Likes Likes:  3
Results 1 to 6 of 6
Thread: dna trike
    Nov 2018
    Deland
    Default dna trike
    I'm working on an older harley conversion with a dna rear end and the hub keeps rotating...I can't find any thing that keeps the axle housing/belt protective outer hub from rotating except the friction of the large vertical clamps that hold the rear facing rods (the ones that set the belt tension)...I've looked at a lot of pictures of dna conversions and some of them show a weld along the upper edge of the axle tube and one of the vertical brackets (the one with four holes)...and I watched a youtube video of a guy converting his sportster...in that video he stated that the factory told him to weld that bracket to the tube....which would certainly solve my problem, but I'd like to confirm that with the factory...and I can't find a phone number....
    can anyone help me out here?
    thanks,
    rb\
    Welcome to Trike Talk RB📞
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by rbsalyer View Post
    thanks,
    rb\
    RB, He is correct and your recollection is correct. Once you have the rear axle CENTERED and belt opening properly oriented, you will weld the internal pinch plate(s) to the axle tube. You only weld one on each side so that the other release when you need later adjustments. Rear axle needs to be level with he frame and perpendicular (squared) with the motorcycle. Aligning and belt adjustment is a multi-faceted operation. Take your time.
    Jim Murphy
    Iron Butt Rider 2001
    Nov 2018
    Deland
    thanks for the help...I was getting ready to try to anchor the center section at the top with a bolt or make a link that would have run from the brake caliper mount to the pinch plate...I think that would have worked...I ocnsidered welding, but was afraid it might warp the tube...(back in the day when we want to put some camber in the rear axle of our stock car, we would draw a bead on the axle housing opposite of the direction we wanted it to move....worked ok...was hell on bearings....
    once again...thanks...
    rb
    Welcome to the Gang from Western Colorado.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    RB..welcome to TrikeTalk from west Texas!
    As you can see you have come to the right place for questions and answers!
  1. DNA trike conversion belt pulley size
    By 10scdust in forum Harley Trike Conversions
    Last Post: 05-05-2022, 02:29 PM
  2. DNA trike axle rotors
    By Graham Banks in forum Harley Trike Conversions
    Last Post: 12-21-2018, 07:14 PM
  3. Harley Sportster DNA trike
    By dale1948 in forum Harley Trike Conversions
    Last Post: 07-04-2018, 09:33 PM
  4. Building a heritage softail dna trike...any advice
    By JEFFCURTIS in forum Harley Trike Conversions
    Last Post: 01-18-2018, 11:54 AM
  5. What Pipes Work with DNA trike kits 2005 Fatboy
    By team98 in forum General Discussion
    Last Post: 07-11-2011, 12:25 PM
