Results 1 to 4 of 4
Thread: Reverse Issue
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Default Reverse Issue
    On my 2012 Wing which is Triked I've noticed an issue once in a while where when the reverse button is pushed, and alloted time is given, it sometimes engages and then disengages and just clicks. Suggestions?
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Does it chatter when pushing the start button to make it back up ??? Another way of asking ... does it feels like it want to begin to move but quits after the start button is hits ???
    Official Mascot Trail Blazer's Avatar
    Nov 2012
    huntington , texas
    Default Reverse
    hay Fred. I have a 2000 gl1500se and am having problems with my Reverse also. I worked for years then one day, no reverse, it engages then kicks out quickly only rocks a little then out it goes. I have looked at all components that effects the reverse that I could think of, then cared it to the shop. they to are stomped. it will start working after checking a number of thing. we think we have it fixed then after a while it is out again. we made a ride to Montana, was gone 3 weeks and it worked like a new one ( I thought we had it fixed for good that time). I was home 2 days, went to get oil for oil change and bang it was out again. try to back up then kick out again. back to shop. 4 time back to the shop. it is working now but for how long ????? the shop said they do not know why it started working again. we Have to wait until it stop working and check again. when it is working you can't find the problem. so bottom like I can not help you, until I get a fix ??????
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Trail Blazer View Post
    That's a real bummer man. Yesterday, didn't want to engage. Today, worked fine. Go figure. Guess I'll see what my tech says when he does my brakes later this month.
  1. ECM issue
    By Lee H. Mann in forum Harley Trike Conversions
    Last Post: 02-11-2017, 05:40 PM
  2. First issue with my 17
    By Mykneesbehurtin in forum Harley Tri Glide
    Last Post: 01-10-2017, 09:10 PM
  3. Replies: 2
    Last Post: 11-29-2014, 11:31 AM
  4. OK, Here's My Issue
    Last Post: 02-25-2014, 09:42 PM
  5. Reverse Button Issue
    By hbrogan57 in forum Honda Trikes
    Last Post: 10-20-2012, 03:40 PM
