Likes Likes:  2
Results 1 to 7 of 7
Thread: Tech Help
    100+ Posts TrikeORNurse's Avatar
    Sep 2015
    Macon GA.
    Default Tech Help
    Does anyone know what the correct torque is for the (4) front fork pinch bolts on a Gl1800? I had to realign the front axle after a recent tire change out.
    What type of grease is used for both the clutch and brake levers?
    I greatly appreciate any input.
    2008 Goldwing/ Roadsmith Conversion
    Former Rides:
    2004 Harley Heritage Softail
    2007 Harley Streetglide
    I don't have service manuals for a GL anymore ... so can't help, but it would be the best investment you ever made, to get shop manuals, if your gonna wrench on your ride ... just my HO
    May 2011
    San Angelo
    Seems to me it is 23 ft. Lbs. *I'm away from home right now but will check in an hour or so..*
    2015 GL1800/Roadsmith HTS1800
    Sep 2015
    Macon GA.
    Quote Originally Posted by Gold Rush View Post
    Thanks guys!
    I only tackle light maintenance and oil changes.
    Anything under the main top shelter is out of my league.
    Former Rides:
    May 2011
    San Angelo
    Quote Originally Posted by TrikeORNurse View Post
    Thanks guys!
    Turning wrenches is not for everyone. I grew up working on things like this so it's second nature.
    I was wrong about the torque settings. Here is a copy and past from the service manual.
    Front axle pinch bolt 22 N·m (2.2 kgf·m, 16 lbf·ft)
    That seems a bit light to me but that is what the book says. I'm pretty sure I do around that 23 foot pound number but if the book says 16 that should be plenty. Good luck with the job.
    OH, I just thought of something. Did you know there is a special procedure in the service manual about remounting the front wheel? If you go strictly by the line up mark on the left end of the axle you may or may not be lined up correctly. The first GL1800 I owned ('01) would drag the left brake something awful with that mark aligned. If you send me your email via PM I can send you that procedure..
    Sep 2015
    Macon GA.
    Thanks kindly Jerry!!
    I use the "float axle/bounce front end method" to align the axle and pay no attention to where the line up mark ends up. The line up mark on the left end of the axle will usually not yield proper alignment results.
    All I am doing is resetting the axle alignment after a dealer installed a new tire. The dealer follows the book.
    What type grease do you use on your brake and clutch levers?
    Former Rides:
    May 2011
    San Angelo
    Very Good Kelly!! You are actually doing what the service manual says. If your dealer is not then he is doing it wrong.
    Actually, I do not use grease on the leavers at all. Grease attracts dirt and road grime. Used spray silicone lube. Once dry it will not collect dirt. I like the Liquid Wrench brand. It is a bit thicker so works well. If you are trying to lube something where soaking in is desired a less thick brand works better. For that I use AMSOIL....
    Good luck with your minor maintenance and keep up the good job!!
  1. aircraft tech
    By aircraft tech in forum New Member Introductions
    Last Post: 10-09-2014, 09:24 AM
  2. Electronic tech needed!
    By pcombe in forum Harley Trike Conversions
    Last Post: 07-06-2013, 08:41 PM
  3. Champion Tech Service
    By meredog in forum Champion Trike
    Last Post: 11-07-2010, 03:08 PM
  4. New Tech Article
    By Nana in forum General Discussion
    Last Post: 01-22-2010, 01:06 PM
