Likes Likes:  3
Results 1 to 10 of 10
Thread: Mystery slowdown
    60+ Posts CyberVet65's Avatar
    Feb 2008
    Cedar City, Utah
    Default Mystery slowdown
    Specifics. A 2003 1800 Lehman Gold Wing with 50,000 miles.
    Today I was riding at freeway speed (80mph) and I couldn't get the cruise control to "set". So I figured ok I will look at it when I got back. Then the bike lost power almost like the engine had been turned off. It would not accelerate with the clutch pulled in. There was no backfiring or indication that it wasn't getting fuel. I pulled over and the bike slowed to about 50 mph. I changed gears and it was like I turned on a switch. I rode it about 25 miles home with no problem at all.
    The engine never stopped running. The alternator was putting out 13.5 volts. Fresh tank of gas. The battery stays on a tender in the garage.
    Any tips or hints?
    The battery is over three years old. Maybe?
    Help
    Clean and tighten all battery cables, load test the battery
    Feb 2008
    Cedar City, Utah
    I will do that 1st thing Thanks
    +1
    May 2011
    San Angelo
    Also take a look at the kill switch. Over the years there have been some issues. My '06 was very sensitive to being bumped.
    2015 GL1800/Roadsmith HTS1800
    Feb 2008
    Cedar City, Utah
    Quote Originally Posted by Gold Rush View Post
    My trike sits in the garage. But I do live in the high desert country. Lots of dirt and grit blowing around. I notice the cruise button does not want to "pop out". Same for a couple other switches. The kill switch is especially sensitive. How to clean? Wil contact cleaner work? Is disassembly of the switch assembly on the bars needed?
    Jun 2008
    Lovington, NM, U.S.A.
    There is a recall for the bank angle sensor mounting screws: http://www.gwrraiachapa.com/bulletins/1800SB12.pdf Look for the white dot on the right compartment lid, as shown in the diagram in the SB.
    Use a contact cleaner that is safe on plastic, some will ruin plastic.
    Retired trike builder
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by trike lady View Post
    Correct me if I'm wrong but I thought the bank angle sensor would shut off the engine if tripped, requiring the key to be turned off and then back on to re-activate. According to OP, he simply downshifted and then bike was fine.
    Jun 2008
    You're right. But its worth checking to see if it was part of the recall.
    Went back and reread it. The cruise control may have caused the hiccup momentarily, since it didn't want to set.
    And when it slowed down and shift gears the cruise command was turned off. So it was not looking at the switch any longer. I think a sticky switch is the first place to look.
  1. Mystery designs IRS rears
    By BIBS in forum Miscellaneous
    Last Post: 04-20-2018, 06:57 AM
  2. The mystery trike kit
    By wriddle in forum New Member Introductions
    Last Post: 05-10-2010, 03:55 AM
  3. Murder, mystery!!!
    By The Wolf in forum General Discussion
    Last Post: 06-11-2009, 04:53 PM
  4. Mystery Wife & Mattel
    By Big Dog in forum General Discussion
    Last Post: 03-20-2009, 09:02 AM
  5. Mystery?
    By Reggie in forum New Member Introductions
    Last Post: 01-08-2009, 02:58 PM
