Likes Likes:  33
Thanks Thanks:  7
Results 1 to 20 of 22
Thread: cruise control not working
    May 2019
    Booneville
    Default cruise control not working
    my wife's freewheeler cruise control doesn't work. the light comes on, but doesn't set. is there anything I can check?
    Gary i can't help you But i can and will Welcome you to Trike-Talk......
    And i'm sure someone will chime in soon with the help you need...
    May 2019
    Booneville
    thanks
    Gary Welcome to Trike Talk
    Have you done any thing to the trike recently?
    Are your brake lights working OK both front and rear brakes turn on and off brake lights?
    If not you may have a brake light switch problem
    Follow the below link to check your trike for stored error codes
    https://dgcustomcycle.com/tech/harle...es-04-present/
    Have a look here also
    May 2019
    Booneville
    I'll check those out and get back. thanks
    If you messed with the hand controls check them.
    #1, very easy to break the front brake switch if 1 is not careful
    Here is a picture of how to protect the switch when working on and around the switch
    https://www.triketalk.com/forum/thre...Switch-Caution
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I was wondering if you would remember that diagnostic. That is a great tool.
    We need to make that a sticky.
    I remember because you posted it
    Always like to read your input ( Very Valuable stuff) and I agree it should be a sticky along with a lot more info contained in these forums
    IMO we cannot have enough info
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    I think Jack is on the right track. I just got a cruise control working again by cleaning sockets and grounds and replacing the tail light bulbs. They were lighting up, but I thought they were ticking fast. The ticking slowed with everything fresh, and the cruise works now.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Done.
    Does that work on a Tri too???
    Scares me to just start pushing buttons ..
    Oct 2017
    St. Louis, MO USA
    Yes!
    Oct 2017
    St. Louis, MO USA
    Done.
    Zook, I was referring to this diagnostic video on troubleshooting your HD cruise control system.
    https://www.triketalk.com/forum/thre...Tools-Required!
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Stickied this one too...
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Quote Originally Posted by rodekyll View Post
    Jack has saved the day for many of us.
    Quote Originally Posted by LadyonaMission View Post
    More than once.
  19. #19
    May 2019
    Whately, MA. US
    Default Switch Pack Issue?
    I recently sent my Tri Glide to the shop because it would not start in gear. Started fine in neutral. They said the neutral saftey switch was bad, but had to replace the left switch pack which included the cruise control. (Was covered under the warranty) I don't know if your switch pack could be the problem. Just a thought.
  20. #20
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by cartobum View Post
    The Tri Glides seem to have a lot of problems with those left switch packs...Hopefully, they have addressed the issue.
  1. Cruise control stopped working
    By wimoonshiner in forum Harley Tri Glide
    Last Post: 08-13-2017, 04:52 PM
  2. Goldwing cruise control not working
    By slimfin in forum General Discussion
    Last Post: 05-17-2017, 09:44 PM
  3. Cruise Control Not Working...
    By Markie in forum Stallion Trikes
    Last Post: 09-02-2015, 01:36 PM
  4. No brake lights...no cruise control
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-24-2010, 11:38 PM
  5. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
