Results 1 to 20 of 22
Thread: Trike Trailer
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Default Trike Trailer
    A couple of you mentioned recently that you were looking for a trailer to haul your trike....
    I saw this trailer on display at a local HD dealer this weekend. It is designed to easily hold the triglide or most other trikes. Obviously they also make trailers for 2-wheelers too. Looked to be pretty well built, though I did note it has minimal rock guard protection at the front of the trailer, which is something I wanted for mine. I very much liked that it can be positioned for very easy ride on/off loading at an angle that would prevent most tail pipe dragging!
    Droptailtrailers - Motorcycle Trailers, Motorcycle, ATV, UTV & Utility Powersport "Combo" Trailers
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Default Re: Trike Trailer
    I bought one of these trailers and it is great. Especially the fold it up and stand it on end in the garage. It takes up a little more room than my old single bike Kendon. As far as the tail pipe dragging, well if you can get the front of the car down just a little the pipes will not drag however if you are on level road the pipes WILL drag (on a HD Triglide). I just ordered a kit to raise the rear of my triglide and level it out. I keep backing into curbs, driveway dragging and dragging loading and unloading on the trailer if on flat ground.
    It is a great trailer and pulls very well.
    Jun 2011
    Lenexa, Kansas, USA
    I heard of the lift kit, but I guess that would soften the ride back there too? My co-pilot still finds it a little rough...
    Mar 2011
    Sun City Florida
    The Droptail trailer is, in my opinion the best trailer out there. I have three wheel cocks on my unit as I load either my 02 GL1800/motortrike or two heavey weight cruisers. They are not cheap, but they are also not the most expensive trailers available. Mine will be the last trailer I will ever need. If you plan on trailering a lot, they are hard to beat.
    350+ Posts Woolie's Avatar
    Jun 2011
    Lubbock, TX
    Here is my solution for draging pipes, I use it on my current trailer. Get one of those adjustable hitch deals that goes in the receiver, the attachment for the ball can be moved up or down to make the hitch more level with the trailer. Then mount the ball to the highest possible position, this will raise the front of the trailer and lower the rear making the ramp have less slope. After the trike is loaded, unhitch from the tow vehicle and change the receiver and ball to the one you want to tow with and hook your trailer back up. Take the other receiver with you to use when unloading. I didn't even tighten the bolts on mine since I don't use it to tow with, that way its easier to adjust to the desired height, you could even use pins instead of bolts. Works for me.
    2009 Honda Gold Wing Motor Trike Adventure Kit
    100+ Posts donjack's Avatar
    Jun 2011
    Danville Ky USA
    Quote Originally Posted by 427dave View Post
    I just put a kit from Trike stuff and its great
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Thumbs up Re: Trike Trailer
    Thanks for the information Nana. I just sent them an e-mail.
    Feb 2009
    Palmyra, Virginia
    Post Re: Trike Trailer
    I just received a response from the company. The trailer will only accept trikes that 'do not' exceed 106 inches. That leaves my Valkyrie out. I'm just over that length.
    150+ Posts
    West Bloomfield, Mi
    Quote Originally Posted by rmrc51 View Post
    Wouldn"t work for our Yam. RSV Hannigan either at 113"
    100+ Posts
    Aug 2009
    Cleveland, OHIO
    I have a enclosed 7 x 14 single axle trailer that I use for Winter storage area for my deck and patio stuff and then use it in the Summer for the trike. Works out well and is there if needed for anything.
    Bill "BigDog"
    Brook Park, OHIO
    ENJOY - Life is too SHORT!!!
    Feb 2009
    Palmyra, Virginia
    Quote Originally Posted by Bill1BigDog View Post
    Your trailer is exactly what I've been considering. At present, I just can't justify the expense for the amount of times I need to trailer the trike. If I could think of an alternate use for it like you did, then maybe I could see buying one.
    I've been watching a real nice 7 X 12 located in Georgia. Fully finished inside for just under $5,000.00
    We'll see,,,.
    100+ Posts deanone98's Avatar
    Aug 2010
    Milton, Fl, USA
    I have a enclosed single axle 6 x 14 foot trailer with a side door and back entrance door. Two windows with one on each side and a full pull out awning for camping etc. Will sell for $3000.00
    Feb 2009
    Palmyra, Virginia
    Quote Originally Posted by deanone98 View Post
    That's pretty close to what I'm looking for. The one I have my eye on is slightly wider and it's a tandem axle. Thanks for mentioning yours. Hope it sells for you.
    10+ Posts Kuddy's Avatar
    Nov 2012
    Mt.Pleasant,Iowa, USA
    Can i get by with a 6 foot wide enclosed trailer for my tri glide , ive been told i need a 7 foot . Live on gravel road so i haul it a mile to hard surface road then ride it. That is what im going to do anyway.
    Hold on to your faith through the storm.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    I think you need a 7.If you don't mind me asking why are you not riding itto the paved road? RIDE SAFE
    Nov 2012
    It gets very dusty if i do . When i had my ultra i did , could do it about 3 times then it needed washed. We have been in droughts and roads are very dusty,plus the 3 wheels kicks up more dust.
    Dec 2009
    LaFayette
    That makes sense to me.I would rather wash three cars than to wash Pearl.RIDE SAFE
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Quote Originally Posted by donjack View Post
    Could you be more specific as to the website name and the name of the kit you are using?
    I googled trikestuff and came up with trikestuff.com which is children's tricycles. Of course there was a bunch more other websites listed with the word trike in them.
    Thanks!
  19. #19
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    I recently bought a 6'4" x 12' landscape trailer for my 09RSV/Hannigan trike combo. Previously I used a 5x10' lamndscape trailer that worked great for my 05 Tri-Winged trike. But the Hannigan was too wide for it thus requiring the next size up. Cost was just over $1100 after taxes.
    Larry
  20. #20
    100+ Posts Bones158's Avatar
    Nov 2010
    Hermitage TN
    Larry, I have the same problem now with the Hannigan. My 5x10 landscape trailer is to narrow and short. I thought about cutting the sides behind the wheels but then she still would of not worked as most of the weight would be close to or behind the axel. So I'm looking for a 6x12 and most are priced around what you paid. Also I started the Aux tank install today. So far so good. Good luck with your new conversion. pepper
  1. How do you tie down a trike on a trailer?
    By Golden Dakota in forum Trailers / Campers
    Last Post: 06-13-2014, 02:20 PM
  2. BMW KLT trike and trailer
    By ebiss9 in forum BMW Trikes
    Last Post: 01-24-2013, 07:10 PM
  3. Trike Trailer
    By sporter in forum Honda Trikes
    Last Post: 02-14-2012, 08:41 AM
  4. Trike Trailer
    By redneckray in forum Trailers / Campers
    Last Post: 12-01-2011, 04:37 PM
