Likes Likes:  8
Results 1 to 13 of 13
Thread: Just A Head's Up
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Default Just A Head's Up
    I'm sure most of you folks know this, but the handlebar switches in the Goldwing are not the best quality and often have issues because of the thick grease that is used on them. Just be very careful using the mute, or reverse, or cruise buttons if your bike if left in a cold place during winter. If they stick you may not get them to release until Spring, and that is after using lots of electric component cleaner.
    I brought my Wing back from Florida a couple of weeks ago and it had been in my trailer for 1 1/2 days at temperatures in the mid 20's. When I rolled it out, I inadvertently put it in reserve and had a heck of a time getting it to release. I usually spray cleaner in those switches every 3 or 4 months, but cold weather really can make the problem worse. This problem isn't necessarily only an issue with older Wings either. I've owned 9 of these bikes and all of them had this tendency. I'm leaving well enough alone until Spring before I touch another one of those buttons. Just a heads up to some of our newer owners.
    It should be a annual maintenance item to clean and replace the grease in these ... one of the first things I do when I buy a new to me wing. Already done em all on Helga,
    Sep 2016
    Springfield, Mass. USA
    My "emergency" flashers on my bike won't shut off..........I'm waiting till spring to even worry about it.... Thanks for the heads up!
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Thought the off-season was the repair season
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Yes, that is the fourth switch that riders need to be careful of. I had forgotten to include that one. Often times it is the worst since many folks seldom use it at all.
    Mar 2011
    mountain home,ar. USA
    You're much braver than I am. I would not take all those switches apart!
    Quote Originally Posted by mhgoldwing View Post
    I Agree.....Theres a 50/50 chance of putting them all back together the right way the ''First time'', But then theres a 90% probability you wont .......
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Bob, if there is a 50/50 percent chance of putting them back together right, how can there be a 90 percent chance you won't? Wouldn't it be a 50 % chance you wouldn't instead of 90? (Aren't statistics fun?)
    May 2018
    Angleton, Texas
    Whenever, I have a sticky switch I use a good grade Silicone spray. It has worked well for me for years on all my rides. Just be sure a plastic safe product like Liquid Wrench Silicone Spray.
    Quote Originally Posted by FRR View Post
    Its the same when the Wife sends me out to the store to pick something up for her...
    And theres two similar items on the shelf...So i have a 50/50 chance of bringing the right one home......But a 90% probability i'm wrong...
    Done that 90% many a time.....
    1500+ Posts
    Oct 2012
    Batavia Ohio
    That's a good one! I think we all have experienced that! Sometimes more like 100%, right?
    Yea, But there is always hope for hitting that allusive 10%.........​[Once or twice in a lifetime]
  1. Not new---just checking in. Do not post much mostly just read
    By rdtrkrdr in forum New Member Introductions
    Last Post: 01-05-2019, 12:44 PM
  2. BMW goes head to head with ???
    By Lee H. Mann in forum General Discussion
    Last Post: 10-13-2016, 08:02 PM
  3. Just fixin to head out the door.....
    By sandrooney in forum Harley Tri Glide
    Last Post: 05-26-2015, 06:25 AM
  4. Stearing Head Bearings
    By pastor bill in forum General Discussion
    Last Post: 02-12-2009, 05:54 PM
