ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  11
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Turning over engine
    Aug 2019
    Arnol, Penna, USA
    Default Turning over engine
    I have a 2006 Harley Ultra with a CSC trike kit. I recently installed an S&S cam kit and every video I saw about adjusting the pushrods said to turn the rear wheel while in gear to rotate the engine. When I tried to do this the engine didn't move regardless of the gear. I also tried removed the seat to give me access to the drive pulleys and that didnt make a difference. Can anyone tell me why rotating the rear wheel won't rotate the engine?
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by klkordzi View Post
    Turning the rear wheel on a trike is totaly different than turning the rear wheel on a bike and will not turn the primary belt/engine due to it having an automotive type differential. If you had one tire jacked up just enough to spin and the other tire firmly on the ground you might get it to rotate the engine. I said might because the compression will fight you, so you may have to remove the spark plugs to get any rotation.
    Try blocking the LS wheel so it does not turn (backwards like a car differential does) when jacked up. Be sure to have the tranny in high gear with the spark plugs out
    Aug 2019
    Arnol, Penna, USA
    Default Thanks
    Thanks everyone for the suggestions
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    You're welcome Kevin.
    You'll find this is a great community, full of knowledge and lots of folks willing to help.
    Let us know how it works out.
    Papa
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool Hello Kevin
    Kevin, what happened ????
    Jim Murphy
    Iron Butt Rider 2001
    Sep 2016
    Springfield, Mass. USA
    Holy crap, now that's was some great information that was just given........WOW! this forum is great!
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    As he rode out into the sunset
  1. Turning engine over while the trike is on jack.
    By sandrooney in forum Harley Trike Conversions
    Last Post: 01-31-2015, 04:09 PM
  2. Turning lamps on CSC?
    By rickt in forum Honda Trikes
    Last Post: 01-13-2013, 11:00 AM
  3. Brake job / Resufacing without turning
    By triwinggirl in forum Tires, Wheels, Brakes, Front End
    Last Post: 12-17-2010, 07:09 PM
  4. Voyager Trike Turning Speeds
    By Honigschmidt in forum Outrigger Style Trikes
    Last Post: 10-01-2010, 06:56 AM
