Results 1 to 6 of 6
Thread: Broken drive belt again
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Broken drive belt again
    I have a 2007 Stratoliner with 85,000 miles. I broke a second drive belt yesterday and now looking for guidance on WHY. Do trikes need a looser belt? Doing a quick inspection I see no signs of sprocket damage and the belt looks brand new. Going to check sprocket alignment today and remove the front sprocket for a detailed inspection. These belts are not cheap (the first one I had to replace near Michigan and cost $750 (just for the belt) as I was on a group ride). If I can't figure out the problem I may convert to chain drive. Oh, I fabricated the trike myself and didn't install a cush drive.
    Hugh hard to say what your problem is but yes the belt can be to tight. Harley suggests about a 1/2 in deflection when about 10lbs of force is put in the middle of the lower belt.
    Good luck in your search for the cause. Belt breaking when not caused by a foreign object getting into the belt is unusual.
    I like to run belts on the loose side
    Too tight has always been a problem not only in breakage but also harder on bearings
    Early Spyder's belts were set too tight per Can-Am specifications and some front sprockets and main shafts were striped...Mine included...
    All my HD belts I felt were too tight from the factory
    I always adjusted them a bit looser and never had any problems
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Thank You
    I think I will go for a touch looser this time. I was pushing 10 pounds at 1/2" but will go for 3/4". Still planning for a chain drive mod later with a 530 chain as we plan to ride these bikes till the cows come home!!
  1. Primary drive belt adjustment
    By jkchipster in forum General Discussion
    Last Post: 02-05-2012, 03:14 PM
  2. drive belt rubs t/g's oil pan
    By eagle1 in forum Harley Trike Conversions
    Last Post: 02-01-2012, 10:13 PM
  3. baker plus 1 oil pan runs drive belt on '09 t/g
    By eagle1 in forum Harley Tri Glide
    Last Post: 11-23-2011, 08:10 AM
  4. Drive Belt Problem on Frankenstein conversion
    By icebite1 in forum Harley Trike Conversions
    Last Post: 09-02-2011, 02:15 PM
  5. Harley trikes and belt drive ????
    By White Knight 04 in forum Harley Trike Conversions
    Last Post: 07-27-2011, 08:41 PM
