Likes Likes:  21
Thanks Thanks:  3
Results 1 to 20 of 25
Thread: fordscan
    Mar 2022
    Cumberland
    Default fordscan
    hi all i thought that the stallion was a ranger in disguise i tried to use fordscan and it doesnt recognise the pcm and quits right away asks if i have a special pcm if i have a code for it anyone else tried this new to me cheers
    Quote Originally Posted by alvy View Post
    It is a Ford Ranger mostly, however many were chipped by Rousch, maybe why you cannot get the info from your scanner ( this is why it does not recognize the ECM)
    250+ Posts
    Dec 2010
    oly,wa
    Hello
    I will probably get kicked out of here but it is a poor design by tbms. it leaves you with nothing to tune and there setup is poor quality even it has been rechipped by rousch. you cannot actually tune up your high price block of plastic.
    Dragon
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    You're wrong on this one. You can tune it. I had mine done. Had it put on the Dyno and retuned. Found the PCM was out of a Ford van and the timing was set very low. Retimed it and adjusted a few other things and now it's putting out more HP and torque. They did have to purchase a program for it to work. There is a thread on here about it.
    Stallion #378
    Suzuki Burgman 650
    try reading the part number when you get at the module behind the panel below steering wheel. that number should tell you where it came from. then you should be able to see if it can be reprogramed keep us advised
    What do you use to scan the OBD system?
    Alvin says he gets an error message when trying to use a scanner, is this common with Stallions having propitiatory ECM mappings?
    i never have scanned my wifes.
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    I know rick you had yours done but the process can only be done if you purchase certain software to achieve success. by the way how does it run.
    the code reader has a fuse under the seat see if that is blown, i had this problem.
    My pcm came from a v8 van
    Dragon
    250+ Posts
    Dec 2010
    oly,wa
    hello again
    fuse location for obdll is fuse location 29 and is a 20 amp fuse under seat
    Dragon
    Dec 2013
    Hot Arizona, USA
    Good morning
    Dragon
    Runs great. I get 30-32MPG up and down the mountains out here running at 70MPH+/-. If I'm on flat roads at that speed, I can get as much as 35MPG, but that doesn't happen very often. It's mostly around 30MPG. Yep, mine was from a V8 van and they were using half of it. If I remember right, timing was set at 10-11 degrees because of it being a van PCM and it was brought up to 21-22 degrees.
    He thought we could get it up to 24 degrees without pinging, but I said I wanted to be conservative to keep it from pinging. The fuel mixture was adjusted and the shift points were slightly adjusted. It has 55000 miles on it now and it doesn't burn any oil between my oil changes at 5000 miles. If you remember, I did change the compressor, check valve and pressure valve for the airbags and I'm loosing only about 2 pounds if I don't start it for 2 weeks. I still love it. Rick
    Stallion #378
    Suzuki Burgman 650
    Jun 2022
    Belmont NC US
    Quote Originally Posted by rocket1lf View Post
    Where is the ODBII Port on the 08 - 09 ?
    Tom
    Quote Originally Posted by 1turbofocus View Post
    Tom
    tom under the hood right side towards the back of the engine under the bars. you really have to look for it
    Jun 2022
    Belmont NC US
    Tom........Welcome to Trike-Talk..........
    Thanks , I now own 2 of them and love the ride , Wife does as well
    Tom
    Jun 2022
    Belmont NC US
    I will take a look for it , Thanks , I own a DynoJet Dyno and I do Custom Tuning with SCT Software and going to take a shot at Tuning it , 180 deg Thermostat , Fan setting , Trans settings , MPG etc and see how it goes
    I work with the Duratec 2.0 , 2.3 , 2.5 In the Focus so I know the Engine very well and build them NA over 200whp and Boosted over 700 whp street Cars. Not looking to do that here but I know I can improve things a good bit
    Tom
    Jun 2022
    Belmont NC US
    Thanks , Found it
    Tom
    Mar 2024
    Warrenton, VA, USA
    So what is the part number on the pcm? Anyone just swapped in one programmed for a ranger?
    Quote Originally Posted by HedgehogRider View Post
    No you can not just swap the ECM's. The shift points will be all wrong most important.
    Mar 2024
    Warrenton, VA, USA
    Maybe the shift points will be off but the computer would be more easily programmable. Is the computer the single or triple plug style?
  19. #19
    Dec 2013
    Hot Arizona, USA
    When they reprogrammed my computer, we found out it was out of a Ford V8 van and TBM was only using one side of it. The shop did buy a program, I had to pay for it, to be able to get into it to reprogram it. I don't remember what it looked like, but it is inside the panel below the steering wheel. Rick
    Stallion #378
    Suzuki Burgman 650
  20. #20
    Mar 2024
    Warrenton, VA, USA
    My theory is they did that because those computers did not have the PAT system natively incorporated. Has the guy who did yours done others? Can you share his info? I have seen your post across multiple threads and think the community would be interested in being able to tune these.
