Results 1 to 20 of 26
Thread: Satellite Radio
    TOI - Illinois TrikerMimi's Avatar
    Jun 2010
    Bartlett, IL
    Default Satellite Radio
    We desperately want to add satellite radio to our trike, but can't seem to find which unit is best and if the installation is difficult. Any ideas??
    TrikerMimi and TrikerMick
    '03 GL1800:cool:
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Post Re: Satellite Radio
    I'm also considering doing the same.
    At present, I'm going to go for one of the Garmin Zumo GPS units. These GPS units also have the provisions for Satellite Radio and they plays MP3 files for your music. So if you don't have a GPS yet, you might consider one of these.
    30+ Posts
    Jun 2011
    Granville,Tennessee
    Default Re: Satellite Radio
    I have had a Zumo 550 for years and always knew about the XM setup but never did anything with it..Today I ran across the antenna which is also the receiver at a deal that I just could not turn down..I hooked everything up,just put the antenna in a windshield bag,Great reception and I am wearing a very large grin..
    550+ Posts
    Feb 2012
    tupelo MS
    I use my Iphone4 using tunein radio. You get any kind of music incl your local stations.
    I am on C Spire, have unlimited INTERNET.
    30+ Posts
    Jun 2011
    Granville,Tennessee
    My problem as I live in the country with no cell phone coverage,and do most of my riding where there is spotty service at best..
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by Captain Itch View Post
    I'm using the Zumo 550 with XM antenna on my Trike, I'm an XM radio junkie. I have one in the house, the Zumo 550 antenna on the trike and the factory one installed on my 06 Ultra.
    Jun 2010
    Bartlett, IL
    I love the suggestion, but yikes! wasn't prepared to spend 600 bucks on a GPS unit!! Just wanted to get a radio from XM and install on the bike. (Radios are only about 129) I will definately keep the GPS in mind if my financial situation allows in the future.
    '03 GL1800:cool:
    50+ Posts Bagger's Avatar
    Jan 2012
    Lexington north carolina
    I use the road tech by Harley.
    I went to Best Buy and bought a radio off the shelf that was satellite ready--they installed it, antenna is inside the fairing. cost just over 200.00 installed. sirus--cd player--sd card player --ear phone-aux plug Works great
    (l ready had the speakers)
    Attachment 5208
    Remember--It is never the issue but rather how we react to the issue is the issue.
    http://www.buggy.com/
    07 VTX 1800 w/Champion Trike Conversion
    [SIGPIC][/SIGPIC]
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by TrikerMimi View Post
    All you need is a handlebar docking kit available from RAM MOUNT and a satellite radio. I have installed Sirius radios on GL1800. The pigtail in the left dash pocket will integrate it to your factory system. A power accessory plug is also located under the left dash pocket to give the satellite radio power. I would mount the satellite antenna on the dash behind the windshield and below the windshield vent for best reception.
    Jim Murphy
    Iron Butt Rider 2001
    30+ Posts 03 Softail's Avatar
    Jul 2011
    Oconomowoc, Wi
    I just got a XM radio kit from Radio shack, I put the radio and docking hardware in the
    center windshield bag (3 bag windshield bag) ran one wire to to AUX input jack on the
    bike radio, ran the satellite antenna under the front fairing and put the antenna top
    of the bikes radio, tapped into the cigerate lighter with an acc. adapter from an
    auto parts store for my power. tugged this and all the excess wire up under the fairing.
    Got the xm radio kit on sale for 49.99 and acc outlet for less than 10.00.
    I get very good reception and the only thing that shows are the 3 plug in coming from
    the xm radio, 1 to the AUX jack, 1 antenna, and 1 power.
    [SIGPIC][/SIGPIC]
    2010 TG, V&H Dresser Duels, Python Predator
    Mufflers, SE Ventilator, SE Pro tuner,
    HD Anarchey wheels, Spinner Hub Caps
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    I like simple. For three years now I have installed small Delphi Roady xt units on my motorcycles (at least the docking station). I mount the docking in my trunk (HD trunks), and supply them with 12v switched power and mount the very small antenna on the top of the trunks with the supplied adhesive tape. The Roady modulates the XM reception on an FM frequency (you set it), so I get two major advantages; 1) I subscribe to only a single radio with XM and switch to the docking stations installed on each of my primary motorcycles, and 2) no wiring required directly to the radio. You tune your desired frequency and it is received by your existing FM radio with crystal clarity. You also have the option of a cheap set of earphones for your ears that have an XM receiver so you can get the XM radio wireless to your helmet sets when you travel. When you start you motorcycle, the XM receiption is switched on automatically and you can use or not as you wish. If you stay mostly with a single XM channel (as I do) then you will not really have to change anything as you travel. Changing stations on the XM receiver will require opening the trunk at a stop (change with a remote, but it will not work thru the trunks). Of course you can mount the little receiver in the front area wherever is convenient and weather protected and have easy control of it while driving.
    You can probably pick one of the Roady XM receivers from eBay for $20-$30 with a single docking station if you watch carefully. I bought three systems at one time from an electronics store for $110 which included three brand new total systems (radios, remote, antennae, docking stations, and coaxial modulators which plug the modulated output into the radio antenna cable if desire the absolute clarity possible, etc.). I used the coax connection on my motorhome installation which gives me perfect clarity but no better than the wireless setup.
    For me, cheap hardware and only one annual subscription for all my motorcycles. Like I said, I like simple.
    im using 12vt radio £14 free delivery from china,can attache mp3 to it comes with speakers pretty loud
    Jun 2010
    Bartlett, IL
    Thank you all so much! Gonna start shopping around!
    '03 GL1800:cool:
    30+ Posts swampride's Avatar
    Dec 2011
    Okeechobee,Fl
    XM Snap plugs in to fairing cigarete lighter socket. stick attenna pod on fairing above speaker. Tune to FM or plug 3.5 jack into accessory on radio. $39. Have one on both bikes.
    Amazon.com
    Amazon.com: AudioVox XM XSN1V1 Snap In-Vehicle Radio
    60+ Posts ProudTexson's Avatar
    Dec 2012
    Big Spring Texas
    I run a Sirius Stratus6 docking system mounted to my bars. It has all power,speaker and antenna all hooked up. I have the same system mounted in my pickup. It can easily be moved from one to the other.The antenna a handle bar mounted. I have the Kuryakyn handle bar speakers with built in amp. works very well. just put it on Willy's Roadhouse and ride.
    450+ Posts ladyff1481's Avatar
    Apr 2009
    Waverly, NY
    Watch the Sirius XM website for their specials. Last Christmas they offered a free radio (Onyx with vehicle kit) if you bought a $50 gift card. I already had the service in my car so I used the gift card towards the subscription cost and now have a Sirius XM radio for the trike. They have been offering a few specials already on their radios, I bet they have a gift card/free radio type deal coming just in time for Christmas.
    30+ Posts
    Jul 2012
    Peary, Arkansas,USA
    I want to have XM satellite on my 2012 Honda Goldwing Trike. Is there a unit out there that you can connect to your ipod connection in the truck. I want to listen to the XM radio through my helment headset and also control volume and stations just like the AM/FM radio on my trike. I wonder what it would cost and if possible to upgrade my existing system with one that has satellite radio and GPS.
  19. #19
    Feb 2008
    Anderson, Missouri
    When we got a new car last April we got 3 free months Sirius. When I didn't continue they called and offered me 6 more months for a little less than $5/month. Cancelled when it was over, and they offered another 6 months for the same price. That is only in the car. I know a lot of folks that love it and that is great for them. For me, I can't see paying the $14.99 per month for radio when I have 32 gigs of music on my phone, most places I ride I can get a signal for I-Heart Radio, Pandora, Last FM, etc. - not to mention regular radio.
  20. #20
    20+ Posts
    May 2015
    Mattawan
    Thanks for all the different means to getting to the same end. I'll be doing some shopping now for a satellite radio system.
  1. satellite radio
    By rgw5944 in forum Honda Trikes
    Last Post: 07-15-2012, 12:17 PM
  2. Distortion with Zumo 550 GPS and Satellite Radio
    By eforman48 in forum Harley Trike Conversions
    Last Post: 07-11-2012, 07:30 AM
  3. CB Radio
    By rgc in forum Harley Trike Conversions
    Last Post: 03-26-2012, 10:33 AM
  4. CB radio
    By Venture 1 in forum Accessories
    Last Post: 11-19-2011, 12:20 PM
  5. Photo from Israely Satellite
    By mpolissky in forum General Discussion
    Last Post: 09-09-2011, 02:07 PM
