for nitrogen filled to 90 psi and carried it with me to the races. Small sprintkart tires and small tracks with flat tight turns.
    The air would expand 8-10 psi during a short 10 lap race making for a very slippery kart at the end of the race. Nitrogen didn't expand at all in those tires and I could adjust my race pressures and not have the bad handling characteristics of low pressure, not to mention the chain and sprocket eating the asphalt, until a desired heated air pressure was reached.
    Never thought of using it other than in competition because of benefit over expense.
    Using it for tires belongs at the racetrack and in aircraft ..... or maybe if you are going from the Florida Keys to Pike's Peak .......
    However, I do have a Nitrogen Factory and a bridge for sale in Brooklyn ..... CHEAP !!!!
    Jim Murphy
    Iron Butt Rider 2001
  17. DKCustoms postbit
  18. #16
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Thank you Jim , well explained
    Every thing was fine till the idiot light era arrived!
  19. #17
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Thanks for all the feed back. I'am just going to leave it in there till I have a flat. And I'am a retired pipe line welder so the nitrogen is no problem for me to aquire
  20. #18
    The idiot era arrived when Power Steering' Power Brakes and Auto Transmissions became widely available, To the masses of idiot's who now think that they can drive...
  21. #19
    Pure Nitrogen is supposed to be a better seal and cause less damage to the inner lining of the tires
    I still cannot force myself to pay for it
  22. #20
    I've been using it in everything I own for years. Here in Western Colorado, we have temp changes from 105* during the day to 55-60* at night. Here lately, we have had 15-20* at night and 55* during the day. I am so confident that nitrogen keeps tire pressures consistent, I only ever check it day or two before a long trip. And my pressures never change.
    I even use it in my trailer tires (converted boat trailer to haul bike and a 7'x4' utility I use for work) and I only check tire pressures once a year except if I load the bike for a long trip.
    I'm sold on Nitrogen, of course, Big O here in town doesn't charge to put it in.
  1. Tire Filling - Ambient Air or Nitrogen
    By tndragonrider in forum Honda Trikes
    Last Post: 02-17-2016, 01:40 PM
  2. Nitrogen in rear/front tires?
    By Winger68 in forum Honda Trikes
    Last Post: 01-24-2016, 09:06 PM
  3. GW Trike Engine Oil Over-Filled
    By Goldrush in forum Honda Trikes
    Last Post: 10-16-2013, 08:10 PM
  4. Anyone riding on nitrogen?
    By AzDaven in forum Tires, Wheels, Brakes, Front End
    Last Post: 10-26-2012, 10:35 PM
  5. over filled oil
    By feni in forum Harley Trike Conversions
    Last Post: 12-30-2011, 02:41 PM
