Results 1 to 8 of 8
Thread: Drive Shaft
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Default Drive Shaft
    Do you need to lube the Drive Shaft on the older, solid axel models?
    If so, how? I do not see any zerk fittings.
    Thanks for your reply.
    Dec 2012
    I find it hard to believe no one replied.
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Sorry I’m not able to answer your question. Good luck with your research
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Gideon View Post
    if no fitting ..tough to grease it
    Dec 2012
    Question
    That is why I asked how is it accomplished?
    Oct 2010
    Must be factory sealed.
    Dec 2012
    Quote Originally Posted by trikeman View Post
    I will leave it alone. Thank you for your response.
    Ride safe
    God bless,
    Gideon
    I would contact the conversion manufacturer ... I'll bet there is a need to lube it. I had a heck os a time locating the zircon on my 08 Gold Wing with the Champion kit.
  1. Drive Shaft with Front Clamping Yoke Removal
    By Trike Dude in forum General Discussion
    Last Post: 09-06-2020, 09:06 PM
  2. shaft drive conversion
    By oldnewby in forum General Discussion
    Last Post: 05-28-2010, 10:27 PM
  3. Drive shaft
    By Trike Rich in forum Honda Trikes
    Last Post: 04-28-2010, 12:39 AM
  4. Drive shaft
    By Trike Rich in forum General Discussion
    Last Post: 03-28-2010, 11:43 PM
  5. Bad U joint & drive shaft
    By wdy41 in forum General Discussion
    Last Post: 02-07-2010, 12:48 AM
