LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  1
Results 1 to 15 of 15
Thread: Kill the green light in the tach
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    Default Kill the green light in the tach
    Can the green warning light mounted in the tach for the fog lights be un plugged ? That sucker is so damn bright it is distracting.
    Quote Originally Posted by MikeyTX View Post
    Cut a piece of black tape into a circle just a little larger than the light, and stick it on the tach over the light...
    May 2016
    I'd thought of doing that, I'm hoping the power source can be un plugged.
    Have you asked the dealer if it can be programmed to stay off?
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    I'd thought of doing that, I'm hoping the power source can be un-plugged.
    I've never done it and will check my assembly manual but think it's a serviceable bulb. I'd just pull the bezel out of the back of the tach and pull the bulb out.
    8~\o
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Texan View Post
    8~\o
    Be sure to reinstall the socket to prevent water intrusion
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    If you can unplug it un-like my tape idea, Where you can still see a little light telling you the brights are on.. How many times are oncoming [Angry] drivers going to flash their brights at you telling you to shut yours off..
    May 2016
    8~\o
    No longer a bulb. LED now
    Jun 2013
    Texas
    Ohhhhhh, Okay, Guess I should have ask what year your trike was ???
    But that LED element still has to be able to be removed from the tach... !!!
    8~\o
  11. #10
    May 2016
    Sadly, the LED is attached to the pc board inside the housing for the speedo/tach assy that is a sealed unit. That is why it costs out the ying yang to replace it. I have a white opaque sticker that says "Crashing Sucks." I will trim it to fit the lower half of the tach. The green will shine through but not as blinding. I will also be able to see the high beam, R and, P indicator lamps through it.
  12. #11
    Jun 2010
    Indianapolis, In.
    So, my final answer A piece of dark window tinting over it. Will dull down the glow but, you can still be aware your hi-beams are on But then, I never really needed an "idiot light" to indicate to me my brights were on
    Patriot Guard
    Was a LEO
  13. #12
    Your good... Most people wound't turn them off in-till they get a friendly wake up call.....
  14. #13
    May 2016
    Default Done purposely
    The take from several techs I inquired of is that the motor co is intent on discouraging night time use of the fog lights. They would prefer that we purchase the new engine guard mount lights. The exact reason I have Moto Lights. Much better as the light beam follows the direction of the headlight.
  15. #14
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I'm pretty sure this thread was about the AUX lamps green indicator lamp staying lit all the time ... not the high beam indicator.
    My 2014 AUX lamps were re-programmed to stay on with both high and low beams. I like it that way... and it is legal in my State. They are aimed to show closer road surfaces so I can pick up pot holes and road debris easier at night. The low beam without them is pitiful for seeing problems.
    I only regulate the high and low center LED lamp.
    The idea of a circle of black tape would work best for me.
    Bob
  16. #15
    May 2016
    Quote Originally Posted by HDB0B View Post
    Bob
    Spot on (pun intended)
  17. DKCustoms postbit
  1. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  2. tach
    By old stoner in forum Honda Trikes
    Last Post: 02-18-2015, 08:12 PM
  3. 2010 triglide reverse green light always on
    By dafoot2 in forum Harley Tri Glide
    Last Post: 05-21-2013, 03:33 PM
  4. tach redline
    By geraldlanc in forum Stallion Trikes
    Last Post: 05-15-2013, 04:55 PM
  5. Vw trike tach
    By RLJO in forum VW Powered Trikes
    Last Post: 02-06-2012, 07:20 AM
