Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Higher profile tires on 2022 Harley Trike
    20+ Posts
    Apr 2018
    New Port Richey, Fl USA
    Default Higher profile tires on 2022 Harley Trike
    Hi,
    Has anyone put higher profile tires on Harley trike that has ABS and traction control? The owner's manual says not to do this since it has wheel speed sensors and would adversely affect the ABS and traction control. I have the extra wheels and higher profile tires that were on the 2016 Trike I traded in which did not have ABS. Was not as issue on the 2016.
    If any has, were there any adverse effects?
    Quote Originally Posted by Vin View Post
    Hi,
    Vin ..Is your 2022 Trike a CVO ..?? If so they are set up from the factory with low profile tires and wheels. I imagine using a higher profile tires and wheels .Will Set off a lot of flashing warning lights….??
    The taller tires will surely throw the ABS and traction control off, the computer and BCM would set a fault code
    20+ Posts
    Apr 2018
    No, it's not a CVO. Thanks for the reply. They are set up at the factory that way. Wonder if the dealer could reprogram mine to accept taller tires... I'll have to ask.
    20+ Posts
    Apr 2018
    I agree. I'll see if the dealer can reprogram it to not set it off. Also, I'll check if they can put a 32 front sprocket in to replace the 30. Thanks for the info.
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    I am not so certain about this.
    As an example, my 2021 was an Ultra Limited, has ABS and RDRS. I converted it to a trike - which now has 17-inch wheels.
    The CSC can handle 17 inches, not sure the TriGlide can. Regardless, it did not cause any fault codes and noting was changed.
    Jun 2008
    Lovington, NM, U.S.A.
    Hello & to Trike Talk.
    Retired trike builder
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Welcome from Indiana!!!
    Bob
  1. Replies: 0
    Last Post: 08-15-2022, 02:32 PM
  2. Is There a Higher Ball Mount?
    By Ray & Paula in forum California Sidecar Trikes
    Owners Forum
    Last Post: 07-18-2021, 07:39 AM
  3. Higher ratio crown wheel and pinion
    By immortal in forum VW Powered Trikes
    Last Post: 08-12-2017, 08:26 AM
