ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  4
Results 1 to 10 of 10
Thread: Throttle assembly/cable whoas
    Jun 2016
    Gold Beach, OR US
    Angry Throttle assembly/cable whoas
    I have had my trike for 6 years and am still having a problem with the throttle assembly and cable. The sheath does not stay in the throttle assembly and the assembly is constantly sticking. It pulls the cable but one released there is too much slack so when I throttle again, there is not enough pull on the carb. I bought a new assembly and am dealing with this problem all over again. I used to use a pipe cleaner to hold the sheath to the assembly and that worked for a while. So frustrated. Do not have a push/pull assembly since VW is single cable. Going to try and lubricate the sheath today and see if that helps. If anyone understands and knows my pain, please reply.
    20+ Posts
    Jul 2015
    Janesville, CA, USA
    Sorry it's being a PITA but if you could load some pics of the connection points, at the throttle and at the carb, it would help to diagnose the issue.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Quote Originally Posted by MdKnightMan View Post
    Kind of what MdKnghtMan stated. The carb connection probably isn't necessary as I'm sure its probably the standard feral with the screw but the hand throttle connection would be a helpful picture.
    And, a huge welcome to TrikeTalk man!!!!! We are all glad you found us.
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    Welcome to Trike Talk!!
    Hope you find the answer to your problem...
    Welcome to the Gang ... the VW guru's here should be able to point you in the right direction.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Sounds like the outer or sheath is not secured at the engine end.
    Just like it has a ferrule and socket at the twist end, it must also have the same at the engine end.
    20+ Posts
    Jul 2015
    Janesville, CA, USA
    I agree with DeathBySnuSnu. If it (the outer sheath) isn't secure at both ends, the whole cable flexes instead of the inside cable sliding and if the cable cannot side or if it has a weak return spring it is going to be a slow return and bind up.
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default Mr trike
    The above answers to the problem are correct. The outer housing must have a stop on both ends. All vw type 1 engines came from factory with a approx. 10 in steel tube that went thru the fan housing. If you don't have one, here is a simple and good way. Buy a 10 in. piece of 1/4 in soft copper tubing and flare one end only. Slide a 5/16 in id washer on tube to flared end. Insert tube from rear side (carb side) thru original hole till it stops.
    Slide a 3/4" piece of rubber fuel line over tube till it contacts fan housing. Secure in place with a hose clamp. Now, Cut another 1" piece rubber hose and slide on end of copper tubing about half way, then secure with a hose clamp. Now, insert inner and outer throttle thru copper tube and secure the outer housing with another clamp. Make sure your choke assembly is off and take all slack out of your inner cable. This has proven to be the best. Also, the copper tube will not rust and cable slides easy. Be sure to lube the inside of housing before putting inner cable in. Good Luck! KEEP-ON-TRIKIN" Dick
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by MR TRIKE View Post
    The above answers to the problem are correct. The outer housing must have a stop on both ends. All vw type 1 engines came from factory with a approx. 10 in steel tube that went thru the fan housing. If you don't have one, here is a simple and good way. Buy a 10 in. piece of 1/4 in soft copper tubing and flare one end only. Slide a 5/16 in id washer on tube to flared end. Insert tube from rear side (carb side) thru original hole till it stops. Slide a 3/4" piece of rubber fuel line over tube till it contacts fan housing.
    That is an excellent answer Dick!!!!!!!
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Throttle
    Hello, If your problem is at the handel bar and not the motor, it made me crazy for awhile. I bought a new cable from Rat Race Prod. in Az. and the throttle assembly from some place else. The brass cap on the cable shieth, at the handel bar end, was too big to fit into the shieth adjuster on the bottom of the throttle assembly. I know, that sounds as clear as gumbo mud, but it's the best discription I could come up with. Any way, I used a short piece of black fuel line split down one side. I slid one end of the fuel line over the shieth adjuster neck on the bottom of the throttle assembly and secured it with a very small hose clamp. I slid the brass end od the shieth into the other end of the fuel line and secured it with a very small hose clamp. After a couple minor adjustments, it has worked well for about 20k.
    If I misunderstood your problem, I appologise for taking up so much space. Thanks for your time,
  1. Throttle Cable
    By pddgm in forum VW Powered Trikes
    Last Post: 04-21-2015, 11:12 AM
  2. Another throttle cable question.
    By gospicker in forum VW Powered Trikes
    Last Post: 07-31-2014, 01:12 PM
  3. Throttle cable
    By stockhatch in forum VW Powered Trikes
    Last Post: 07-17-2013, 08:47 PM
  4. Throttle assembly and Cable issue…
    By Shadowlord in forum VW Powered Trikes
    Last Post: 12-25-2012, 11:22 AM
  5. throttle cable
    By wildwest in forum Stallion Trikes
    Last Post: 07-13-2012, 06:49 AM
