Likes Likes:  3
Thanks Thanks:  1
Results 1 to 9 of 9
Thread: Stage 2 questions
    100+ Posts
    Feb 2019
    Olivette, mo. usa
    Default Stage 2 questions
    I want to 'll do a stage 2 on my 2016 freewheeler, if you can advise me I would be grateful. What is the best torque cam to buy. Will anything else need to be updated and what is the approximate cost if done by a dealer.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by 2ndheart View Post
    Hello my friend. Hopefully Jack will chime in here, as he has had a twin cam FW.
    In general, I feel you can't go wrong with S&S.
    https://www.fuelmotousa.com/series-2...camshafts.html
    Here would be my choice, I would have crank run out checked first before doing any work
    https://www.sscycle.com/4-steps/step...s-and-pushrods
    Oct 2017
    St. Louis, MO USA
    Jack, I have a question, everything listed is for 2013 or older. Where are the cams listed for the last few years of the TC?
    Here
    https://www.sscycle.com/easy-start-cams/
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Default 2016 FW cams
    I was told the 2016 FW engine came with an upgraded cam. Due to being a trike.
    Was this wrong info!
    If yes, so an upgraded cam is int the stage 2?
    Quote Originally Posted by Mcmister View Post
    Same cams are in a Roadking Model, nuthin super about them I can see
    100+ Posts
    Feb 2019
    Olivette, mo. usa
    All 2014 - 2016 had updated camshafts, this the designation 103ho. A performance cam for the trike is not listed for 2014+ twin cams. I am not sure what cam would work for a stage 2 update, maybe if someone has done a stage 2 on a Rushmore trike they could give me a heads up.
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Default Rushmore
    My HD dealer “”specialist” told me “you already have the Rushmore cam. No need to further upgrade cam. Next upgrade would be larger pistons, etc”
    My stage 1 was/is very worthwhile
    HD FW 2016
  1. performance machine stage 1 rear brake kit on ebay
    By eagle1 in forum Harley Trike Conversions
    Last Post: 03-09-2012, 12:08 PM
  2. attn. anyone installing the perf. machine stage 1 brake system(help)
    Last Post: 02-20-2012, 10:15 AM
  3. Performance Machine Stage 1 install experience
    Last Post: 02-14-2012, 04:49 PM
  4. Replies: 3
    Last Post: 12-21-2011, 09:15 AM
  5. '09 t/g installing p/m stage 1 rear brakes
    By eagle1 in forum Harley Tri Glide
    Last Post: 11-19-2011, 05:40 PM
