Likes Likes:  4
Thanks Thanks:  1
Results 1 to 20 of 20
Thread: Trike vw motor delantero
    Jun 2019
    Tuxtla gutierrez chiapas México
    Default Trike vw motor delantero
    <font style = "vertical-align: inherit;"> <font style = "vertical-align: inherit;"> Hola me interesa saber cómo realizar un triciclo con el motor y el motor debajo del tanque de combustible mis principales dudas son como Invertir en el movimiento de los neumáticos y leer en la palabra y en la corona y en el piñón, pero no sólo en la información más concreta en cómo y en algunos consejos/
    Hello, I am interested in how to make a tricycle with the engine and the engine under the fuel tank. My main doubts are how to invest in the movement of the tires and read in the word and in the crown and in the pinion, but not only in the more concrete information on how and in some councils. trike with vw engine . trike con motor vw </font> </font>
    Jaime........Welcome to Trike-Talk.... , Thats a nice looking Trike.....
    ..I wonder if someone can translate the Tex from Spanish To English.........
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Huston—— We have a problem.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Muy Bueno, VW...
    My Espanola is poor at best, and I'm too old to go back to high school for Spanish-I......
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I have built one.
    Look at the stickies at the top of page.
    My thread "Anyone Else" has my latest build.
    As far as the crown gear....you must have a two side cover trans. You can then pull the crown and drive out one side and put it into the other side. This reverses the drive direction.
    I did mine by flipping the entire trans. I would not recommend that for anyone unfamiliar with the internal workings of a vw trans. The trans must be fully disassembled and internal machine work done. Then fully assembled.
    I have prints on the drive adapter and the input shaft for the extension housing if you pursue.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    And......
    That is me in the top pics....just a long time ago.
    It looks like this now.
    The valkyrie still looks the same.
    Stock off the shelf Honda. You can buy them all day on ebay.
    jaimi welcome aboard
    Cool Pictures, Welcome to Trike Talk
    Jun 2019
    Default Traducción al inglés/ traslation to english
    [QUOTE = JVA; 679540] <font style = "vertical-align: inherit;"> <font style = "vertical-align: inherit;"> Hola me interesa saber cómo realizar un triciclo con motor y el motor debajo del tanque de combustible mis principales dudas son como Invertir en el movimiento de los neumáticos y leer en la palabra y en la corona y en el piñón, pero no sólo en la información más concreta en cómo y en algunos consejos. trike con motor vw </font> </font> [/ QUOTE]
    Traslation:
    Hi I am interested in how to make a tricycle with the engine under the fuel tank would be with the engine of a vw, I would be grateful if you gave me ideas or directions on how to reverse the rotation of the tires (read about changing or rearrange the pinion and the crown) or if they have information on which gearbox can be adapted to said vw engine to follow the control scheme of the traditional motorcycle (the gear change in the foot), I attach some images of my main inspirations of; Thank you in advance and sorry for my bad English
    Jun 2019
    [CITA = JVA; 679540] <font style = "vertical-align: inherit;"> <font style = "vertical-align: inherit;"> Hola me interesa saber cómo realizar un triciclo con motor y el motor debajo del tanque de combustible mis principales dudas son Invertir en el movimiento de los neumáticos y leer en la palabra y en la corona y en el piñón, pero no sólo en la información más concreta en cómo y en algunos consejos. trike con motor vw </font> </font> [/ QUOTE]
    Traducción:
    Hola, estoy interesado en cómo hacer un triciclo con el motor debajo del tanque de combustible sería el motor de un motor Vw. Le agradecería que me diera ideas o instrucciones sobre cómo invertir la rotación de los neumáticos (lea sobre el cambio de reorganizar el piñón y la corona) o si tiene información sobre la caja de cambios Se puede adaptar a dicho motor vw para seguir el esquema de control de la motocicleta tradicional, adjunto algunas imágenes de mis principales inspiraciones de; Gracias de antemano y perdón por mi mal inglés
    Jun 2019
    Default Muchas gracias por la información / thanks for the information
    [QUOTE = DeathBySnuSnu; 679587] He construido uno.
    Mira las notas adhesivas en la parte superior de la página.
    Mi hilo "Cualquier otra persona" tiene mi última versión.
    En cuanto a la corona dentada ... debe tener una cubierta de dos lados trans. Luego, puede jalar la corona y expulsar un lado y colocarlo en el otro lado. Esto invierte la dirección de la unidad.
    Hice el mío al voltear todo el trans. No lo recomendaría a nadie que no esté familiarizado con el funcionamiento interno de una vw trans. La trans se debe desmontar completamente y el trabajo interno de la máquina debe realizarse. Luego totalmente ensamblado.
    Tengo impresiones en el adaptador de la unidad y en el eje de entrada para el alojamiento de la extensión, si continúa. [/ QUOTE]
    Muchas gracias por tu respuesta, podrías darme más información sobre como construiste tu trike y de ser posible adjuntar planos o medidas gracias por aclárarme sobre como invertir las ruedas
    Traslation:
    Thank you very much for your answer, could you give me more information about how you built your trike and if possible attach drawings or measures thank you for clarifying how to invert the wheels
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    See above reply.
    Also look at this for foot shifting.
    You will have to get very creative to invent a way to pull a car clutch with a hand lever. It can be done with shear gorilla like grip strength or you could come up with some kind of power assist servo.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Mine is mostly hand built without any instruction or plan.
    When I first built it (old black pictures) it was just a functional design. Whatever works the way I wanted it too design.
    The current rebuild is just way over the top. A lot of custom machining.
    I have the drive adapter drawings in .dxf format if you want those.
    Welcome to the Gang from Western Colorado.
    Jun 2019
    Me encanta la idea de la palanca muchas gracias por compartirla y me favor envíame los esquemas que mencionas, respecto al embrague que me recomendarías para poder usarlo en el manillar
    Traslation:
    I love the idea of ​​the lever thank you very much for sharing and please send me the schemes you mention, regarding the clutch that you would recommend me to use it on the handlebar
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    https://www.triketalk.com/forum/thre...e-to-handbrake
    Give me an email address and I will send some files.
    Just remember that a very very large amount of what you are considering doing is NOT anything you can buy. YOU will be making a lot of parts.
    Are you up to it?
    It will be cool and your own!
    But you are going to need a lot of desire and drive to get it done.
    Jun 2019
    Are you up to it?
    Jvaloraguilar@outlook.com
    70+ Posts
    Feb 2017
    West amherst new York usa
    Default Wow!
    I'm not shure which is cooler...the in-line shifter mechanism for a vw transaxle, or the fact of an english-speaking guy helping a spanish-speaking enthusiast build a one-off trike over the internet!!
  19. #19
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yeah......Luis is in Brazil.....that is Portuguese he is speaking.
    You can call him he speaks English just fine.
    There is one of his shifters here in the vw forum.
    I am just a waiting on that person's build project to get going again.
  20. #20
    70+ Posts
    Feb 2017
    Like I said, wow!, looking forward to reading about that project. Would you be kind enough to provide a name or link? I don't know if I have the skills to build a shifter like that.
  1. Replies: 3
    Last Post: 08-08-2016, 09:32 AM
  2. Motor Trike announces a new Reverse Trike
    By tndragonrider in forum Honda Trikes
    Last Post: 03-13-2016, 02:04 PM
  3. Motor Trike fixed our trike out of warranty
    By Skippy49 in forum Motor Trike
    Last Post: 11-19-2015, 09:23 PM
  4. purchased 03 GW trike (motor trike)
    By Bangngearz in forum Motor Trike
    Last Post: 05-26-2012, 06:33 AM
  5. Just bought a Valkyrie trike by Motor Trike.
    By skynyrd in forum Honda Trikes
    Last Post: 09-05-2011, 05:09 PM
