Likes Likes:  9
Thanks Thanks:  1
Results 1 to 20 of 20
Thread: Towing trike advise
    100+ Posts Rev J's Avatar
    May 2016
    NC
    Default Towing trike advise
    Hey everyone. I'm looking to buy a 6'x10' utility trailer. There are times I just have to haul the Triglide because of wife's health issues. The dealer has one that has a flat deck and another with the dove tail. Both are the same price. Is one better than the other? Not sure which one to get. Any advise, personal experiences appreciated. Thanks, RevJ.
    70+ Posts
    Dec 2018
    FREDERICKTOWN MO
    My personal choice would be the dove tail (shorter ramps)..
    QUESTION: do they tilt????? "IF NOT, THE DOVETAIL would be the way to go.
    If they do tilt, I would still go with the dove tail......
    Hopes this helps.
    May 2016
    NC
    Quote Originally Posted by Gold Nugget View Post
    Hopes this helps.
    Is that because the shorter ramp takes up less space or is it easier to load? Neither trailers tilt. Thanks, RevJ.
    70+ Posts
    Dec 2018
    FREDERICKTOWN MO
    The back of the trailer should be closer to the ground. (not as steep)All mine(3) have dove tails, lots of times I can back into a ditch and not use the ramps. I assume the trailers have a 1-piece back that drops down?
    PIC'S?
    May 2016
    NC
    PIC'S?
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    IMO, I would ride the trike to his facility & see which one that you like the best when loading the trike. The longer gate ramp is better when loading to avoid bottoming out. I have an open 19' car hauler that I use hauling different equipment. The 5' ramps that came with the trailer were good for cars but not so much for riding mowers. Got a set of 7' ramps & all is good. Whichever trailer you purchase, be sure to get a spare tire.
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Quote Originally Posted by Rev J View Post
    I'd buy the Dovetail and have them put the Taller ramp on it. I had mine built like that....works great. Also had them add a short {ish} stone guard. jc
    Name:  Bully Trailer (5).jpg
    30+ Posts
    May 2019
    Apache Junction, AZ USA
    You might want to look at the Aluma TK-1 trike-specific trailer. Integral ramp slides out from under bed, stone guard protects from gravel, etc., and weighs only 550#. You can see it here: https://www.alumaklm.com/recreationa...-trike-trailer
    Good luck!
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    If you can find one i would look at a 6 1/2 ft wide that's what i have and it gives you just enough extra clearance on the sides.My friend put his Tri on his 6 ft wide trailer and i wouldn't feel comfortable only have a couple inches of clearance between the trailer and the rear fenders,if i heard the parts guy right the unpainted fender is $700.Mine is not a dove tail and i wish it was,i have two short 2x10's that i use to make the ramp a little longer so the pipes don't drag.
  11. #10
    Jun 2010
    Indianapolis, In.
    If possible, $ wise, I would consider an enclosed trailer. Better security and not exposed to the elements while towing. There are some good deals on used enclosed trailers out there!!!
    Suggesting 7X12 for a trike
    Here's some new and used examples on EBay:
    https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  12. #11
    Apr 2015
    Sorry...but other add-ons.... I had them run angle Iron under the deck where I was going to bolt the chock. Gives me a solid mount...And had them add other bars to the ramp where all three tires hit...again, maybe a bit over cautious...but peace of mind. you can see the better supported ramp in the pic.
  13. #12
    70+ Posts
    Dec 2018
    FREDERICKTOWN MO
    Quote Originally Posted by jc1300 View Post
    What jc said, dovetail with the longer ramp is a excellent idea & choice.
  14. #13
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    I would go for the dovetail model. It will make loading easier especially with a longer ramp.
    We bought an Aluma 7712H tilt trailer after my wife decided she wasn't up to long distance trips riding in bad weather anymore.
  15. #14
    5+ Posts jamesdn's Avatar
    Mar 2017
    Fredericksburg,TX, USA
    You will find a 6x10 enclosed trailer is a little too small for hauling a trike. I use a 7x12 enclosed trailer, tandem axle, electric brakes, and a rear ramp door. Super easy to tie down and haul the bike. Mine weighs about 3500 lb with the bike loaded. Additionally I have room for extra junk. This is the one that I have for example:
    https://homesteadertrailer.com/service/ez-rider-series/
  16. #15
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Dove tail is best choice. Your mufflers are close to the ground. The regular trailer will be a steeper (higher) ramp. Dovetail makes a smoother transition to deck.
  17. DKCustoms postbit
  18. #16
    Apr 2015
    Quote Originally Posted by ol' school View Post
    That is a great looking trailer...and surprised you don't drag on the way in or out...and being aluminum...nice and light.
    jc
  19. #17
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Thanks JC... I have to two short sections of 2×12 I lay down for the rear wheels just to make sure the pipes don't drag if we are loading/offloading somewhere the pavement is not level. The tilt on the trailer is 15 degrees and is usually ok.
  20. #18
    +1 on the dove tail ... I built mine from an old boat trailer. I made a 6' x 6' ramp ... way over kill, but loads nice, but, dove tail would of allowed a shorter ramp that would have had less drag. I'm considering making the ramp fold down in half to cut the drag.
    Name:  2015-04-09 12.43.22.jpg
    I too added a solid beam where the wheels ride.
    Name:  2015-03-26 14.03.18.jpg
    And a rock guard
    Name:  2019-03-18 09.52.20.jpg
  21. #19
    May 2016
    NC
    Thank you for all the recommendations. I will take each in consideration. Be safe out there guys.
  22. #20
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    I have had both the TK-1 Aluma trailer and a previous one. We used to haul our Ultra once and awhile and that was why we purchased the first one. When we began traveling 7 months out of the year in our RV we went with the TK-1 for the TG.
    With the storage box and protection up front you have a place for chocks and a jack. I even mounted a spare there. The ramp stores under aluminum bed and is hidden. With a torsion axle it is the perfect trailer for hauling a TG.
    Good luck with your decision.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
  1. Trike selection advise/suggestions for newbie please.
    By NiteOwl in forum Harley Trike Conversions
    Last Post: 09-23-2013, 08:38 AM
  2. Converting my Heritage - Please advise
    By hardriderbabe in forum Harley Trike Conversions
    Last Post: 05-02-2012, 04:17 PM
  3. Need advise.
    By triker1 in forum Miscellaneous
    Last Post: 04-16-2012, 12:59 PM
  4. sportster trike advise
    By Greg hicks in forum Harley Trike Conversions
    Last Post: 01-25-2011, 08:15 PM
  5. need some advise
    By WEB in forum General Discussion
    Last Post: 03-26-2008, 08:11 PM
